| engine is hard to start after big bore install | |
+6banchee6 09-rhino700 CamoRhino660 REDRHINO64 ChrisH banshee_317 10 posters |
banshee_317
Posts : 11 Join date : 2013-03-10
| Subject: engine is hard to start after big bore install Tue Aug 20, 2013 10:00 pm | |
| I have a 09 700 just installed a alba 734 big bore.i have to hold my hand over the throttle body to make it start.Plus it turns over hard and kicks back.any ideas.my other mods are thanks mike Hot cam stage 2 K&n air filter exhaust end cap removed 25in mudlite tires hot rod sheeve msd charge | |
| Subject: Re: engine is hard to start after big bore install Tue Aug 20, 2013 10:09 pm | |
| Did you get the cam decompression mechanism installed properly. It can be a pain. | |
| Subject: Re: engine is hard to start after big bore install Tue Aug 20, 2013 10:11 pm | |
| yep,easy to get decompression in backwards... | |
banshee_317
| Subject: Re: engine is hard to start after big bore install Tue Aug 20, 2013 10:15 pm | |
| yea decompression is working I installed the cam a year ago and it has worked fine.till i installed the big bore | |
| Subject: Re: engine is hard to start after big bore install Tue Aug 20, 2013 10:17 pm | |
| Well, then I might venture that your timing might be off by a tooth??? Mine cranks over easy, even with a low battery and a heathy 11:1 piston. | |
CamoRhino660
| Subject: Re: engine is hard to start after big bore install Tue Aug 20, 2013 10:22 pm | |
| I have had this same problem on my 660 since my new motor. Just thought the higher compression made it harder to start. Now it's lookin like I have problems? Help us out hear guys. | |
banshee_317
| Subject: Re: engine is hard to start after big bore install Tue Aug 20, 2013 10:27 pm | |
| i have adjusted my timing both ways with no help. | |
| Subject: Re: engine is hard to start after big bore install Tue Aug 20, 2013 10:29 pm | |
| when u put the decompression pin in the cam...the pin should go in when you move the weights out on the cam,when the cam is at rest with the fly weights installed the pin should stick out. | |
| Subject: Re: engine is hard to start after big bore install Tue Aug 20, 2013 10:30 pm | |
| Timing wont help if the decompression pin is installed wrong. | |
CamoRhino660
| Subject: Re: engine is hard to start after big bore install Tue Aug 20, 2013 10:34 pm | |
| I need some help I guess..... Anyone live in central ohio that's good with these motors!?!? Lol | |
banshee_317
| Subject: Re: engine is hard to start after big bore install Tue Aug 20, 2013 11:09 pm | |
| I gave up on it for the night. I will pull the cam tomorrow after work and see if its right. | |
| Subject: Re: engine is hard to start after big bore install Wed Aug 21, 2013 12:04 am | |
| go on you tube and search for: raptor 700 can install.... there is a part 1 and a part 2, it helped me.... hope you get it man. | |
| Subject: Re: engine is hard to start after big bore install Wed Aug 21, 2013 7:33 am | |
| I have the same issue with mine. Cold starts it fires right off. Once it's at running temp, it spins about 5-10 seconds before it bearly fires off. And it did this before and after cam install. | |
banshee_317
| Subject: Re: engine is hard to start after big bore install Wed Aug 21, 2013 9:40 pm | |
| turns out the decompression pin was installed right. the spring was unhooked from the wieght so it was holding the pin in. fires right up now. | |
| Bam! Glad you got it fixed. Good job! | |
| Subject: Re: engine is hard to start after big bore install Wed Aug 21, 2013 10:00 pm | |
| Subject: Re: engine is hard to start after big bore install Thu Aug 22, 2013 8:03 am | |
| Subject: Re: engine is hard to start after big bore install Thu Aug 22, 2013 8:06 am | |
| Phew! | |
| Subject: Re: engine is hard to start after big bore install Thu Aug 22, 2013 8:24 am | |
CamoRhino660
| Subject: Re: engine is hard to start after big bore install Thu Aug 22, 2013 8:36 pm | |
| I still need help! James how much would you charge me if I dropped off my rig and you go threw the motor and fix it and tune it for me? | |
| Subject: Re: engine is hard to start after big bore install Thu Aug 22, 2013 9:12 pm | |
| Subject: Re: engine is hard to start after big bore install Sat Aug 31, 2013 2:17 pm | |
| nice glad ya got it | |
| Subject: Re: engine is hard to start after big bore install Sat Aug 31, 2013 4:08 pm | |
| - CamoRhino660 wrote:
- I still need help! James how much would you charge me if I dropped off my rig and you go threw the motor and fix it and tune it for me?
That's exactly what you need to do,then you will be ready to ride! | |
| Subject: Re: engine is hard to start after big bore install Sun Sep 01, 2013 1:23 am | |
| It may be the only way to get those hard earned ponies freed up. | |
| Subject: Re: engine is hard to start after big bore install | |
