| Busted Wheel Bearing | |
+8REDRHINO64 T.Rhino 123.bert0621 CaptainEER CUSTOMIZEDRHINO13 WV Hot Rod Rhino Firefighter Mrs. Hot Rod 12 posters |
Mrs. Hot Rod Admin
| Subject: Busted Wheel Bearing Mon Jun 10, 2013 12:23 pm | |
| Had a bad vibration that started at the end of our last ride ... jacked it up & checked everything ... but the wheel didn't wobble or have any play. So we started out on our ride this past Saturday and figured out real quick the DS front wheel bearing was busted. | |
| Subject: Re: Busted Wheel Bearing Mon Jun 10, 2013 12:29 pm | |
| WOW ! I guess sense all or most of the pieces were there is why it didn't wobble when You had it jacked up.
I got a Buddy named James that sells them if You need one...........lol | |
| Subject: Re: Busted Wheel Bearing Mon Jun 10, 2013 12:34 pm | |
| Subject: Re: Busted Wheel Bearing Mon Jun 10, 2013 12:35 pm | |
| Were you still able to ride? | |
CaptainEER
Posts : 21 Join date : 2013-04-16 Age : 45 Location : Grafton Wv
| Subject: Re: Busted Wheel Bearing Mon Jun 10, 2013 1:12 pm | |
| Ouch....How often should these wheel bearings be changed? | |
| Subject: Re: Busted Wheel Bearing Mon Jun 10, 2013 2:00 pm | |
| I am checking them all the time,it seems every year one has to be replaced but to be fair they are not OEM, maybe I should go back? Alballs in it now. | |
| Subject: Re: Busted Wheel Bearing Mon Jun 10, 2013 2:38 pm | |
| - CustomizedRhino13 wrote:
- Were you still able to ride?
nope. ..had to get it to the road and go get a truck and trailer... | |
| Subject: Re: Busted Wheel Bearing Mon Jun 10, 2013 3:21 pm | |
| - CaptainEER wrote:
- Ouch....How often should these wheel bearings be changed?
it matters what type of conditions you ride in. Mud and water will shorten the life of them. | |
| Subject: Re: Busted Wheel Bearing Mon Jun 10, 2013 6:31 pm | |
| Front wheel bearings went out from riding wheelies!!!! | |
| Subject: Re: Busted Wheel Bearing Mon Jun 10, 2013 6:51 pm | |
| - RENEGADE64 wrote:
- Front wheel bearings went out from riding wheelies!!!!
or what comes after the wheelies....hitting the ground with a big o redneck in it....HAHA | |
| Subject: Re: Busted Wheel Bearing Mon Jun 10, 2013 10:20 pm | |
| with my terminators, I got thru a set of AllBalls bearings about every 4 months... if I Knew for a fact OEM would last longer I would spend the extra cash... | |
| Subject: Re: Busted Wheel Bearing Mon Jun 10, 2013 11:34 pm | |
| Any special ways to check these James I've shook and pulled on mine and spun them jacked up and no vibration but my wheels are cocked a bit {at least it looks like it} but I've been keeping an eye on them about 2000 miles on the rhiner. | |
| Subject: Re: Busted Wheel Bearing Mon Jun 10, 2013 11:37 pm | |
| - KJrhino wrote:
- Any special ways to check these James I've shook and pulled on mine and spun them jacked up and no vibration but my wheels are cocked a bit {at least it looks like it} but I've been keeping an eye on them about 2000 miles on the rhiner.
thats prolly from the shocks sagging....turn them up a click or two | |
| Subject: Re: Busted Wheel Bearing Tue Jun 11, 2013 8:30 am | |
| - banchee6 wrote:
- with my terminators, I got thru a set of AllBalls bearings about every 4 months... if I Knew for a fact OEM would last longer I would spend the extra cash...
I've ran both before and I have noticed the oem to last atleast twice as long I will never go back to allballs brand. | |
| Subject: Re: Busted Wheel Bearing Tue Jun 11, 2013 8:39 am | |
| - T.Rhino wrote:
I've ran both before and I have noticed the oem to last atleast twice as long I will never go back to allballs brand. x2 !!...the only time I'll run the cheap ones , is if I am out of oe ones ; and , I don't have time to drive to Beckley before the ride. Usually get 5-700 out of the cheapo's...have 2k on the rear oe ones !! | |
| Subject: Re: Busted Wheel Bearing Sun Jun 16, 2013 12:16 am | |
| Subject: Re: Busted Wheel Bearing Sun Jun 16, 2013 2:38 am | |
| I wouldn't be upset if mine went any day now. I only have 900 miles on it, but I've hit all kinds of stuff at 40+ in a turn and almost wrecked. Pure abuse...I can't believe one of the front wheels ain't fell off yet. | |
| Subject: Re: Busted Wheel Bearing | |
