| Rubber down custom 2" lift install | |
+9Jet T.Rhino flimmy CUSTOMIZEDRHINO13 madmax 1 REDRHINO64 Hump Firefighter Workhorserhino 13 posters |
Workhorserhino
| Subject: Rubber down custom 2" lift install Thu Apr 18, 2013 10:32 pm | |
| Installing a RDC 2" lift. Very nicely finished kit. Front lift brackets. I guess your gonna view this in reverse order till I figure out to put pics in order. Antiseize all bolts. Both brackets and shock, all bolts loose yet. Left and right frt axles with suspension hanging. Right frt just touches frame, but I'm ok with that. As I don't jump it. Frt lift installed. Minimum number of beers required for frt lift. Rear shock adjusting nuts wouldn't move, needed additional help. Additional beer for shocks. Rear lift brackets installed. Amount of frt lift 12 5/8in. Amount of rear lift 13 1/2. All done and toe in set. Minimum number of beers required to finish. Sorry about the reverse order of pics. Hopefully I'll get that figured out soon. | |
| Subject: Re: Rubber down custom 2" lift install Thu Apr 18, 2013 10:36 pm | |
| WOW ! and I would be laid out on the ground beside it ! HAHA
Let us know how it does. | |
Workhorserhino
| Subject: Re: Rubber down custom 2" lift install Thu Apr 18, 2013 10:42 pm | |
| That was over 4 days. 1 night for shocks, another night for tire problem. That will be another topic in vendor section tomorrow, with pics. Matthew at atvoutfitters really came thru for me on tire issue. | |
| Subject: Re: Rubber down custom 2" lift install Fri Apr 19, 2013 4:25 am | |
| Subject: Re: Rubber down custom 2" lift install Fri Apr 19, 2013 7:44 am | |
| Subject: Re: Rubber down custom 2" lift install Fri Apr 19, 2013 8:47 am | |
| good job man | |
| Subject: Re: Rubber down custom 2" lift install Fri Apr 19, 2013 11:17 am | |
| Wow, nice lift! | |
| Subject: Re: Rubber down custom 2" lift install Fri Apr 19, 2013 1:29 pm | |
| Looks good , I'd love to lift my Rhino but I like to drive way too fast and jump it. I could see it being over on its side more then it has been already | |
Workhorserhino
| Subject: Re: Rubber down custom 2" lift install Fri Apr 19, 2013 8:35 pm | |
| First casuality of lift, left rear inner axle boot. Went for a ride this evening to try and find some turkeys. Season starts soon here. Anyway got home and took a quick look around it. Yep boot torn, but its original. I put a heat shield in for the left one. Maybe need to do the same for this one. | |
| Subject: Re: Rubber down custom 2" lift install Fri Apr 19, 2013 8:41 pm | |
| How many beers is this gonna take to fix?...time to pop a top!! lol | |
| Subject: Re: Rubber down custom 2" lift install Fri Apr 19, 2013 8:46 pm | |
| Pop a top again! | |
| Subject: Re: Rubber down custom 2" lift install Fri Apr 19, 2013 9:15 pm | |
| I like the look of a lifted rhino but they are a little more top heavy but I guess it's all in how you ride. | |
| Subject: Re: Rubber down custom 2" lift install Fri Apr 19, 2013 9:23 pm | |
| i'd love to lift my rhino but would need someone to chop the top equal distance for it to get in my enclosed trailer. | |
meats
| Subject: Re: Rubber down custom 2" lift install Sat Apr 20, 2013 8:18 am | |
| looks like a good kit. does your cv shaft hit all the time or is that at full drop | |
| Subject: Re: Rubber down custom 2" lift install Sat Apr 20, 2013 8:26 am | |
| How much adjustment on the shocks? I have the stock sport shocks on mine and I'm thinking of tightening up the rear to get a little sag out but don't have to much adjustment. Maybe an inch of threads. | |
| Subject: Re: Rubber down custom 2" lift install Sat Apr 20, 2013 8:37 am | |
| lookin good!!!..........you may have to cut the frame to clear and then plate it if you dont wanna have axle trouble... | |
Workhorserhino
| Subject: Re: Rubber down custom 2" lift install Sat Apr 20, 2013 11:07 am | |
| - RENEGADE64 wrote:
- How many beers is this gonna take to fix?...time to pop a top!! lol
About 5. Getting quicker at it. | |
Workhorserhino
| Subject: Re: Rubber down custom 2" lift install Sat Apr 20, 2013 11:10 am | |
| - meats wrote:
- looks like a good kit. does your cv shaft hit all the time or is that at full drop
That left frt shaft only at full droop. I noticed yesterday that the right rear one rubs frame now. I turned rear shocks up a little more day before. Quess its to much. Don't really want to lower them though. Considering notching the frame there. Don't know yet. | |
Workhorserhino
| Subject: Re: Rubber down custom 2" lift install Sat Apr 20, 2013 11:14 am | |
| - banchee6 wrote:
- How much adjustment on the shocks? I have the stock sport shocks on mine and I'm thinking of tightening up the rear to get a little sag out but don't have to much adjustment. Maybe an inch of threads.
I have progressive 425 shocks on it. Rear shocks are about 1/2 way up threads. Frt shocks are cranked up tight. Extra steel in the front. | |
Workhorserhino
| Subject: Re: Rubber down custom 2" lift install Sat Apr 20, 2013 11:16 am | |
| - WV Hot Rod Rhino wrote:
- lookin good!!!..........you may have to cut the frame to clear and then plate it if you dont wanna have axle trouble...
Probably gonna notch frame. But hope you have an axle in stock, if I need it. | |
Workhorserhino
| Subject: Re: Rubber down custom 2" lift install Sat Apr 20, 2013 11:16 pm | |
| could you post pic of tool an clamp | |
Workhorserhino
| Subject: Re: Rubber down custom 2" lift install Sun Apr 21, 2013 12:50 pm | |
| Here is a pic of the tool. | |
Workhorserhino
| Subject: Re: Rubber down custom 2" lift install Sun Apr 21, 2013 12:56 pm | |
| With a clamp started in tool. Just wind arm up as tight as needed. Fold back over band. remove tool and crimp tabs to hold band. Cut off excess. Works very easy. | |
Workhorserhino
| Subject: Re: Rubber down custom 2" lift install Sun Apr 21, 2013 1:00 pm | |
Probably gonna notch frame. But hope you have an axle in stock, if I need it. I decided to adjust rear shocks down a little yesterday. Lowered each a 1/4". Drove it around and rechecked. Got about 1/4" clearance to frame now. Till I get to notch frame. Want to fix the right floor board next. | |
| Subject: Re: Rubber down custom 2" lift install | |
