In total there are 20 users online :: 0 Registered, 0 Hidden and 20 Guests :: 2 Bots
James do u sell high flow fuel pump Icon_minitimeWed Aug 16, 2023 1:17 pm by RADICAL RAM
James do u sell high flow fuel pump Icon_minitimeThu Dec 14, 2017 4:54 pm by WV Hot Rod Rhino
James do u sell high flow fuel pump Icon_minitimeThu Dec 14, 2017 1:28 am by WV Hot Rod Rhino
James do u sell high flow fuel pump Icon_minitimeThu Dec 14, 2017 12:35 am by WV Hot Rod Rhino
James do u sell high flow fuel pump Icon_minitimeFri Dec 13, 2013 11:01 am by WV Hot Rod Rhino
James do u sell high flow fuel pump Icon_minitimeFri Dec 13, 2013 10:59 am by WV Hot Rod Rhino
James do u sell high flow fuel pump Icon_minitimeFri Dec 13, 2013 9:33 am by Tacoclaw
James do u sell high flow fuel pump Icon_minitimeFri Dec 13, 2013 7:50 am by chuddly
James do u sell high flow fuel pump Icon_minitimeFri Dec 13, 2013 7:47 am by chuddly
James do u sell high flow fuel pump Vote_lcapJames do u sell high flow fuel pump Voting_barJames do u sell high flow fuel pump Vote_rcap
4 posters
FLOGROWN
FLOGROWN
James do u sell high flow fuel pump Empty
PostSubject: James do u sell high flow fuel pump   James do u sell high flow fuel pump Icon_minitimeWed Sep 04, 2013 10:48 am
Was wondering if you sell high flow fuel pump for 06 660? Clear lines needed? Or do I go with the weller setup? Also do you stock the oil seal for the wet clutch drum shaft, the one that's seen on the outside of the case?
PostSubject: Re: James do u sell high flow fuel pump   James do u sell high flow fuel pump Icon_minitimeWed Sep 04, 2013 11:01 am
i have the seal...no hi flow or lines
FLOGROWN
FLOGROWN
PostSubject: Re: James do u sell high flow fuel pump   James do u sell high flow fuel pump Icon_minitimeWed Sep 04, 2013 11:20 am
Ok do u recommend the high flow? And what's the price on the seal?
PostSubject: Re: James do u sell high flow fuel pump   James do u sell high flow fuel pump Icon_minitimeWed Sep 04, 2013 11:36 am
8.00 on the seal...high flow is fine
FLOGROWN
FLOGROWN
PostSubject: Re: James do u sell high flow fuel pump   James do u sell high flow fuel pump Icon_minitimeWed Sep 04, 2013 11:38 am
Awesome, you da man as usual..
PostSubject: Re: James do u sell high flow fuel pump   James do u sell high flow fuel pump Icon_minitimeWed Sep 04, 2013 1:11 pm
Try alba for the pump.
http://www.trailbrightled.com
PostSubject: Re: James do u sell high flow fuel pump   James do u sell high flow fuel pump Icon_minitimeWed Sep 04, 2013 1:26 pm
i went with alba for the pump an it works great starts right up as soon as i hit the key.
» relocating fuel pump 660
» 660 puking coolant
» FUEL PUMP HELP
» 450 Fuel Pump
» electric fuel pump????
