In total there are 31 users online :: 0 Registered, 0 Hidden and 31 Guests :: 2 Bots
Under seat battery Icon_minitimeWed Aug 16, 2023 1:17 pm by RADICAL RAM
Under seat battery Icon_minitimeThu Dec 14, 2017 4:54 pm by WV Hot Rod Rhino
Under seat battery Icon_minitimeThu Dec 14, 2017 1:28 am by WV Hot Rod Rhino
Under seat battery Icon_minitimeThu Dec 14, 2017 12:35 am by WV Hot Rod Rhino
Under seat battery Icon_minitimeFri Dec 13, 2013 11:01 am by WV Hot Rod Rhino
Under seat battery Icon_minitimeFri Dec 13, 2013 10:59 am by WV Hot Rod Rhino
Under seat battery Icon_minitimeFri Dec 13, 2013 9:33 am by Tacoclaw
Under seat battery Icon_minitimeFri Dec 13, 2013 7:50 am by chuddly
Under seat battery Icon_minitimeFri Dec 13, 2013 7:47 am by chuddly
Under seat battery Vote_lcapUnder seat battery Voting_barUnder seat battery Vote_rcap
 Under seat battery
3 posters
Grunt
Under seat battery Empty
PostSubject: Under seat battery   Under seat battery Icon_minitimeFri Apr 26, 2013 11:36 pm
Has anyone had problems after installing a battery under the seat?
My main
concern is the possibility of the battery shorting out (thus ruining it) when
submerged during a deep water crossing.
PostSubject: Re: Under seat battery   Under seat battery Icon_minitimeSat Apr 27, 2013 9:05 am
mine is mounted up high next to the stocker, I have a heater under the seat, its mounted in a EMP bracket
PostSubject: Re: Under seat battery   Under seat battery Icon_minitimeSat Apr 27, 2013 9:09 am
Under seat battery Rhino_14
PostSubject: Re: Under seat battery   Under seat battery Icon_minitimeSat Apr 27, 2013 9:54 am
Hello Grunt, Good to see Ya here !
I don't think You would have much of a problem with the battery "shorting out" under the seat as long as You use a sealed battery. IMO water isn't the killer on a battery, it's grease and dirt on top of a battery that can cause a draw and kill a battery. Most UTV's run an AGM battery now and a lot of people submerge them quite often (even in the stock location) !
Hope this helps !
Under seat battery
» OEM Yamaha Battery
» Changing battery
» Battery upgrade
» Battery FAQs
» Replacement battery
