In total there are 32 users online :: 0 Registered, 0 Hidden and 32 Guests :: 2 Bots
2" cfm lift - Page 2 Icon_minitimeWed Aug 16, 2023 1:17 pm by RADICAL RAM
2" cfm lift - Page 2 Icon_minitimeThu Dec 14, 2017 4:54 pm by WV Hot Rod Rhino
2" cfm lift - Page 2 Icon_minitimeThu Dec 14, 2017 1:28 am by WV Hot Rod Rhino
2" cfm lift - Page 2 Icon_minitimeThu Dec 14, 2017 12:35 am by WV Hot Rod Rhino
2" cfm lift - Page 2 Icon_minitimeFri Dec 13, 2013 11:01 am by WV Hot Rod Rhino
2" cfm lift - Page 2 Icon_minitimeFri Dec 13, 2013 10:59 am by WV Hot Rod Rhino
2" cfm lift - Page 2 Icon_minitimeFri Dec 13, 2013 9:33 am by Tacoclaw
2" cfm lift - Page 2 Icon_minitimeFri Dec 13, 2013 7:50 am by chuddly
2" cfm lift - Page 2 Icon_minitimeFri Dec 13, 2013 7:47 am by chuddly
2" cfm lift - Page 2 Vote_lcap2" cfm lift - Page 2 Voting_bar2" cfm lift - Page 2 Vote_rcap
 2" cfm lift
RHINOMOON
sugarbear
skeeter9
watrsmkr
Quadog
meats
16 posters
Go to page : Previous  1, 2
meats
meats
2" cfm lift - Page 2 Empty
PostSubject: Re: 2" cfm lift   2" cfm lift - Page 2 Icon_minitimeFri May 10, 2013 8:39 am
yes it measures that to the bottom of the hitch with the 27's i have no rubs and it is stiffer but it is not as bad of a ride as one would think. with the spacers in the rear it leveled the rear to same as the front so i have two left over if something were to happen to the rears
brewis
brewis
PostSubject: Re: 2" cfm lift   2" cfm lift - Page 2 Icon_minitimeSat May 18, 2013 12:07 pm
Did you guys cut the shock mount support to put the cfm kit on? There is a support on the frame above and of the rear shock mount.
brewis
brewis
PostSubject: Re: 2" cfm lift   2" cfm lift - Page 2 Icon_minitimeWed May 29, 2013 2:20 pm
2" cfm lift - Page 2 05181310Here's a picture. Notice the support on top of the frame forward of the mount bracket where the cfm bracket goes. Has anyone encountered this and do sport shocks make a difference? Thanks
PostSubject: Re: 2" cfm lift   2" cfm lift - Page 2 Icon_minitimeWed May 29, 2013 4:34 pm
The lift goes inside the hole and clamps on the back side of the bracket. Not the front.
PostSubject: Re: 2" cfm lift   2" cfm lift - Page 2 Icon_minitimeWed May 29, 2013 4:41 pm
This is not mine, but it's like this..........
2" cfm lift - Page 2 D15b6bab-fd5f-2776
brewis
brewis
PostSubject: Re: 2" cfm lift   2" cfm lift - Page 2 Icon_minitimeWed May 29, 2013 5:36 pm
Okay, thanks guys, I'll try it.
PostSubject: Re: 2" cfm lift   2" cfm lift - Page 2 Icon_minitimeWed May 29, 2013 5:58 pm
The next question is which way are You going to mount the front ones......
Here is how must people mount them.....
2" cfm lift - Page 2 IMG_5429_zps2a76ba99
Mine came without instruction and I'm a little redneck so I mounted mine like this....
2" cfm lift - Page 2 Img_0210
All You have to do is switch sides. Which way is correct ? Don't have a clue, but if I was guessing, I would say Chris put His on the right way. Does it matter ? Don't have a clue there either. lol
PostSubject: Re: 2" cfm lift   2" cfm lift - Page 2 Icon_minitimeWed May 29, 2013 6:08 pm
Firefighter is right.
tit for tat
I'm not real sure it matters how you mount the front.
PostSubject: Re: 2" cfm lift   2" cfm lift - Page 2 Icon_minitimeWed May 29, 2013 7:45 pm
mine came with grooves cut inside to fit the stock mounting area on the a arms... The top pic is correct... question is, does it work both ways?????
PostSubject: Re: 2" cfm lift   2" cfm lift - Page 2 Icon_minitimeWed May 29, 2013 8:15 pm
Mine has the grooves also. And they fit like a glove, just probably on the wrong side. HAHAHA
RHINOMOON
RHINOMOON
PostSubject: Re: 2" cfm lift   2" cfm lift - Page 2 Icon_minitimeThu May 30, 2013 9:08 pm
how you mounted them (bottom pik) is how i did it. it just makes more sence if you think about the geomitry.
PostSubject: Re: 2" cfm lift   2" cfm lift - Page 2 Icon_minitimeThu May 30, 2013 10:07 pm
might make sence, but check your for the grooves...might be pushing your axles to much with it higher...
2" cfm lift
» 3" lift
» Lift or Mid-Travel?
» Rear lift question
» extreme products 3" lift
» anyone running a 2" lift on a sport model with resi shocks
