In total there are 48 users online :: 0 Registered, 0 Hidden and 48 Guests :: 2 Bots
450 question  Icon_minitimeWed Aug 16, 2023 1:17 pm by RADICAL RAM
450 question  Icon_minitimeThu Dec 14, 2017 4:54 pm by WV Hot Rod Rhino
450 question  Icon_minitimeThu Dec 14, 2017 1:28 am by WV Hot Rod Rhino
450 question  Icon_minitimeThu Dec 14, 2017 12:35 am by WV Hot Rod Rhino
450 question  Icon_minitimeFri Dec 13, 2013 11:01 am by WV Hot Rod Rhino
450 question  Icon_minitimeFri Dec 13, 2013 10:59 am by WV Hot Rod Rhino
450 question  Icon_minitimeFri Dec 13, 2013 9:33 am by Tacoclaw
450 question  Icon_minitimeFri Dec 13, 2013 7:50 am by chuddly
450 question  Icon_minitimeFri Dec 13, 2013 7:47 am by chuddly
450 question  Vote_lcap450 question  Voting_bar450 question  Vote_rcap
 450 question
5 posters
450 question  Empty
PostSubject: 450 question    450 question  Icon_minitimeSun Jun 09, 2013 2:28 pm
A friend of mine just bought a 450 rhino so I was wanting to ask you 450 guys for him what is the best performance upgrades and what can he expect from them obviously I have already told him a JBS sheave should be his first purchase. Thanks guys in advance.
450 question  Empty
PostSubject: Re: 450 question    450 question  Icon_minitimeSun Jun 09, 2013 3:09 pm
Teddy, the 450 Rhino is a beast. It needs no modifications whatsoever other than the JBS sheave. 450 question  2016508534
but seriously, he should ride it the way it is and see what the seat of his pants tells him first.
450 question  Empty
PostSubject: Re: 450 question    450 question  Icon_minitimeSun Jun 09, 2013 3:51 pm
[img]450 question  036_zps00061655[/img][img]450 question  037_zpsec3e69a2[/img][img]450 question  034_zpsfbfae946[/img]T Rhino: Was out yesterday trail scout and took a ridge straight up from 7100' to 8600', The only issue the 450 had was on descending and the fuel pump wasn't push enough fuel into the carb and the Rhino wanted to keep dying, so there was the need to throttle up the engine even thou all I needed was 4x4 disc brakes. Not sure, but maybe an upgrade on the fuel pump if you do much of that type of riding. JBS sheave is a must in my arsenal. Here is a couple pics from the top of the ridge, see the elk in the one pic?
450 question  Empty
PostSubject: Re: 450 question    450 question  Icon_minitimeSun Jun 09, 2013 4:31 pm
[img]450 question  011_zps78f70e2a[/img]
This is why I went with a 3" lift on my Rhino. Haven't had any problems with axles, cv's, ect.
Yotehunter66
Moderator
Yotehunter66
450 question  Empty
PostSubject: Re: 450 question    450 question  Icon_minitimeSun Jun 09, 2013 8:07 pm
Sheave, blue spring, rejet the carb for top performance and CDI. That's about all you can get out of her without cam and piston.
450 question  Empty
PostSubject: Re: 450 question    450 question  Icon_minitimeSun Jun 09, 2013 8:11 pm
What size jets for the carb ?
450 question  Empty
PostSubject: Re: 450 question    450 question  Icon_minitimeSun Jun 09, 2013 8:35 pm
And what about exhaust ?
450 question  Empty
PostSubject: Re: 450 question    450 question  Icon_minitimeSun Jun 09, 2013 9:34 pm
Teddy, I re-jetted when I opened up the air intake and added a exhaust tip. Jet size will depend on his bike. Borrow James' A/F meter and you can get it tuned in pretty good, you'll need to weld a bung on the exhaust. After I was done with mine, it'll hold 42 - 43 mph on the flats and hit 46 down hill. Love what it did for it.
450 question  Empty
PostSubject: Re: 450 question    450 question  Icon_minitimeMon Jun 10, 2013 2:15 am
Don't go crazy on the tire size. JBS sheave changes everything about it. The blue spring is a must, it adds a little help to get the tires turning from a stop in mud, over rocks, trees, etc. It also helps it get out of the turns a little quicker.
Would like to have drove mine with 25s and a set of factory sport wheels after the sheave and spring, because the 26s and itp wheels killed it. I did the sheave after the tire/wheel swap.
450 question  Empty
PostSubject: Re: 450 question    450 question  Icon_minitimeMon Jun 10, 2013 2:21 am
I always heard that the 450 was the toughest engine Yamaha ever made. I believe that. I held mine wide open all day long for countless days. Ran it do hard it didn't want to run right a couple of times. Ate so much dust the filter clogged and the engine wouldn't even try to start once. It never used any oil, and never let me down other than it didn't want to run if the tailpipe was under water. LOL
That 450 and JBS are the reasons I own what I do now.450 question  2016508534
450 question  Empty
450 question
» GPS question
» question on kms slug kit???
» Question for James
» a question for the 450 guys
» Radiator Question
