| Help!! Sheave wanting to back spin | |
sugarbear
Posts : 105 Join date : 2013-03-11 Location : slc, utah
| Subject: Help!! Sheave wanting to back spin Mon Mar 25, 2013 8:15 pm | |
| Well I slugged my clutch. while putting it back together made sure the one way was facing the right way green dot towards me. got it all back together and it seems to want to go back wards in high gear and i can't find neutral on the dash doesn't light up. I thought ok well i did install the one way backwards so tore it back down and its the right way. so now i am lost and need some help on this one guys. | |
| Subject: Re: Help!! Sheave wanting to back spin Mon Mar 25, 2013 8:35 pm | |
| There is nothing in the wet clutch, including the one-way, that will make the machine go backwards in any of the forward gear settings. From what you are describing there would seem to be something going on regarding the shift linkage. | |
| Subject: Re: Help!! Sheave wanting to back spin Tue Mar 26, 2013 12:14 pm | |
| So do You think it is the one way bearing? | |
Quadog
| Subject: Re: Help!! Sheave wanting to back spin Tue Mar 26, 2013 1:07 pm | |
| The belt is on backwards. | |
sugarbear
| Subject: Re: Help!! Sheave wanting to back spin Tue Mar 26, 2013 1:58 pm | |
| ya talked with james last night he thinks its the one way, cause when i pulled the cover off it dropped and they are tempermental. The good out of this is I saw the updated sheave video and am now taking all my new grease out and grinding a bit off that webbing so the 700 camplate fits better. also getting my light bar installed and if my lift would ever get here I would put that on. hoping the one way gets here by thursday or friday so i can get a ride in before i work this weekend. | |
sugarbear
| Subject: Re: Help!! Sheave wanting to back spin Fri Mar 29, 2013 10:02 pm | |
| Replaced one way and Walla she is running right again. While I had it apart ground down the secondary Orange spring so it turned smoothly it was binding pretty bad. Can't wait to get to some rocks and see how slugging the clutch does. | |
| Subject: Re: Help!! Sheave wanting to back spin Fri Mar 29, 2013 10:03 pm | |
| Subject: Re: Help!! Sheave wanting to back spin | |
