Who is online? | In total there are 27 users online :: 0 Registered, 0 Hidden and 27 Guests :: 2 Bots None Most users ever online was 207 on Tue Jun 11, 2013 11:13 pm |
| | water pump | |
| Subject: water pump Sat May 04, 2013 7:16 pm | |
| OK the water pump breather hose is leaking coolant ,just wander if it could be rubber damper or water pump seal, any thoughts would help | |
| | | 123.bert0621
| Subject: Re: water pump Sat May 04, 2013 7:36 pm | |
| There are seals available to rebuild it,but it is probably a good idea to replace it,sand can score the impeller shaft,or corrosion, and you might still have a leak and its allot of work to replace. A 700 is not bad but a 660 sounds like more work. | |
| | | Stuntmanmike
| Subject: Re: water pump Sat May 04, 2013 8:16 pm | |
| Jeff rebuilding the water pump seal is easy, and make sure you get a new o ring for the outer seal. And when your done put a one way check valve on the vent hose just like the one on the carb, it will keep the dirt out so you dont have to rebuild it agian. | |
| | | rhino727
| Subject: Re: water pump Sat May 04, 2013 10:04 pm | |
| thanks Mike now where can I lay hands on a check valve that small, also no need to pull pump shaft is it ? | |
| | | Stuntmanmike
| Subject: Re: water pump Sat May 04, 2013 10:13 pm | |
| The hole water pump assy comes out with about 6 screws, And order the check valve from the yamaha carb parts break down. | |
| | | rhino727
| Subject: Re: water pump Sat May 04, 2013 10:21 pm | |
| Subject: Re: water pump | |
| | | | water pump | |
