| Fuel pump | |
Clay44
Posts : 40 Join date : 2013-03-10 Age : 45 Location : Texas
| Subject: Fuel pump Sun Apr 07, 2013 9:18 am | |
| Can I run your fuel pump with a stock 660? | |
| Subject: Re: Fuel pump Sun Apr 07, 2013 10:24 am | |
| I have the Alba pump on my 660. Its bored to a 673 but that's not really a lot only .5 over I don't think it will be a problem. | |
| Subject: Re: Fuel pump Sun Apr 07, 2013 10:27 am | |
| - Clay44 wrote:
- Can I run your fuel pump with a stock 660?
I ran the Mikuni pump on my 660 for years on my stock engine with no issues. I do recomend installing the fuel line kit with this pump. I'm still running the same pump and kit on my 686. | |
Mrs. Hot Rod Admin
| Subject: Re: Fuel pump Sun Apr 07, 2013 10:41 am | |
Clay44
| Subject: Re: Fuel pump Sun Apr 07, 2013 10:45 am | |
| What is the fuel line kit? | |
| Subject: Re: Fuel pump Sun Apr 07, 2013 11:01 am | |
| clear lines so you can see the fuel and the return is closer to the carb and pointed up to keep more fuel at the carb | |
| Subject: Re: Fuel pump Sun Apr 07, 2013 11:07 am | |
Clay44
| Subject: Re: Fuel pump Sun Apr 07, 2013 11:08 am | |
| Do you have this stuff James? I also need all the motor mounts | |
| Subject: Re: Fuel pump Sun Apr 07, 2013 11:15 am | |
| - Clay44 wrote:
- What is the fuel line kit?
The fuel line kit allows the dual outputs on the pump to be utilized, instead of plugging one off with a cap. The return line to the tank is larger, compensating for the additional flow. It's amazing to see how much fuel this pump actually moves. The clear lines do allow you to see the flow. Well worth the money! | |
| Subject: Re: Fuel pump Sun Apr 07, 2013 11:26 am | |
| - Clay44 wrote:
- Do you have this stuff James? I also need all the motor mounts
usually...i got more coming | |
| Subject: Re: Fuel pump | |
| Fuel pump | |
