In total there are 50 users online :: 0 Registered, 0 Hidden and 50 Guests :: 1 Bot
truck question Icon_minitimeWed Aug 16, 2023 1:17 pm by RADICAL RAM
truck question Icon_minitimeThu Dec 14, 2017 4:54 pm by WV Hot Rod Rhino
truck question Icon_minitimeThu Dec 14, 2017 1:28 am by WV Hot Rod Rhino
truck question Icon_minitimeThu Dec 14, 2017 12:35 am by WV Hot Rod Rhino
truck question Icon_minitimeFri Dec 13, 2013 11:01 am by WV Hot Rod Rhino
truck question Icon_minitimeFri Dec 13, 2013 10:59 am by WV Hot Rod Rhino
truck question Icon_minitimeFri Dec 13, 2013 9:33 am by Tacoclaw
truck question Icon_minitimeFri Dec 13, 2013 7:50 am by chuddly
truck question Icon_minitimeFri Dec 13, 2013 7:47 am by chuddly
truck question Vote_lcaptruck question Voting_bartruck question Vote_rcap
 truck question
chalkminer
Crusty
RhinoGT350
11 posters
RhinoGT350
RhinoGT350
truck question Empty
PostSubject: truck question   truck question Icon_minitimeWed Nov 20, 2013 7:03 pm
ok i hoping some one can answer this. i am driving in my truck about 35 and i a bump or a dip in the road and the right front tires sort of bounces like it is up and down a bit and my steering wheel vibrates a bit. if i slow down or hit my brakes, the vibrating of my steering wheel and the up and down feeling from my right front tired will come to an end.
my tires all have proper air pressure
good tread on all tires
lug nuts all tight
no new work done in it
do you think this could be a shock absorber or strut ?
PostSubject: Re: truck question   truck question Icon_minitimeWed Nov 20, 2013 7:09 pm
tie rod end,shock
PostSubject: Re: truck question   truck question Icon_minitimeWed Nov 20, 2013 7:28 pm
Could be a tie rod or shock, what model and brand,independent or straight or mono beam, A arm or I beam?
Crusty
Crusty
PostSubject: Re: truck question   truck question Icon_minitimeWed Nov 20, 2013 7:31 pm
Could be ball joints or wheel bearings also.
PostSubject: Re: truck question   truck question Icon_minitimeWed Nov 20, 2013 7:36 pm
Could be track arm ball joint or bushing,steering damper,upper arms,control arm bushings.
Crusty
Crusty
PostSubject: Re: truck question   truck question Icon_minitimeWed Nov 20, 2013 8:05 pm
What make and model?
I know a lot of the Chevy's were having problems from 05' to around 09' with the left front wheel bearings going out all the time, not sure why it was always the left side but we have changed numerous left front hubs on our work trucks.
PostSubject: Re: truck question   truck question Icon_minitimeWed Nov 20, 2013 11:04 pm
What make , model , and yr truck ? Any lift or bigger tires ?
http://www.trailbrightled.com
RhinoGT350
RhinoGT350
PostSubject: Re: truck question   truck question Icon_minitimeThu Nov 21, 2013 12:25 am
oh sorry guys i forgot to describe my truck
2007 dodge ram 2500 diesle 4x4
6 inch lift
37" tires.
front axile is solid not a arm type
PostSubject: Re: truck question   truck question Icon_minitimeThu Nov 21, 2013 1:15 am
Have you tried jacking the front end up and seeing if there is any play in the front end ? Check track bar , wheel bearings , ball joints ( you need a big pry bar for this ) shock bushings ? Its all things everyone else had mentioned already. Don't let it go it will only get worse. It leads to death wobble which is 10x worse
chalkminer
chalkminer
PostSubject: Re: truck question   truck question Icon_minitimeThu Nov 21, 2013 1:22 am
Some times these issues are hard to track down because there is more than one factor.  It could be any one if the things mentioned here or a combination of several.  I'd jack it up and push and pull in every direction.  Have a friend move the steering wheel a little back and forth while you watch the components to see if there is any play anywhere.  Rotate the tires.  Maybe even swap the front shocks side to side.  A lot of issues are maginified by 37" tires.
RhinoGT350
RhinoGT350
PostSubject: Re: truck question   truck question Icon_minitimeThu Nov 21, 2013 2:24 am
ok thanks i will try to jack up the front end and take a good look and try to move things to see if i see anything
thanks guys, you all gave me great ideas to look into.
PostSubject: Re: truck question   truck question Icon_minitimeThu Nov 21, 2013 4:17 am
to check the track bar have someone in the truck turning the wheel back an forth with the truck on the ground(not jacked up) an look at the track bar an see if it has play. sounds like a bad track bar bushing or some bump steer im assuming it has a drop pitman arm with the lift? also check pitman an idler arm for play
PostSubject: Re: truck question   truck question Icon_minitimeThu Nov 21, 2013 6:15 am
Straight axle Rams are notorious for the suspension arm bushings going bad.  The ones in the arms that connect your axle to the frame.  If the tierod ends and balljoints check out ok, then those bushings will be the problem I bet.  I love those trucks.  Plan on having one some day.
PostSubject: Re: truck question   truck question Icon_minitimeThu Nov 21, 2013 9:27 am
There are four front end recalls on that model that should be checked, Feb/07 pitman arm,July/11 tie rods,May/10 steering box,pitman arm,Nov/13 tie rod ends, some problems have been repaired with an alignment with revised specs,shocks,steering shock,track arm,shocks,tires,tie rods and balljoints. I would have the alignment done,tires set to whats on the door,if cupped replace them,replace the front shocks,gas filled if you can.
Quadog
Quadog
PostSubject: Re: truck question   truck question Icon_minitimeThu Nov 21, 2013 9:39 am
Take those 37" tires off and put them on a Ford.  Problem solved.   lol
RhinoGT350
RhinoGT350
PostSubject: Re: truck question   truck question Icon_minitimeThu Nov 21, 2013 10:07 am
funny you say that,, i bought them off Craigslist and they were on a F250. paid $600.00 for them.
PostSubject: Re: truck question   truck question Icon_minitimeThu Nov 21, 2013 1:09 pm
Welcome to the wonderful world of Dodge front end work.
Quadog
Quadog
PostSubject: Re: truck question   truck question Icon_minitimeThu Nov 21, 2013 5:23 pm
Those Cummins are heavy.  Hard on the front end components. Run forever though.
PostSubject: Re: truck question   truck question Icon_minitimeFri Nov 22, 2013 5:20 am
Maybe I won't own one someday. lol! I'm thinking nobody builds a good truck anymore.
What is the milege when these front end parts start to take a dump?
I'm running out of trucks to hate.  Soon be riding the rhino to where I'm gonna ride.  Only thing I ever had good luck with is 70s and 80s fords and chevys, and pre 95 Toyotas.  My 05 Tacoma was a great truck til it took a dump on me, and two dealerships gave up on fixing it after a ton of money wasted on it.
They say a good off road rig is built not bought.  I'm starting to think a street truck is the same.  Fix all the weak links just to get to work and back on the pavement.
PostSubject: Re: truck question   truck question Icon_minitimeFri Nov 22, 2013 10:09 am
I agree , if or when my 7.3 power stroke goes out I will check out putting Cummings in have read were a few have done this an seems to like the swap
truck question
» First Truck!!!!
» nitro truck
» 450 question
» GPS question
HOTRODRHINOFORUMS.COM :: Other Off-Road, UTV, and Watersports Discussion :: Trucks, Tow Rigs, RV's and Camping-
