First off, sorry I did not get this posted a month ago when I installed it; I have been extremely busy with the new house. Also, please note the night I wired the fuse block I had not yet installed a grounding block. I have since installed the grounding block and would recommend overhauling your grounding system before wiring a bunch if stuff in.
Okay now to the fun part!
If you could not tell by my stereo install thread I like to do things a bit different. I do not use my glove box on my Rhino except to plug into the auxiliary radio so I chose to mount my fuse block in the glove box an go from there. I used wired clamps to hold the wires into place, and heat shrinked them in a few places to keep things tidy. Where I exited the glove box with the wires I actually used a seal tight fitting that will keep out water. It has a rubber gasket in it and as you tighten it down it seals itself off. The directions were pretty easy to follow. I hope this give everyone different ideas/methods when installing. Feel free to critique.
Joe
This is the Seal Tight fitting:
Pic inside the glove box:
