| electric fuel pump???? | |
+3CUSTOMIZEDRHINO13 kronik EddieMc 7 posters |
EddieMc
| Subject: electric fuel pump???? Tue Apr 23, 2013 3:13 pm | |
| On my 08 734 should I buy an electric fuel pump? | |
kronik
Posts : 27 Join date : 2013-04-23 Location : Smoke dope, eat soap, fly high on a bubble...
| Subject: Re: electric fuel pump???? Tue Apr 23, 2013 3:48 pm | |
| Not sure what you're asking, Eddie, as you already have one... That said, with the 105.5 that you're running, the only thing you need to add is a fuel controller. | |
| Subject: Re: electric fuel pump???? Tue Apr 23, 2013 4:39 pm | |
| I like my Weller racing fuel pump with the clear fuel lines! I didn't buy an electrical one because a member mentioned that if you role it and it catches on fire you will need to be able to turn it off so you won't pump fuel on the fire. | |
kronik
| Subject: Re: electric fuel pump???? Tue Apr 23, 2013 4:46 pm | |
| CR13; That isn't an issue with Eddie's Rhino (electric), or your own (stock) system... Failsafes... | |
| Subject: Re: electric fuel pump???? Tue Apr 23, 2013 4:47 pm | |
| Oh that's pretty cool! Disregard that statement then lol | |
kronik
| Subject: Re: electric fuel pump???? Tue Apr 23, 2013 4:48 pm | |
| No worries, bro | |
| Subject: Re: electric fuel pump???? Tue Apr 23, 2013 7:23 pm | |
| - CustomizedRhino13 wrote:
- I like my Weller racing fuel pump with the clear fuel lines! I didn't buy an electrical one because a member mentioned that if you role it and it catches on fire you will need to be able to turn it off so you won't pump fuel on the fire.
On the 450 and 660 that is true, unless a rollover switch is installed.It will cut the power off to the pump not allowing it to pump fuel out. The 700s are fuel injected and come from the factory with electric fuel pumps and switch. I think Canam was having a problem with the Commanders switch, turning off the fuel when guys were pitching them sideways. | |
| Subject: Re: electric fuel pump???? Tue Apr 23, 2013 7:41 pm | |
| That's what I was remembering! When you said that last time it steered me towards the weller racing, plus some people have like 4000 miles on 'em. | |
kronik
| Subject: Re: electric fuel pump???? Tue Apr 23, 2013 8:13 pm | |
| Every Rhino ever built comes stock with a "roll over" valve... What you have to look at is how that valve functions and more so "why" the fuel would be "cut off"... It's not an "electrical" thing... | |
| Subject: Re: electric fuel pump???? Tue Apr 23, 2013 8:27 pm | |
| I was one of the people steering people away from electric fuel pumps. Electric fuel pumps are awesome if set up correctly !!!! If not, they are deadly. The majority of people I seen trying to hook them up were just hooking them to a keyed circuit with a regulator. No emergency shut off or roll over valve.
Take my word for it, there is nothing worse than seeing someone who is burnt to a crisp ! | |
| Subject: Re: electric fuel pump???? Tue Apr 23, 2013 8:29 pm | |
| I didn't want to take a chance and the weller racing fuel pump has had no problems so far! | |
Workhorserhino
| Subject: Re: electric fuel pump???? Tue Apr 23, 2013 8:33 pm | |
| Take my word for it, there is nothing worse than seeing someone who is burnt to a crisp ! X2 on that. My ex-wife's brother was burnt as a kid. 3/4 of his upperbody. I saw the scares. Terrible! | |
| - kronik wrote:
- Every Rhino ever built comes stock with a "roll over" valve... What you have to look at is how that valve functions and more so "why" the fuel would be "cut off"... It's not an "electrical" thing...
The "rollover valve" on the 450 and 660 are on the tank vent line. They are prone to fail, usually sticking open or closed. an easy way to check it to remove it shake it? You should hear the check ball moving. Im sure how Yamaha is "cutting off" the power on the 700. | |
| Subject: Re: electric fuel pump???? Tue Apr 23, 2013 8:36 pm | |
| Steve, doesn't that just keep fuel from coming out of the tank on a rollover ? | |
kronik
| Subject: Re: electric fuel pump???? Tue Apr 23, 2013 8:37 pm | |
| - Firefighter wrote:
- Take my word for it, there is nothing worse than seeing someone who is burnt to a crisp !
With a name like "firefighter", I'll take your word for that, point taken True, the carb'd units only really ever needed the electric to be "blipped" and not "on" full time... That said, the "roll over" effect on either setup would still be in play | |
kronik
| Subject: Re: electric fuel pump???? Tue Apr 23, 2013 8:38 pm | |
| - onebuilder wrote:
The "rollover valve" on the 450 and 660 are on the tank vent line. They are prone to fail, usually sticking open or closed. an easy way to check it to remove it shake it? You should hear the check ball moving. Im sure how Yamaha is "cutting off" the power on the 700. Not disagreeing with what you said or what you've implied in this message, don't get me wrong. The "cutoff" kind of works the same on all their products.... | |
Workhorserhino
| Subject: Re: electric fuel pump???? Tue Apr 23, 2013 8:43 pm | |
| According to manual, there are 2 safety's on the 700. There is a rollover valve and a lean angle sensor. I'm going to assume the rollover is check ball type. the lean angle is electrical. More than 65 degrees it it opens. I'm guessing shuts the pump off. it this helps some. | |
| Subject: Re: electric fuel pump???? Tue Apr 23, 2013 8:48 pm | |
| - Workhorserhino wrote:
- According to manual, there are 2 safety's on the 700. There is a rollover valve and a lean angle sensor. I'm going to assume the rollover is check ball type. the lean angle is electrical. More than 65 degrees it it opens. I'm guessing shuts the pump off. it this helps some.
Thanks for looking it up. Now I/we know how the 700 works. | |
| Subject: Re: electric fuel pump???? Tue Apr 23, 2013 8:57 pm | |
- Steve, doesn't that just keep fuel from coming out of the tank on a rollover ?
Yes, keeps fuel from coming out of the vent that goes into the roll cage. | |
kronik
| Subject: Re: electric fuel pump???? Tue Apr 23, 2013 9:01 pm | |
| If a single, like the Rhino, and knowing how it's oil system works, gets "inverted" for any length of time... Wouldn't you "cut it off" at certain "angles"? Y'all are missing the point on exactly "how" the fuel gets shut off I think... | |
| Subject: Re: electric fuel pump???? Tue Apr 23, 2013 9:06 pm | |
| - kronik wrote:
- If a single, like the Rhino, and knowing how it's oil system works, gets "inverted" for any length of time... Wouldn't you "cut it off" at certain "angles"?
Y'all are missing the point on exactly "how" the fuel gets shut off I think... Lol! Time for another hit of the crack pipe! The fuel will come out the tank to the carb when inverted. | |
kronik
| Subject: Re: electric fuel pump???? Tue Apr 23, 2013 9:09 pm | |
| You're starting to "get it" Umm... Minus the "crack pipe" If air can't get in, fluid can't come out | |
| Subject: Re: electric fuel pump???? Tue Apr 23, 2013 10:07 pm | |
| That makes since! Are you buds with Eddie? | |
| Subject: Re: electric fuel pump???? Tue Apr 23, 2013 10:09 pm | |
| Subject: Re: electric fuel pump???? Tue Apr 23, 2013 10:10 pm | |
| :lol!:Can I sue afterwards? | |
| Subject: Re: electric fuel pump???? | |
