| Doesn't like water | |
+3Yotehunter66 Clay44 LouisianaRebel 7 posters |
LouisianaRebel
Posts : 66 Join date : 2013-03-10
| Subject: Doesn't like water Sun Mar 10, 2013 6:29 pm | |
| Every time I get about carburetor deep it dies. When we pull it out the water it cranks right up. No water in airbox or oil each time.
I have everything snorkeled and all vent lines ran plus sparkplug is bone dry. Help! | |
Clay44
Posts : 40 Join date : 2013-03-10 Age : 45 Location : Texas
| Subject: Re: Doesn't like water Sun Mar 10, 2013 6:54 pm | |
| Electrical connection getting wet have you pulled all your plugs and put dielectric grease in them | |
LouisianaRebel
| Subject: Re: Doesn't like water Sun Mar 10, 2013 7:15 pm | |
| There's not really any plugs that high to make it quit. It will do it pretty much every other time I get that deep. I sat there will the pressure washer and sprayed everything while it was running and it won't even hiccup | |
Clay44
| Subject: Re: Doesn't like water Sun Mar 10, 2013 7:25 pm | |
| On my rhino 660 I have 3 plugs around my carb and one under the center hump cover | |
LouisianaRebel
| Subject: Re: Doesn't like water Sun Mar 10, 2013 7:28 pm | |
| I'll do them. Might be done already. Haha. I did find out it only has 1200 miles instead of 2000. Damn kilometers. Saved money buying it thinking 2000 miles. Haha | |
Yotehunter66 Moderator
| Subject: Re: Doesn't like water Sun Mar 10, 2013 7:32 pm | |
| Do you have the vent line from the carb rerouted? | |
LouisianaRebel
| Subject: Re: Doesn't like water Sun Mar 10, 2013 7:37 pm | |
| Yep. Plugged the drain one just incase the one way wasn't working and it still died. | |
| Subject: Re: Doesn't like water Sun Mar 10, 2013 7:44 pm | |
| Does it die like you just turned off the key, sputter some or slowly bog down? | |
| Subject: Re: Doesn't like water Sun Mar 10, 2013 8:02 pm | |
| is the coil on the driver's side of the engine getting wet? | |
| Subject: Re: Doesn't like water Sun Mar 10, 2013 8:10 pm | |
| check your exhaust for leaks or cracks......
your stator wires are next to the gas tank and by the motor,, check those and dielectric grease them.... remember a little dab will do ya with that nasty stuff.....
Thats the only thing i could think of....... | |
| Subject: Re: Doesn't like water Sun Mar 10, 2013 8:21 pm | |
| - 08Rhino450SE wrote:
- is the coil on the driver's side of the engine getting wet?
A lot of people relocate their coils if they're always in deep water. | |
LouisianaRebel
| Subject: Re: Doesn't like water Sun Mar 10, 2013 8:52 pm | |
| Starts sputtering like no gas. | |
| Subject: Re: Doesn't like water Sun Mar 10, 2013 8:54 pm | |
DesignMine
Posts : 17 Join date : 2013-03-10 Age : 54 Location : NC
| On my 660 there was a cooling fan on the passenger side that blew air to the exhaust hanger. If it gets bogged down it will stall the engine. I took mine off and never had an issue. Not sure if that is it but just a thought. | |
| Subject: Re: Doesn't like water Sun Mar 10, 2013 9:53 pm | |
| - DesignMine wrote:
- On my 660 there was a cooling fan on the passenger side that blew air to the exhaust hanger. If it gets bogged down it will stall the engine. I took mine off and never had an issue. Not sure if that is it but just a thought.
Beat me to it. I was heading in that direction if the air box was stock. Thats why I wanted to know how it was acting before it died. The sputtering part threw me. | |
LouisianaRebel
| Subject: Re: Doesn't like water Sun Mar 10, 2013 10:36 pm | |
Clay44
| Subject: Re: Doesn't like water Sun Mar 10, 2013 10:39 pm | |
| I think it's something electrical getting wet maybe your coil I would do everything with grease and make sure your carb is tight and vents have no holes rubbed in them | |
LouisianaRebel
| Subject: Re: Doesn't like water Sun Mar 10, 2013 10:43 pm | |
| Subject: Re: Doesn't like water Sun Mar 10, 2013 11:04 pm | |
| first try wrapping it with plastic and see if it works. if that eliminates the problem you'll have to relocate the coil to a higher location. | |
LouisianaRebel
| Subject: Re: Doesn't like water Sun Mar 10, 2013 11:20 pm | |
| Sounds fun. I'll see this weekend I guess. Thanks ya'll. Very helpful for a forum that's been up for a weekend. Haha | |
| Subject: Re: Doesn't like water Mon Mar 11, 2013 1:17 am | |
| My old 450 done that every time the exhaust was under water. Didn't do it when until after a couple yrs of riding. Never could figure it out. I just had to hit the deep water hard and make a big wave to keep the tailpipe from going under. It would idle good and would only take just enough throttle to move, after that it would try to die. | |
| Subject: Re: Doesn't like water Mon Mar 11, 2013 6:20 pm | |
| That sounds like back pressure. Same as if the exhaust was plugged. | |
| Subject: Re: Doesn't like water Tue Mar 12, 2013 12:15 am | |
| We just took an exhaust off and found it had a pencil size hole in it. Soaked it in water over night and beat it back right. | |
LouisianaRebel
| Subject: Re: Doesn't like water Tue Mar 12, 2013 11:14 am | |
| Ill put the muffler under and see.
I dont think it would have a hole in just the pipe right? | |
| Subject: Re: Doesn't like water | |
