Dizzledog1
| Subject: Trans or bearing? Tue Apr 02, 2013 1:06 pm | |
| Rough shifting in and out of gears. Wants to jump then grind sometime before it goes in gear. One way bearing or shifter linkage? | |
| Subject: Re: Trans or bearing? Tue Apr 02, 2013 1:13 pm | |
Dizzledog1
| Subject: Re: Trans or bearing? Tue Apr 02, 2013 1:18 pm | |
| I've never messed with idle and it didn't do it when I bought it just started a few rides ago. It's got 1200 mile on it is that bout normal life of one way bearing? | |
Rootin'Rhino
Posts : 27 Join date : 2013-03-24 Age : 39 Location : East Texas
| Subject: Re: Trans or bearing? Tue Apr 02, 2013 5:09 pm | |
| I have 1300 miles on mine with no problem yet, and I've run 27" s/w outlaws since new. | |
| Subject: Re: Trans or bearing? Tue Apr 02, 2013 5:10 pm | |
| I've got 4,200 miles and never messed with it. | |
Yotehunter66 Moderator
| Subject: Re: Trans or bearing? Tue Apr 02, 2013 6:52 pm | |
| Start with the idle first that is easy. Then like James said check into your one way bearing. | |
Snorhino
| Subject: Re: Trans or bearing? Tue Apr 02, 2013 9:06 pm | |
| Had a similar problem, mine was idle | |
| Subject: Re: Trans or bearing? | |
