In total there are 30 users online :: 0 Registered, 0 Hidden and 30 Guests :: 1 Bot
700 top speed  Icon_minitimeWed Aug 16, 2023 1:17 pm by RADICAL RAM
700 top speed  Icon_minitimeThu Dec 14, 2017 4:54 pm by WV Hot Rod Rhino
700 top speed  Icon_minitimeThu Dec 14, 2017 1:28 am by WV Hot Rod Rhino
700 top speed  Icon_minitimeThu Dec 14, 2017 12:35 am by WV Hot Rod Rhino
700 top speed  Icon_minitimeFri Dec 13, 2013 11:01 am by WV Hot Rod Rhino
700 top speed  Icon_minitimeFri Dec 13, 2013 10:59 am by WV Hot Rod Rhino
700 top speed  Icon_minitimeFri Dec 13, 2013 9:33 am by Tacoclaw
700 top speed  Icon_minitimeFri Dec 13, 2013 7:50 am by chuddly
700 top speed  Icon_minitimeFri Dec 13, 2013 7:47 am by chuddly
700 top speed  Vote_lcap700 top speed  Voting_bar700 top speed  Vote_rcap
 700 top speed
5 posters
brianak
700 top speed  Empty
PostSubject: 700 top speed    700 top speed  Icon_minitimeMon Apr 22, 2013 2:44 am
Just trying to figure out what speed to expect out of a 2012 700 with just a JBS sheave 18g weights and purple spring on 27" mud lites. Stock CDI for now until I can fiure out a way to order one without the wife knowing. I finally got to give it a run on flat pavement and it gets up and goes. In the room I have I hit 41. Gets there pretty damn quick now. Is this right? Wanting to make sure this is normal and that I did not screw something up.
Workhorserhino
Workhorserhino
700 top speed  Empty
PostSubject: Re: 700 top speed    700 top speed  Icon_minitimeMon Apr 22, 2013 6:38 am
I just put 27" tire on mine. It takes a long run to hit top speed for me, tires are heavy. I can hit 40 and still have throttle. I used to hit 48-50 with 25" tires. No other mods, just Hotrods sheave. I think you need a longer straight away.
Snorhino
Snorhino
700 top speed  Empty
PostSubject: Re: 700 top speed    700 top speed  Icon_minitimeMon Apr 22, 2013 9:45 pm
I have the same primary set up but the factory spring in the secondary with 26" tires, I get 44-45 on pavement
700 top speed  Empty
PostSubject: Re: 700 top speed    700 top speed  Icon_minitimeTue Apr 23, 2013 1:16 pm
I consistently hit 50 sometimes a little more
700 top speed  Empty
PostSubject: Re: 700 top speed    700 top speed  Icon_minitimeTue Apr 23, 2013 1:40 pm
should be more...prolly a weight flopped over during install...call me if you need to
700 top speed  Empty
700 top speed
» my 660 top speed run 30 to 54 mph
» 700 top speed
» 700 rhino top speed?
» 450 Speed/What Am I Missing?
» 660 Top speed what am I missing?
