| Subject: Re: Is the my floor pan cracked ? Sun Apr 21, 2013 9:39 am | |
| hard to tell from pic not the mount is it | |
| Subject: Re: Is the my floor pan cracked ? Sun Apr 21, 2013 9:41 am | |
| my thought also on the mount let us know what you find | |
Yamahammer
Posts : 2 Join date : 2013-04-05 Age : 41 Location : South arkansas
| Subject: Re: Is the my floor pan cracked ? Tue Apr 23, 2013 4:17 am | |
| Mine done the same thing. I put a peice of angle iron under it and drilled hole for motor mount and two more to hold it to floor pan since I can't weld. Works good so far no more movement | |
| Subject: Re: Is the my floor pan cracked ? Tue Apr 23, 2013 8:11 am | |
| Subject: Re: Is the my floor pan cracked ? Tue Apr 23, 2013 10:14 am | |
| I'm going to pull the mount off today and see what it looks like under it. If it's cracked I'll just weld it and maybe add some plate to reinforce it | |
| Subject: Re: Is the my floor pan cracked ? | |
