In total there are 26 users online :: 0 Registered, 0 Hidden and 26 Guests :: 1 Bot
2007 Rhino 660 Squeak Icon_minitimeWed Aug 16, 2023 1:17 pm by RADICAL RAM
2007 Rhino 660 Squeak Icon_minitimeThu Dec 14, 2017 4:54 pm by WV Hot Rod Rhino
2007 Rhino 660 Squeak Icon_minitimeThu Dec 14, 2017 1:28 am by WV Hot Rod Rhino
2007 Rhino 660 Squeak Icon_minitimeThu Dec 14, 2017 12:35 am by WV Hot Rod Rhino
2007 Rhino 660 Squeak Icon_minitimeFri Dec 13, 2013 11:01 am by WV Hot Rod Rhino
2007 Rhino 660 Squeak Icon_minitimeFri Dec 13, 2013 10:59 am by WV Hot Rod Rhino
2007 Rhino 660 Squeak Icon_minitimeFri Dec 13, 2013 9:33 am by Tacoclaw
2007 Rhino 660 Squeak Icon_minitimeFri Dec 13, 2013 7:50 am by chuddly
2007 Rhino 660 Squeak Icon_minitimeFri Dec 13, 2013 7:47 am by chuddly
2007 Rhino 660 Squeak Vote_lcap2007 Rhino 660 Squeak Voting_bar2007 Rhino 660 Squeak Vote_rcap
Deuces wild
watrsmkr
9 posters
watrsmkr
2007 Rhino 660 Squeak Empty
PostSubject: 2007 Rhino 660 Squeak   2007 Rhino 660 Squeak Icon_minitimeTue Oct 15, 2013 7:05 pm
My 2007 Rhino 660 has a very annoying squeak when going backwards. Sometimes it sounds like it is from the front and other times from the back. I have had it upon jackstands and can't find anything!!! Someone out there have any ideas? I am about to go deaf and crazy!!!!! affraid Dancing Banana Dancing Banana Dancing Banana Dancing Banana Dancing Banana
Deuces wild
Deuces wild
PostSubject: Re: 2007 Rhino 660 Squeak   2007 Rhino 660 Squeak Icon_minitimeTue Oct 15, 2013 7:16 pm
Its not the bed us it?  My 07 use to squeak as well but it was the bed
PostSubject: Re: 2007 Rhino 660 Squeak   2007 Rhino 660 Squeak Icon_minitimeTue Oct 15, 2013 7:44 pm
Most likely the brakes. Worst case , a bearing but I'm sure there would be other signs as well, wheel play etc.
PostSubject: Re: 2007 Rhino 660 Squeak   2007 Rhino 660 Squeak Icon_minitimeTue Oct 15, 2013 8:03 pm
X2 on breaks or bearings.
PostSubject: Re: 2007 Rhino 660 Squeak   2007 Rhino 660 Squeak Icon_minitimeTue Oct 15, 2013 8:29 pm
Brakes.
PostSubject: Re: 2007 Rhino 660 Squeak   2007 Rhino 660 Squeak Icon_minitimeTue Oct 15, 2013 8:37 pm
X4 on the brakes. You can put any mfg brake pads on it ; go for a ride , next time you take off...squeak , squeak ...nature of the beast. When you back it out of the garage next time , you can two foot it ...brake n gas at the same time. Sometimes that'll shut them up.
PostSubject: Re: 2007 Rhino 660 Squeak   2007 Rhino 660 Squeak Icon_minitimeTue Oct 15, 2013 9:30 pm
we were making fun of everybody's rear brakes making noise at the forum ride.
believe it or not, i spray SC1 silicone spray all over the rear brake and pray i don't have to stop until it wears off lol.
it works pretty well, and sooner or later it rubs off the rotor bounce
PostSubject: Re: 2007 Rhino 660 Squeak   2007 Rhino 660 Squeak Icon_minitimeTue Oct 15, 2013 10:25 pm
I cleaned my rear caliber got the floater pins freed up an cleaned /greased pins new pads an the noise went away . the pins where a pain to get apart to clean now I clean an grease regular
brewis
brewis
PostSubject: Re: 2007 Rhino 660 Squeak   2007 Rhino 660 Squeak Icon_minitimeTue Oct 15, 2013 11:14 pm
Try some EBC brake pads fa428x is the pn.  Made mine stop squeeking.  They wear quicker though.
» 2007 rhino 660 18.0 af at wot
» 2007 long travel 660 rhino
» 2007 Yamaha Rhino full custom with tracks
» My 450 Rhino
» why did you buy a rhino?
