Info on the Controller DFS7-33
WIRE CONNECTIONS:
To insert wires into the Dynatek F.S. fi rst remove the rubber plug on the
backside of the unit and loosen the screw for the corresponding input.
Using a 22-24 gauge wire, strip about 10mm from its end. Push the wire
into the hole of the
Dynatek F.S. until is stops
and then tighten the screw.
Make sure to reinstall the
rubber plug.
NOTE: If you tin the wires
with solder it will make
inserting them easier.
DYNATEK F.S.
INPUT ACCESSORY GUIDE
NOT USED
DYNATEK F.S. MODULE INPUTS
Input 1 and input 2 are used for switches. The switches must be confi gured in the Dynatek
Control Center software.
Map: The Dynatek F.S. has the ability to hold two different base maps. You can switch on
the fl y between these two base maps when you connect a switch to input 1 or 2.
You can use any open/close type switch. The polarity of the wires is not important.
The Dynatek F.S. is compatible with Dyna Tune autotune. When using Dyna Tune
autotune, one position will hold a base map and the other position will let you
activate the learning mode. When the switch is “CLOSED” Dyna Tune autotune will
be activated. (Set to input 1 by default.)
Shifter: These inputs are for use with a Dynatek quickshifter. Insert the wires from the
Dynatek quickshifter into input 1 or 2. The polarity of the wires is not important. (Set
to input 2 by default.)
Speed: If your application has a speed sensor then you can tap into the signal side of the
sensor and run a wire into this input. This will allow you to calculate gear position
in the Dynatek Control Center software. Once gear position is setup you can alter
your map based on gear position and setup gear dependent kill times when using a
quickshifter.
Analog: This input is for a 0-5v signal such as engine temp, boost, etc. Once this input is
established you can alter your fuel curve based on this input in the Dynatek Control
Center software.
USING DYNATEK CONTROL CENTER SOFTWARE
Insert the CD provided into your computer’s cd-rom drive. The launch program will run
automatically. If auto-run is disabled, double-click the My Computer icon then double-click
the CD drive icon. Double-click Control Center.exe to manually start the CD.
Click Install Software and follow the on-screen instructions to install the Dynatek Control
Center software. The Dynatek Control Center software will be stored in C:\Program Files\
Dynatek Control Center.
Click Map Database. All maps will automatically be installed to the C:\Program Files\
Dynatek Control Center\maps folder.
Connect the USB cable from the computer to the Dynatek 3000. Verify the cable is fully
seated in the Dynatek F.S.
Run the Dynatek Control Center software by double-clicking the program icon installed on
your desktop or on your start menu. Click Open Map File and select a map fi le. Click Send
Map.
The values in the fuel table represent a percentage of fuel change over stock. A value of 10
in the table indicates at that throttle position and RPM range the vehicle will be 10% richer
than stock. A value of 10 in the ignition table indicates at that throttle position and RPM
range the ignition timing will be advanced 10 degrees from the stock timing. The Dynatek
Control Center software allows a fuel table adjustment of +250 to -100 and an ignition table
adjustment of +20 to -20 in each cell.
TROUBLESHOOTING
If the STATUS LED does not come on when the ignition is switched on, there is no power to
the Dynatek F.S. Make sure that you have the ground connected properly either directly to
the battery ground, or to a lug on the frame that is grounded.
If the LED comes on, but the vehicle does not run on all cylinders, double check all
connections at the injector, making sure the connectors are seated properly.
