In total there are 21 users online :: 0 Registered, 0 Hidden and 21 Guests :: 2 Bots
700 Radiator fan replacment Icon_minitimeWed Aug 16, 2023 1:17 pm by RADICAL RAM
700 Radiator fan replacment Icon_minitimeThu Dec 14, 2017 4:54 pm by WV Hot Rod Rhino
700 Radiator fan replacment Icon_minitimeThu Dec 14, 2017 1:28 am by WV Hot Rod Rhino
700 Radiator fan replacment Icon_minitimeThu Dec 14, 2017 12:35 am by WV Hot Rod Rhino
700 Radiator fan replacment Icon_minitimeFri Dec 13, 2013 11:01 am by WV Hot Rod Rhino
700 Radiator fan replacment Icon_minitimeFri Dec 13, 2013 10:59 am by WV Hot Rod Rhino
700 Radiator fan replacment Icon_minitimeFri Dec 13, 2013 9:33 am by Tacoclaw
700 Radiator fan replacment Icon_minitimeFri Dec 13, 2013 7:50 am by chuddly
700 Radiator fan replacment Icon_minitimeFri Dec 13, 2013 7:47 am by chuddly
700 Radiator fan replacment Vote_lcap700 Radiator fan replacment Voting_bar700 Radiator fan replacment Vote_rcap
DHILL
6 posters
DHILL
DHILL
700 Radiator fan replacment Empty
PostSubject: 700 Radiator fan replacment   700 Radiator fan replacment Icon_minitimeMon Jul 22, 2013 11:34 pm
Has anyone found a good aftermarket replacement for reasonable price? I saw a few on eBay that came with aftermarket fan and aluminum shroud for $190. I would prefer to just replace the fan if possible. Thanks
PostSubject: Re: 700 Radiator fan replacment   700 Radiator fan replacment Icon_minitimeTue Jul 23, 2013 8:53 am
I bought my replacement from James (oe)...I don't remember how much it was ; but, they are expensive...even with him hookin a feller up !! Mud is what f'ed mine ...I tend to "go around" the big ole deep holes now !! Shocked
rhinobucket
rhinobucket
PostSubject: Re: 700 Radiator fan replacment   700 Radiator fan replacment Icon_minitimeTue Jul 23, 2013 8:58 am
Don't know for the 700, but the Hayden Rapid Cool #3670 at O'Reillys will fit the 450 and 660. $49.99
PostSubject: Re: 700 Radiator fan replacment   700 Radiator fan replacment Icon_minitimeTue Jul 23, 2013 9:42 am
Check out this thread. https://hotrodrhinoforums.forumotion.com/t533-radiator-fan
I paid $30 for a new fan. You'll need a shroud to make it fit tho
PostSubject: Re: 700 Radiator fan replacment   700 Radiator fan replacment Icon_minitimeTue Jul 23, 2013 9:51 am
put a post our on here and the other sites, someone might have a spare laying around.....if you buy a fan from autozone or where ever, cut your stock shroud and make it work.....  I called the company that made the fan motor and they wont sell that model motor to the public....
PostSubject: Re: 700 Radiator fan replacment   700 Radiator fan replacment Icon_minitimeTue Jul 23, 2013 10:14 am
I replaced one on a 450 with a oil cooler fan from advance.
DHILL
DHILL
PostSubject: Re: 700 Radiator fan replacment   700 Radiator fan replacment Icon_minitimeTue Jul 23, 2013 10:54 am
Yea I read the other post first. Banchee what did you end up doing to fix yours? I would rather try fitting a fan from auto parts store to my stock shroud first before buying aftermarket shroud. Where can I buy the aluminum shroud separately if I have to go that route?
PostSubject: Re: 700 Radiator fan replacment   700 Radiator fan replacment Icon_minitimeTue Jul 23, 2013 7:24 pm
I found a used one for 120. Works perfectly. I kept my old one to make something new for the next time. I'll get an aftermarket one and fit it in there with some trusty modifications.
DHILL
DHILL
PostSubject: Re: 700 Radiator fan replacment   700 Radiator fan replacment Icon_minitimeWed Aug 07, 2013 12:22 am
An update on what I ended up doing to fix the broken fan on my 08 700. I bought the Hayden fan listed above from O'Reillys. I cut out the middle of the oem fan shroud and bolted the Hayden fan in the opening.  I had to put a spacer in between the shroud and fan to keep the fan from bending when I tightened everything up. Also the fan is taller than the shroud so I am hoping that won't become an issue.  I ran the rhino until the fan kicked on...seems to be working properly.
700 Radiator fan replacment IMAG0162_zps7398e882
https://2img.net/h/i1282.photobucket.com/albums/a527/dhillr6/IMAG0163_zpsb9f69575.jpg
https://2img.net/h/i1282.photobucket.com/albums/a527/dhillr6/IMAG0164_zpsc5763372.jpg
https://2img.net/h/i1282.photobucket.com/albums/a527/dhillr6/IMAG0165_zps01303835.jpg
https://2img.net/h/i1282.photobucket.com/albums/a527/dhillr6/IMAG0166_zps28dd5693.jpg
https://2img.net/h/i1282.photobucket.com/albums/a527/dhillr6/IMAG0167_zpsf9c55c2a.jpg
rhinobucket
rhinobucket
PostSubject: Re: 700 Radiator fan replacment   700 Radiator fan replacment Icon_minitimeWed Aug 07, 2013 9:42 am
Did you reverse the fan blades and reverse polarity? Blue + and black-. The fan comes from factory as a pusher.
DHILL
DHILL
PostSubject: Re: 700 Radiator fan replacment   700 Radiator fan replacment Icon_minitimeWed Aug 07, 2013 11:33 am
Yes you are right. I did both. I flipped the fan over and ran blue + and black -
» Radiator Fan
» radiator fan
» Radiator Question
» Radiator refill
» Radiator relocate ??
