In total there are 44 users online :: 0 Registered, 0 Hidden and 44 Guests :: 2 Bots
Shock bolts Icon_minitimeWed Aug 16, 2023 1:17 pm by RADICAL RAM
Shock bolts Icon_minitimeThu Dec 14, 2017 4:54 pm by WV Hot Rod Rhino
Shock bolts Icon_minitimeThu Dec 14, 2017 1:28 am by WV Hot Rod Rhino
Shock bolts Icon_minitimeThu Dec 14, 2017 12:35 am by WV Hot Rod Rhino
Shock bolts Icon_minitimeFri Dec 13, 2013 11:01 am by WV Hot Rod Rhino
Shock bolts Icon_minitimeFri Dec 13, 2013 10:59 am by WV Hot Rod Rhino
Shock bolts Icon_minitimeFri Dec 13, 2013 9:33 am by Tacoclaw
Shock bolts Icon_minitimeFri Dec 13, 2013 7:50 am by chuddly
Shock bolts Icon_minitimeFri Dec 13, 2013 7:47 am by chuddly
Shock bolts Vote_lcapShock bolts Voting_barShock bolts Vote_rcap
 Shock bolts
5 posters
Dan700
Dan700
Shock bolts Empty
PostSubject: Shock bolts   Shock bolts Icon_minitimeFri Apr 19, 2013 1:44 pm
I noticed the rear bottom shock bolt is rubbing on the axle you can see the axle where it is rubbing its only when the suspension is at a certain point. any ideas wats wrong anything bent I will try to get pic soon any help would be great
jaydog13
Shock bolts Empty
PostSubject: Re: Shock bolts   Shock bolts Icon_minitimeFri Apr 19, 2013 2:03 pm
have ever removed the rear spindles ? if u put them on upside down and have a life it will make it rub.
Shock bolts Empty
PostSubject: Re: Shock bolts   Shock bolts Icon_minitimeFri Apr 19, 2013 2:37 pm
yep..up side down prolly
Shock bolts Empty
PostSubject: Re: Shock bolts   Shock bolts Icon_minitimeFri Apr 19, 2013 2:38 pm
or the lower a arm where the shock bolts...seen that too
Shock bolts Empty
PostSubject: Re: Shock bolts   Shock bolts Icon_minitimeFri Apr 19, 2013 3:23 pm
does it have a lift kit?
Shock bolts Empty
PostSubject: Re: Shock bolts   Shock bolts Icon_minitimeFri Apr 19, 2013 3:32 pm
660 or 700
Dan700
Dan700
Shock bolts Empty
PostSubject: Re: Shock bolts   Shock bolts Icon_minitimeSat Apr 20, 2013 4:06 pm
700... no lift kit...
Rhino686
Rhino686
Shock bolts Empty
PostSubject: Re: Shock bolts   Shock bolts Icon_minitimeWed Sep 11, 2013 10:42 pm
Mine had the same problem it was on backwards. But when i went to try to flip it around it was stuck in the bushing and took a sledgehammer and a punch to bust the bad boy out. Finally got it now waiting on a new bushing from fox but mine was rubbing my cv boot and would twist it up i fixed the driver side also and it fixed my rubbing issue so maybe we have the same problem
Shock bolts Empty
Shock bolts
» Sport resi shock HELP
» Shock help ASAP
» Teryx shock install
» Adding a lift kit to restore stock height
» Shock suggestions? 700 rhino
