In total there are 31 users online :: 0 Registered, 0 Hidden and 31 Guests :: 2 Bots
carg settings Icon_minitimeWed Aug 16, 2023 1:17 pm by RADICAL RAM
carg settings Icon_minitimeThu Dec 14, 2017 4:54 pm by WV Hot Rod Rhino
carg settings Icon_minitimeThu Dec 14, 2017 1:28 am by WV Hot Rod Rhino
carg settings Icon_minitimeThu Dec 14, 2017 12:35 am by WV Hot Rod Rhino
carg settings Icon_minitimeFri Dec 13, 2013 11:01 am by WV Hot Rod Rhino
carg settings Icon_minitimeFri Dec 13, 2013 10:59 am by WV Hot Rod Rhino
carg settings Icon_minitimeFri Dec 13, 2013 9:33 am by Tacoclaw
carg settings Icon_minitimeFri Dec 13, 2013 7:50 am by chuddly
carg settings Icon_minitimeFri Dec 13, 2013 7:47 am by chuddly
carg settings Vote_lcapcarg settings Voting_barcarg settings Vote_rcap
 carg settings
5 posters
txgrown1404
txgrown1404
carg settings Empty
PostSubject: carg settings   carg settings Icon_minitimeTue Apr 16, 2013 1:10 am
when dealing with carg tuning, what are they talking about "slide cutaway"? and can anyone tell me what the staock jet settings are ona 660? bc i found these numbers written down in the back of the service manual that came with it..
main 170 - i have changed that now to a 165
55 - taking thats the pilot jet which is now a 50
27.5 not sure???????????????
80 little one on side not sure either
9:1 686 102mm bore
uni filter billet adapter
2 brothers duals
utv machined sheave 14g weights i know i have to get a new jbs one saving money for that
still running richer from looking at my spark plug. using mikuni jets have a few pilots on order and i have a full main jet kit. seems to be idling good a/f meter reads 12.4-12.6 drops to 11.3-11.6 on acceleration then goes up to 12.3-12.4 at wot. and i ruuning around 200-210 degrees any help with that would be good too.
carg settings Empty
PostSubject: Re: carg settings   carg settings Icon_minitimeTue Apr 16, 2013 9:19 am
go one more smaller on the main
carg settings Empty
PostSubject: Re: carg settings   carg settings Icon_minitimeTue Apr 16, 2013 10:37 am
stock settings for a 2006 660...
carg settings 06_66010
carg settings Empty
PostSubject: Re: carg settings   carg settings Icon_minitimeTue Apr 16, 2013 1:31 pm
The slide cutaway is a cut away view of the carbs internals, to give you a better idea of how a carb actually flows fuel and air and how and were they mix together. It sounds like the numbers you found in the back of your manual is what the previous owner set the carb to after going to the 686 piston. You need to read the spark plug along with seat of the pants feel to get your carb tuned right. of coarse if you were to get an A/F ratio gauge installed it would make it alot easeier. Good luck.
txgrown1404
txgrown1404
carg settings Empty
PostSubject: Re: carg settings   carg settings Icon_minitimeTue Apr 16, 2013 5:43 pm
i have an a/f gauge and i for got to add that i removed the supercharger that was on it too.
txgrown1404
txgrown1404
carg settings Empty
PostSubject: Re: carg settings   carg settings Icon_minitimeTue Apr 16, 2013 5:44 pm
so will that help it run alittle cooler? i thought that i read where when running rich you run alittle hotter, is that true?
carg settings Empty
PostSubject: Re: carg settings   carg settings Icon_minitimeTue Apr 16, 2013 10:15 pm
Lean is hot .
txgrown1404
txgrown1404
carg settings Empty
PostSubject: Re: carg settings   carg settings Icon_minitimeTue Apr 16, 2013 11:11 pm
so what can i do to make it run alittle cooler running around 210 and its only in the low 80's now can imagine what it will be like when its 110 out
carg settings Empty
PostSubject: Re: carg settings   carg settings Icon_minitimeTue Apr 16, 2013 11:19 pm
Question for Ya. Does it only run that high when running hard, say above 20 to 30 mph ?
txgrown1404
txgrown1404
carg settings Empty
PostSubject: Re: carg settings   carg settings Icon_minitimeTue Apr 16, 2013 11:21 pm
yes it runs hot all the time not just when hard riding
carg settings Empty
PostSubject: Re: carg settings   carg settings Icon_minitimeTue Apr 16, 2013 11:25 pm
OK Had an idea if that was the problem.
txgrown1404
txgrown1404
carg settings Empty
PostSubject: Re: carg settings   carg settings Icon_minitimeTue Apr 16, 2013 11:29 pm
does adjusting the valves help at all ? should i look into getting fan shroud? i really dont want to get a bigger radiator.
carg settings Empty
PostSubject: Re: carg settings   carg settings Icon_minitimeTue Apr 16, 2013 11:32 pm
There are a dozen things that could help, but the most important ones are probably SUPER clean radiator and proper fan function ! I hear the shrouds help a bunch too.
carg settings Empty
PostSubject: Re: carg settings   carg settings Icon_minitimeTue Apr 16, 2013 11:36 pm
just lookin at the air fuel mixture you put up there and its a little rich
carg settings Empty
PostSubject: Re: carg settings   carg settings Icon_minitimeWed Apr 17, 2013 12:05 pm
If you spray down the radiator with diluted Aluminum brite it will clean it like brand new, The spot most often over looked is the area right behind the oil cooler. I now cut the metal hose and install a 4 inch rubber hose so the oil cooler can be moved out of the way to properly clean the Rad, It works great.
carg settings Empty
PostSubject: Re: carg settings   carg settings Icon_minitimeWed Apr 17, 2013 12:12 pm
After I installed my winch, I removed the metal radiator guard. This has totally changed the temp. of my machine. Now I can run WOT and not get over 190.
It also allows for very easy radiator cleaning !
carg settings Img_0218
txgrown1404
txgrown1404
carg settings Empty
PostSubject: Re: carg settings   carg settings Icon_minitimeWed Apr 17, 2013 6:09 pm
thanks guys imma try cleaning my radiator and see if that helps
txgrown1404
txgrown1404
carg settings Empty
PostSubject: Re: carg settings   carg settings Icon_minitimeWed Apr 17, 2013 7:12 pm
can u post a pic of that
carg settings Empty
carg settings
» Torque settings
» valve settings for raptor stage 1 cam on a 660
» Yamaha Rhino Factory Sport Shock Settings & Hot Rod's Tips.
