In total there are 26 users online :: 0 Registered, 0 Hidden and 26 Guests :: 2 Bots
droping tire size an adding cage extension should i change my spring  Icon_minitimeWed Aug 16, 2023 1:17 pm by RADICAL RAM
droping tire size an adding cage extension should i change my spring  Icon_minitimeThu Dec 14, 2017 4:54 pm by WV Hot Rod Rhino
droping tire size an adding cage extension should i change my spring  Icon_minitimeThu Dec 14, 2017 1:28 am by WV Hot Rod Rhino
droping tire size an adding cage extension should i change my spring  Icon_minitimeThu Dec 14, 2017 12:35 am by WV Hot Rod Rhino
droping tire size an adding cage extension should i change my spring  Icon_minitimeFri Dec 13, 2013 11:01 am by WV Hot Rod Rhino
droping tire size an adding cage extension should i change my spring  Icon_minitimeFri Dec 13, 2013 10:59 am by WV Hot Rod Rhino
droping tire size an adding cage extension should i change my spring  Icon_minitimeFri Dec 13, 2013 9:33 am by Tacoclaw
droping tire size an adding cage extension should i change my spring  Icon_minitimeFri Dec 13, 2013 7:50 am by chuddly
droping tire size an adding cage extension should i change my spring  Icon_minitimeFri Dec 13, 2013 7:47 am by chuddly
droping tire size an adding cage extension should i change my spring  Vote_lcapdroping tire size an adding cage extension should i change my spring  Voting_bardroping tire size an adding cage extension should i change my spring  Vote_rcap
7 posters
droping tire size an adding cage extension should i change my spring  Empty
PostSubject: droping tire size an adding cage extension should i change my spring    droping tire size an adding cage extension should i change my spring  Icon_minitimeWed Aug 14, 2013 12:28 am
im running very heavy 29.5 swamplites right now but i just orderd a set of 28-10-12 maxxis zillas they are about 13 pounds lighter than the swamplites but i also just orderd a cage extension from rhinogiant.com should i change my secondary spring from purple to orange or stay with the purple thanks
PostSubject: Re: droping tire size an adding cage extension should i change my spring    droping tire size an adding cage extension should i change my spring  Icon_minitimeWed Aug 14, 2013 2:39 am
all I know is I would get a stiffer spring for the rear shocks. what shocks are you running?
PostSubject: Re: droping tire size an adding cage extension should i change my spring    droping tire size an adding cage extension should i change my spring  Icon_minitimeWed Aug 14, 2013 4:13 am
Unless someone knows for sure, I would run it and see what you think.  I'm running the purple with 25 horns.  Mine may run a little stronger with the stock one in there and have more top end IDK, but I like how the revs come up when I gas it on a hill, and I like knowing I have a little more grip on the belt to go with the added power of the cam.
PostSubject: Re: droping tire size an adding cage extension should i change my spring    droping tire size an adding cage extension should i change my spring  Icon_minitimeWed Aug 14, 2013 6:57 am
Hump is right. It will have a lot to do with personal preference it will probably be best to ride it and see what you thank.
PostSubject: Re: droping tire size an adding cage extension should i change my spring    droping tire size an adding cage extension should i change my spring  Icon_minitimeWed Aug 14, 2013 9:01 am
25-26 orange...27-30 purple
PostSubject: Re: droping tire size an adding cage extension should i change my spring    droping tire size an adding cage extension should i change my spring  Icon_minitimeWed Aug 14, 2013 2:29 pm
 mine is the sport model so it has the stock resi shocks im going to crank them up tight an hope that will be enough if not ill add a lift in the rear to make up for the weight
PostSubject: Re: droping tire size an adding cage extension should i change my spring    droping tire size an adding cage extension should i change my spring  Icon_minitimeWed Aug 14, 2013 2:31 pm
an thanks for the info just wanst sure if the lighter tires would require a diffrent spring but i do like the way the purple spring works i like rpms for hills an mud so ill try it out thanks guys
PostSubject: Re: droping tire size an adding cage extension should i change my spring    droping tire size an adding cage extension should i change my spring  Icon_minitimeWed Aug 14, 2013 5:51 pm
I like the purple,great for trails.
PostSubject: Re: droping tire size an adding cage extension should i change my spring    droping tire size an adding cage extension should i change my spring  Icon_minitimeWed Aug 14, 2013 7:40 pm
i'm running the orange spring now, what would I gain with the purple
PostSubject: Re: droping tire size an adding cage extension should i change my spring    droping tire size an adding cage extension should i change my spring  Icon_minitimeWed Aug 14, 2013 7:54 pm
Gives more low,midrange punch,better for trails with larger tires.
» Tire size?
» Question about tire size I can fit.
» best size and kind of tire on rhino
» secondary spring change
» Change to 12g OD's ??
