In total there are 68 users online :: 0 Registered, 0 Hidden and 68 Guests :: 2 Bots
guage install Icon_minitimeWed Aug 16, 2023 1:17 pm by RADICAL RAM
guage install Icon_minitimeThu Dec 14, 2017 4:54 pm by WV Hot Rod Rhino
guage install Icon_minitimeThu Dec 14, 2017 1:28 am by WV Hot Rod Rhino
guage install Icon_minitimeThu Dec 14, 2017 12:35 am by WV Hot Rod Rhino
guage install Icon_minitimeFri Dec 13, 2013 11:01 am by WV Hot Rod Rhino
guage install Icon_minitimeFri Dec 13, 2013 10:59 am by WV Hot Rod Rhino
guage install Icon_minitimeFri Dec 13, 2013 9:33 am by Tacoclaw
guage install Icon_minitimeFri Dec 13, 2013 7:50 am by chuddly
guage install Icon_minitimeFri Dec 13, 2013 7:47 am by chuddly
guage install Vote_lcapguage install Voting_barguage install Vote_rcap
 guage install
Guenther
txgrown1404
Rhinofire13
tjt603
willykiller
chammons
Tunderslimer
Brian lee Rhino450
21 posters
Go to page : 1, 2, 3  Next
guage install Empty
PostSubject: guage install   guage install Icon_minitimeTue Jun 18, 2013 8:42 pm
my next project is to install a water temp guage and volt guage in the rhino , where can I get the adapter that goes in line to install the sending unit in or if theres a better way please do tell the volt guage I have already read here, thanks mick
Brian lee Rhino450
Brian lee Rhino450
guage install Empty
PostSubject: Re: guage install   guage install Icon_minitimeTue Jun 18, 2013 9:09 pm
Black rhino is where i got mine
guage install Empty
PostSubject: Re: guage install   guage install Icon_minitimeTue Jun 18, 2013 9:11 pm
I 'm working on this now , trying to get all parts rounded up , was told to check with ultimate rhino
 for sensor for water temp have not got that far yet , I 'm doing tack--water temp---oil temp
Brian lee Rhino450
Brian lee Rhino450
guage install Empty
PostSubject: Re: guage install   guage install Icon_minitimeTue Jun 18, 2013 9:13 pm
For oil temp adapter, i got it out of summit catalog
Last edited by Brian lee Rhino450 on Wed Jun 19, 2013 1:40 am; edited 1 time in total
Tunderslimer
Tunderslimer
guage install Empty
PostSubject: Re: guage install   guage install Icon_minitimeWed Jun 19, 2013 12:42 am
I've got an Auto Meter setup in mine... I will go snap a couple of pics. I picked up a 3/4" inline adapter made by Auto Meter as well. I did a distribution block and relay setup to connect the gauge lighting and volt gauge. I will post the pics as soon as I get em.
guage install Empty
PostSubject: Re: guage install   guage install Icon_minitimeWed Jun 19, 2013 7:03 am
Thanks I would like to see those pics also and if you have any part #'s that would be great to.
guage install Empty
PostSubject: Re: guage install   guage install Icon_minitimeWed Jun 19, 2013 10:03 am
I bought a cheap water temp gauge and volt meter from Orielliy's. Took the sending unit to the hardware store and put together some fitting for in line on radiator hose. Works great !
Tunderslimer
Tunderslimer
guage install Empty
PostSubject: Re: guage install   guage install Icon_minitimeWed Jun 19, 2013 10:56 am
I used Auto Meter #'s 5791 and 5737 for volts and water temp, short sweep electric.  The vacuum gauge is a full sweep 5784.  All from Phantom series.
guage install 20130618_205103
The adapter I used is an Auto Meter 2281, 3/4" pipe adapter.  It's a little smaller than the rad hose, but the hose clamps give it a good squeeze.  Haven't had any trouble with cooling despite the smaller adapter size.
guage install 20130618_205232
My flash wasn't working last night cause my phone was so dead, but I can post a pic of the distribution block and relay setup if you want.
guage install Empty
PostSubject: Re: guage install   guage install Icon_minitimeWed Jun 19, 2013 2:33 pm
Thanks and yes any pics you could would be great.
Tunderslimer
Tunderslimer
guage install Empty
PostSubject: Re: guage install   guage install Icon_minitimeWed Jun 19, 2013 3:12 pm
Just checking but you can see the pics I posted right??
guage install Empty
PostSubject: Re: guage install   guage install Icon_minitimeWed Jun 19, 2013 3:43 pm
Yes ! And very good pics !
chammons
guage install Empty
PostSubject: Re: guage install   guage install Icon_minitimeWed Jun 19, 2013 7:06 pm
Black Rhino kit is what I installed myself.
guage install Empty
PostSubject: Re: guage install   guage install Icon_minitimeWed Jun 19, 2013 7:09 pm
thanks for the pics and info just what I needed  cheers
Tunderslimer
Tunderslimer
guage install Empty
PostSubject: Re: guage install   guage install Icon_minitimeWed Jun 19, 2013 8:44 pm
Better pic of the temp sender install:
guage install 2013+-+1
Tunderslimer
Tunderslimer
guage install Empty
PostSubject: Re: guage install   guage install Icon_minitimeWed Jun 19, 2013 8:49 pm
Here's a crappy pic of my distro block. A set of 12 ga wires run from the battery to the block providing constant 12v power, and there's one more positive post as well from the switched relay.
Posts in no particular order:
1. Battery 12+
2. Battery Negative
3. Switched 30 Amp relay 12+
4. Low current 12+ (from ignition switch)  ** This pole only switches the relay, no other loads should be run from the ignition switch
guage install 2013+-+2
Tunderslimer
Tunderslimer
guage install Empty
PostSubject: Re: guage install   guage install Icon_minitimeWed Jun 19, 2013 8:54 pm
I screwed up here, I just left the relay hanging down.  Water seeps in and allows a connection powering everything up with the key off.
Note for others, hang the relay upside down or better yet, drill a hole in a tupperware container and run the wire for the distro block and relay into it.  Bam, nice fairly waterproof electrical box with a removable lid.
guage install 2013+-+4
Tunderslimer
Tunderslimer
guage install Empty
PostSubject: Re: guage install   guage install Icon_minitimeWed Jun 19, 2013 8:58 pm
Backside of the gauges.
The power for the volt gauge and LED lighting is all run through the distro block.  The temp gauge sender needs to be grounded, it's also done up to the distro block.
Remember not to hook anything other than a low current relay to the ignition switch, use your relay power for this.
guage install 2013+-+5
willykiller
willykiller
guage install Empty
PostSubject: Re: guage install   guage install Icon_minitimeFri Jun 21, 2013 8:14 am
I mounted the water temp senor in the head right beside the thermostat housing, on the 660s there is lots of room, just drill a hole and thread to the proper sensor threads......
guage install Empty
PostSubject: Re: guage install   guage install Icon_minitimeFri Jun 21, 2013 9:59 am
Great posts they really help out I'm in the process of hooking my Gauges up now and refuse to drive it till there done due to the overheating issue I had the other day. Thanks again
tjt603
tjt603
guage install Empty
PostSubject: Re: guage install   guage install Icon_minitimeFri Jun 21, 2013 5:30 pm
guage install 20120928_212248
Here is my set up....
guage install Empty
PostSubject: Re: guage install   guage install Icon_minitimeFri Jun 21, 2013 5:46 pm
Nice looking set up. How do you like those pedals ?
tjt603
tjt603
guage install Empty
PostSubject: Re: guage install   guage install Icon_minitimeFri Jun 21, 2013 5:48 pm
I love the pedals they really help out.
Rhinofire13
Rhinofire13
guage install Empty
PostSubject: Re: guage install   guage install Icon_minitimeFri Jun 21, 2013 7:13 pm
Looks nice!
guage install Empty
PostSubject: Re: guage install   guage install Icon_minitimeFri Jun 21, 2013 8:16 pm
great pics  can't wait to finish mine
guage install Empty
PostSubject: Re: guage install   guage install Icon_minitimeSat Jun 22, 2013 12:32 pm
In the process of installing volt, oil pressure, and water temp gauges. I just need to button up the water. I am curious on what temp it should run, my is running a steady 170. What about everyone else who has a gauge? I will post pics when done, let me warn you it is somewhat redneck. Please point out anything ya'll see that might cause issues on down the road.
guage install Empty
guage install
Page 1 of 3Go to page : 1, 2, 3  Next
» A/F guage
» Guage stays on after key is off
» My Stereo Install
» 450 cam install
» Inner cv install
