In total there are 19 users online :: 0 Registered, 0 Hidden and 19 Guests :: 1 Bot
side engine fan Icon_minitimeWed Aug 16, 2023 1:17 pm by RADICAL RAM
side engine fan Icon_minitimeThu Dec 14, 2017 4:54 pm by WV Hot Rod Rhino
side engine fan Icon_minitimeThu Dec 14, 2017 1:28 am by WV Hot Rod Rhino
side engine fan Icon_minitimeThu Dec 14, 2017 12:35 am by WV Hot Rod Rhino
side engine fan Icon_minitimeFri Dec 13, 2013 11:01 am by WV Hot Rod Rhino
side engine fan Icon_minitimeFri Dec 13, 2013 10:59 am by WV Hot Rod Rhino
side engine fan Icon_minitimeFri Dec 13, 2013 9:33 am by Tacoclaw
side engine fan Icon_minitimeFri Dec 13, 2013 7:50 am by chuddly
side engine fan Icon_minitimeFri Dec 13, 2013 7:47 am by chuddly
side engine fan Vote_lcapside engine fan Voting_barside engine fan Vote_rcap
 side engine fan
dunerdan
meats
10 posters
meats
meats
side engine fan Empty
PostSubject: side engine fan   side engine fan Icon_minitimeSun Mar 17, 2013 11:30 am
i know i've seen this before but i think it was on rf, but its the fan on the right side of the motor i was just wondering if i need this on and whats the purpose of it. thanks
PostSubject: Re: side engine fan   side engine fan Icon_minitimeSun Mar 17, 2013 11:47 am
It blows air on the exhaust I took mine off and left it off when I put a new piston in mine a few mo.s ago.
http://www.trailbrightled.com
PostSubject: Re: side engine fan   side engine fan Icon_minitimeSun Mar 17, 2013 11:53 am
Yep, Just blows air across the exhaust. Couple things tho. When I took mine off(just the hose) the exhaust hanger tried to catch fire. Some have said, It will melt Your hanger then You will crack the manifold. Others have removed with success. The down side of the fan is, when it gets water or mud in it, it bogs the motor real bad.
PostSubject: Re: side engine fan   side engine fan Icon_minitimeSun Mar 17, 2013 11:55 am
removed mine when i installed my hmf , no issues to date
dunerdan
dunerdan
PostSubject: Re: side engine fan   side engine fan Icon_minitimeSun Mar 17, 2013 1:56 pm
if you have stock exhaust it cools the rubber mount. if you have aftermarket exhaust, ditch the whole setup.
I pondered running inter my intake for a supercharger... lol!
PostSubject: Re: side engine fan   side engine fan Icon_minitimeSun Mar 17, 2013 2:25 pm
dunerdan:...... I pondered running inter my intake for a supercharger... lol!
Imagine what would happen when you went into the water and pumped a few gallons of it into the intake ..... ScubaCharger .... Exclamation Laughing
PostSubject: Re: side engine fan   side engine fan Icon_minitimeSun Mar 17, 2013 7:51 pm
I removed mind because it was bogging down in the mud. I melted my exhaust mount the next ride. I've been dealing with the aftermath since. Pretty sure the manifold is cracked but haven't tore into it yet. On the plus side I tear thru the deep mud now.
If you're running stock exhaust I wouldn't suggest ripping it out.
meats
meats
PostSubject: Re: side engine fan   side engine fan Icon_minitimeSun Mar 17, 2013 9:30 pm
thanks for the info guys guess ill leave it on for now
PostSubject: Re: side engine fan   side engine fan Icon_minitimeSun Apr 07, 2013 9:27 pm
older thread but i was thinking about taking my side fan off as well i have pro-tec dual exhaust so i should be safe? when i remove the fan do i need to put a cover or anything where the fan was? thanks
PostSubject: Re: side engine fan   side engine fan Icon_minitimeSun Apr 07, 2013 9:55 pm
Where are those fans located? Are they electric, or bolted to the sheave? I know my 700 don't have one, but I've heard alot about the bogging down from it.
PostSubject: Re: side engine fan   side engine fan Icon_minitimeSun Apr 07, 2013 9:57 pm
Its on the passenger side. Bolted to, i guess the crank
PostSubject: Re: side engine fan   side engine fan Icon_minitimeSun Apr 07, 2013 10:05 pm
yes it bolts to the crank
PostSubject: Re: side engine fan   side engine fan Icon_minitimeMon Apr 08, 2013 12:21 am
so would i just remove the fan an leave the shroud on the motor or remove it all
side engine fan
» Came over from the dark side...
» ROD Side Play
» Engine case?
» hello i made it to the dark side
» engine cooling!!!
