buddalo
Posts : 2 Join date : 2013-10-25
| Subject: Stock 2006 450 Rhino Tue Dec 03, 2013 9:13 pm | |
| Engine starts up and idles good but at WOT it hesitates every few seconds. Has sat for over 6 months, changed the plug, fuel filter, air filter, cleaned the fuel pump and carb. Less than 2 hours on engine since Yamaha shop did complete service. Put in new CDI box still runs the same. Am I missing something? Buddie | |
moobster
Posts : 88 Join date : 2013-10-02 Age : 62 Location : Southern Ontario
| Subject: Re: Stock 2006 450 Rhino Tue Dec 03, 2013 9:34 pm | |
| Sounds fuel related to me. Cracked fuel line??? | |
| Subject: Re: Stock 2006 450 Rhino Tue Dec 03, 2013 9:59 pm | |
| If your fuel pick up and lines are OK them an electric fuel pump may be the answer. | |
| Subject: Re: Stock 2006 450 Rhino Tue Dec 03, 2013 10:13 pm | |
| If the 450 sat for 6 month there is a good chance the fuel is old in the tank. The second thought is if you're running WOT you're more than likely bouncing off the rev limiter. Put a dyna-tech CDI on the 450 and eliminate the rev limit problem, plus pick up some more top-end on your Rhino. Get with JBS and he'll fix you up with the CDI if you go that direction. Drain the old fuel put some 90+ octane fuel in there run it and see if that solves the problem, but if you're holding it WOT and it hits the rev limiter it's going to have a dead spot until the revs die down them rev back up and do it all over again.......... Got a 450 myself know how they respond. | |
moobster
| Subject: Re: Stock 2006 450 Rhino Tue Dec 03, 2013 10:32 pm | |
| Never thought about old fuel, that makes a lot of sense. Regular fuel lasts about 3 months, High test lasts about 6 months. | |
buddalo
| Subject: Re: Stock 2006 450 Rhino Wed Dec 04, 2013 1:40 pm | |
| Thanks everyone now I know what to do. The new CDI is from James and I also got his sheave. It now goes 4mph faster with more power. Buddie | |
| Subject: Re: Stock 2006 450 Rhino | |
