| wet clutch off | |
RADICAL RAM
| Subject: wet clutch off Fri Aug 09, 2013 10:51 pm | |
| anyone currently have there wet clutch apart.?
curious if there is a hole in there big enough in the side of the engine case to reach in with a magnet. trying to find a valve spring keeper that may have dropped into my case.
thanks | |
| Subject: Re: wet clutch off Fri Aug 09, 2013 10:53 pm | |
| there is a couple spots in there that needs checked | |
RADICAL RAM
| Subject: Re: wet clutch off Fri Aug 09, 2013 10:56 pm | |
| - WV Hot Rod Rhino wrote:
- there is a couple spots in there that needs checked
James you mean couple spots inside the case i need to check for keeper? or couple of spots behind wet clutch i can get magnet in? | |
| Subject: Re: wet clutch off Fri Aug 09, 2013 11:01 pm | |
meats
| Subject: Re: wet clutch off Sat Aug 10, 2013 9:35 am | |
| i will have my wet clutch cover off this morning if that will help i am replacing my screw up. i will take a pic for you. | |
RADICAL RAM
| Subject: Re: wet clutch off Sat Aug 10, 2013 9:47 am | |
| - meats wrote:
- i will have my wet clutch cover off this morning if that will help i am replacing my screw up. i will take a pic for you.
cool thanks | |
meats
| Subject: Re: wet clutch off Sat Aug 10, 2013 11:42 am | |
| here is the only hole that is accessible. but with a small magnet with a flexable handle you should be able to get in there. its about a half inch hole. just remember to get a gasket and not to silicone the cover, you will be taking it apart again like i am. hope this helps. | |
meats
| Subject: Re: wet clutch off Sat Aug 10, 2013 11:48 am | |
RADICAL RAM
| Subject: Re: wet clutch off Sat Aug 10, 2013 12:28 pm | |
| thanks for the picture meats. if that is the only hole then i don't think that is going to help me in finding it. | |
| Subject: Re: wet clutch off | |
| wet clutch off | |
