In total there are 20 users online :: 0 Registered, 0 Hidden and 20 Guests :: 1 Bot
scratching my head here fellas... Icon_minitimeWed Aug 16, 2023 1:17 pm by RADICAL RAM
scratching my head here fellas... Icon_minitimeThu Dec 14, 2017 4:54 pm by WV Hot Rod Rhino
scratching my head here fellas... Icon_minitimeThu Dec 14, 2017 1:28 am by WV Hot Rod Rhino
scratching my head here fellas... Icon_minitimeThu Dec 14, 2017 12:35 am by WV Hot Rod Rhino
scratching my head here fellas... Icon_minitimeFri Dec 13, 2013 11:01 am by WV Hot Rod Rhino
scratching my head here fellas... Icon_minitimeFri Dec 13, 2013 10:59 am by WV Hot Rod Rhino
scratching my head here fellas... Icon_minitimeFri Dec 13, 2013 9:33 am by Tacoclaw
scratching my head here fellas... Icon_minitimeFri Dec 13, 2013 7:50 am by chuddly
scratching my head here fellas... Icon_minitimeFri Dec 13, 2013 7:47 am by chuddly
scratching my head here fellas... Vote_lcapscratching my head here fellas... Voting_barscratching my head here fellas... Vote_rcap
Greeley
6 posters
scratching my head here fellas... Empty
PostSubject: scratching my head here fellas...   scratching my head here fellas... Icon_minitimeMon Mar 11, 2013 1:32 am
hey all, trying to pull my secondary off to install my spring and washers from james today and I've been trying for a few times now. I tried some penetrant and a puller with some bolts in the 6mm holes in the face light taps with wood and brass drift . heat and cool a few times. nada. any ideas newish to me rhino had no cover on it so who knows what cruddy corrosion is between shaft and secondary. any ideas? 2008 700. yes the nut and fan is all off. don't wanna break it. Rolling Eyes
Greeley
Greeley
PostSubject: Re: scratching my head here fellas...   scratching my head here fellas... Icon_minitimeMon Mar 11, 2013 2:13 pm
I don't have any advice but I would call James directly, he would be happy to help!
Brian lee Rhino450
Brian lee Rhino450
PostSubject: Re: scratching my head here fellas...   scratching my head here fellas... Icon_minitimeMon Mar 11, 2013 3:23 pm
I may not understand but is the belt off im kinda slow. I did mine a couple weeks ago used an impact to take off nut for secondary and nut for primary and slid everthing off
Brian lee Rhino450
Brian lee Rhino450
PostSubject: Re: scratching my head here fellas...   scratching my head here fellas... Icon_minitimeMon Mar 11, 2013 3:25 pm
If the belts off and it wont slide off. Ua id call james too
PostSubject: Re: scratching my head here fellas...   scratching my head here fellas... Icon_minitimeMon Mar 11, 2013 4:25 pm
Ya belt is off I spoke with James about it before he cautioned me on the puller I just tried to call him again for other ideas he was talking about a very good penetrant oil maybe ill pm him phone is full lol. Very busy guy lately
Brian lee Rhino450
Brian lee Rhino450
PostSubject: Re: scratching my head here fellas...   scratching my head here fellas... Icon_minitimeMon Mar 11, 2013 5:49 pm
May have to find a way to tilt the vehicle pretty good to one side so the pentrating oil can run down in between the shaft and the secondary. Sounds like shes frozen good
Brian lee Rhino450
Brian lee Rhino450
PostSubject: Re: scratching my head here fellas...   scratching my head here fellas... Icon_minitimeMon Mar 11, 2013 5:55 pm
If it were mine it would get some imdustrial strength penatrating oil and sit on its side for 24 hrs. Just dont know if u can buy the stuff never looked for it but we use it on airplanes all the time. Good luck man
PostSubject: Re: scratching my head here fellas...   scratching my head here fellas... Icon_minitimeMon Mar 11, 2013 6:40 pm
pb plaster and jb 80 are very good ,i work on heavy equiptment everyday and we go through cases of this stuff every month , best to let it soak overnight, mick
PostSubject: Re: scratching my head here fellas...   scratching my head here fellas... Icon_minitimeMon Mar 11, 2013 7:39 pm
I will second that, let it soak over night or two if needed. Then smack it lightly with a nylon or rubber hammer.
PostSubject: Re: scratching my head here fellas...   scratching my head here fellas... Icon_minitimeMon Mar 11, 2013 9:18 pm
Panter Piss should do the job, you ran a bolt in the secondary sheave to spread it some, that should help get some PP in around the shaft. Maybe spread it and loosen it; and repeat several times to work it a little bit.
PostSubject: Re: scratching my head here fellas...   scratching my head here fellas... Icon_minitimeMon Mar 11, 2013 10:28 pm
got it off just now had a little heat on it and I've been soaking pb blaster and wd and anything else i could find. had the puller on it with tension on the shaft and kept tapping the end of it had a friend keep some tension on the sheave so it didn't bounce and slowly it came... didn't really look all that bad once it was off shaft looked good. thanks for all who commented.
» Hey fellas
» Engine pics
» 660 head and cam
» 660 head
» Head install
