In total there are 9 users online :: 0 Registered, 0 Hidden and 9 Guests :: 2 Bots
Hard to start Icon_minitimeWed Aug 16, 2023 1:17 pm by RADICAL RAM
Hard to start Icon_minitimeThu Dec 14, 2017 4:54 pm by WV Hot Rod Rhino
Hard to start Icon_minitimeThu Dec 14, 2017 1:28 am by WV Hot Rod Rhino
Hard to start Icon_minitimeThu Dec 14, 2017 12:35 am by WV Hot Rod Rhino
Hard to start Icon_minitimeFri Dec 13, 2013 11:01 am by WV Hot Rod Rhino
Hard to start Icon_minitimeFri Dec 13, 2013 10:59 am by WV Hot Rod Rhino
Hard to start Icon_minitimeFri Dec 13, 2013 9:33 am by Tacoclaw
Hard to start Icon_minitimeFri Dec 13, 2013 7:50 am by chuddly
Hard to start Icon_minitimeFri Dec 13, 2013 7:47 am by chuddly
Hard to start Vote_lcapHard to start Voting_barHard to start Vote_rcap
 Hard to start
5 posters
Hard to start Empty
PostSubject: Hard to start   Hard to start Icon_minitimeSun Apr 14, 2013 4:25 pm
I installed the stage 2 cam n msd recently. When it cold, it pops right off. Let it sit for an hour or so, it really hard to start n sometimes backfires. Any ideas????
Here's when it's cold....
https://youtu.be/AKOffMdXXXQ
This after it sat for 2 hrs.....
https://youtu.be/jYbsJS-u2ho
And sometimes it's worse than that. Sometimes it take a few times of spinning over to start. Thanks for the help.
Hard to start Empty
PostSubject: Re: Hard to start   Hard to start Icon_minitimeSun Apr 14, 2013 4:39 pm
Are you sure you got it back in time right or the valves adjust correctly.
Hard to start Empty
PostSubject: Re: Hard to start   Hard to start Icon_minitimeSun Apr 14, 2013 5:59 pm
From what I checked yes. I marked the timing chain and cam gear and rechecked the flywheel and valve cover after installed. Everything lines up just as stock.
Hard to start Empty
PostSubject: Re: Hard to start   Hard to start Icon_minitimeSun Apr 14, 2013 6:34 pm
Did you get the decompression pin reinstalled correctly.
Hard to start Empty
PostSubject: Re: Hard to start   Hard to start Icon_minitimeSun Apr 14, 2013 7:55 pm
Are you doing anything different with the choke, to account for the differing engine temperatures ? What happens when you immediately re-start after it warms up ?
Hard to start Empty
PostSubject: Re: Hard to start   Hard to start Icon_minitimeSun Apr 14, 2013 9:16 pm
Efi and all parts were installed correctly.
Workhorserhino
Workhorserhino
Hard to start Empty
PostSubject: Re: Hard to start   Hard to start Icon_minitimeSun Apr 14, 2013 9:30 pm
As a general guideline, backfire=timing retarded to far. exhaust valve still open. glowing exhaust= timing advanced, burning not complete. Or the controller allows to much fuel.
Hard to start Empty
PostSubject: Re: Hard to start   Hard to start Icon_minitimeSun Apr 14, 2013 10:09 pm
The thing that I am sort of focusing on is that the difference might have to do with the temperature of the engine/engine compartment based on your description. That would suggest that someting is going on with the fuel. What about when you immediately restart from shutdown, after those times that it starts well from cold conditions? I.e.: Cold=good, Lukewarm=bad, Hot=??
I certainly am not well versed on the EFI setup on the newer Rhinos. I gather that this is the first time that you have had the MSD on it? You might consider taking that back off for the time being, to get the EFI system back the way it was. Kind of a divide and conquer approach.
Hard to start Empty
PostSubject: Re: Hard to start   Hard to start Icon_minitimeSun Apr 14, 2013 10:11 pm
I'm not an efi guy at all. I did look at the msd in action on the laptop but have not clue what it's doing. I know it's rich on low end cause it takes forever to warm up according to the msd. Just kinda stumped. I'm going to check the valves tomorrow just to make sure. Just don't understand how it pops off quick and then hours later it does that sorta thing.
Hard to start Empty
PostSubject: Re: Hard to start   Hard to start Icon_minitimeSun Apr 14, 2013 11:45 pm
Hmmm, I wonder if it uses a temp sensor somewhere to look at, in order to know when to richen for cold starts and all of that?
I've always been a bit leary of a few lines of code running the show. I do too many typos myself to have the faith, eh?
Hard to start Empty
PostSubject: Re: Hard to start   Hard to start Icon_minitimeMon Apr 15, 2013 10:04 am
There is a temp sensor in the air box. I wonder if I have some oil on it from the over flow from the valve cover breather. Never got my siphon break yet.
Never really ran it hard but maybe twice. I don't drive it fast at all.
Hard to start Empty
PostSubject: Re: Hard to start   Hard to start Icon_minitimeMon Apr 15, 2013 10:46 am
call me
Hard to start Empty
Hard to start
» engine is hard to start after big bore install
» 05 660 dies when trying to start
» Forum off to a great start
» no neutral light, no start. no ground?
» Start a tips and tricks sticky thingy?
