In total there are 14 users online :: 0 Registered, 0 Hidden and 14 Guests :: 1 Bot
trans binding  Icon_minitimeWed Aug 16, 2023 1:17 pm by RADICAL RAM
trans binding  Icon_minitimeThu Dec 14, 2017 4:54 pm by WV Hot Rod Rhino
trans binding  Icon_minitimeThu Dec 14, 2017 1:28 am by WV Hot Rod Rhino
trans binding  Icon_minitimeThu Dec 14, 2017 12:35 am by WV Hot Rod Rhino
trans binding  Icon_minitimeFri Dec 13, 2013 11:01 am by WV Hot Rod Rhino
trans binding  Icon_minitimeFri Dec 13, 2013 10:59 am by WV Hot Rod Rhino
trans binding  Icon_minitimeFri Dec 13, 2013 9:33 am by Tacoclaw
trans binding  Icon_minitimeFri Dec 13, 2013 7:50 am by chuddly
trans binding  Icon_minitimeFri Dec 13, 2013 7:47 am by chuddly
trans binding  Vote_lcaptrans binding  Voting_bartrans binding  Vote_rcap
 trans binding
4 posters
trans binding  Empty
PostSubject: trans binding    trans binding  Icon_minitimeMon Mar 25, 2013 4:12 pm
I went out today to plow the driveway and the trans wont shift correctly. It is binding were you have to sometimes rock the rhino to get it to shift. I havent pulled the cover to check the sheave yet but before I do what should I be looking for ?
It also seems to want to move at idle.
http://www.trailbrightled.com
trans binding  Empty
PostSubject: Re: trans binding    trans binding  Icon_minitimeMon Mar 25, 2013 4:18 pm
nothing with the shift linkage is there
trans binding  Empty
PostSubject: Re: trans binding    trans binding  Icon_minitimeMon Mar 25, 2013 4:23 pm
idling to high or wet clutch not dis engaging ?
trans binding  Empty
PostSubject: Re: trans binding    trans binding  Icon_minitimeMon Mar 25, 2013 4:37 pm
check idle..wet clutch or one way..sheaves wont make it move at idle
trans binding  Empty
PostSubject: Re: trans binding    trans binding  Icon_minitimeMon Mar 25, 2013 4:55 pm
Idle is low and I was thinking wet clutch because I had to rock it back and forth to get it to shift.
It stalled a few times and when I went to start it acted like it wanted to move. Looks like I'll be puling it apart this week.
trans binding  Empty
PostSubject: Re: trans binding    trans binding  Icon_minitimeMon Mar 25, 2013 4:56 pm
something happened to the one way im thinking
trans binding  Empty
PostSubject: Re: trans binding    trans binding  Icon_minitimeMon Mar 25, 2013 4:59 pm
ok , do you have any videos on the oneway ?
trans binding  Empty
PostSubject: Re: trans binding    trans binding  Icon_minitimeMon Mar 25, 2013 5:02 pm
i will make on when i do my slug kit tonight
trans binding  Empty
PostSubject: Re: trans binding    trans binding  Icon_minitimeMon Mar 25, 2013 5:07 pm
Thanks
trans binding  Empty
Could the super cold cause the one way bearing to seize ? Especially if it has a little moisture on it.
trans binding  Empty
PostSubject: Re: trans binding    trans binding  Icon_minitimeMon Mar 25, 2013 5:20 pm
the spring gets weak and they just wear out every 1500 to 5000 ....lol..depends on ridn style
trans binding  Empty
PostSubject: Re: trans binding    trans binding  Icon_minitimeMon Mar 25, 2013 5:39 pm
Firefighter it's not that cold, I really didnt need to plow the driveway. I plowed more snow out in the field because I hadn't got to use it this winter. Laughing
And my riding style is either on the gas or off . plus I bought the Rhino used and dont know how it was treated before I got it.
trans binding  Empty
PostSubject: Re: trans binding    trans binding  Icon_minitimeMon Mar 25, 2013 5:46 pm
oil changes is the life of them....dirty oil eats stators too..
trans binding  Empty
PostSubject: Re: trans binding    trans binding  Icon_minitimeMon Mar 25, 2013 5:51 pm
Ahhhh. And I guess the one way runs in oil anyway.
trans binding  Empty
PostSubject: Re: trans binding    trans binding  Icon_minitimeMon Mar 25, 2013 5:53 pm
Oil is new , I just bored it and put a new piston in less then 15 hrs ago , changed the oil and used Yamalube performance all purpose 10w-40
trans binding  Empty
trans binding
» Trans or bearing?
