| radiator fan | |
+11Bender.chris5908 123.bert0621 txgrown1404 onebuilder REDRHINO64 Pokahpolice Stuntmanmike honda450sfm Firefighter scottwv banchee6 15 posters |
| Subject: radiator fan Sun Mar 31, 2013 9:56 am | |
| My fan is making some crazy noises.... Can it be rebuilt or do i just have to replace the whole thing? Im sure its from going underwater so many times but oh well........... | |
Posts : 601 Join date : 2013-03-10 Age : 53 Location : Charleston , WV
| Subject: Re: radiator fan Sun Mar 31, 2013 11:08 am | |
| Mine didnt really make noises...it just wouldnt kick on sometimes. I took it off , and kept spraying wd-40 in the vent hole , till it would drain out clear. That'll get you a little more time out of it ; but , you'll end up buying a new one before all said and done. btw...you're gonna shit when you see how much those cost !!! | |
| Subject: Re: radiator fan Sun Mar 31, 2013 11:56 am | |
| I put an aftermarket fan on from O'Reilly's .....$50 Been on there for about a year with no issues. cools better than factory ! | |
| Subject: Re: radiator fan Sun Mar 31, 2013 12:22 pm | |
| If you a mechanically inclined , you can take one apart. Once it's apart, it's pretty simple. Clean out all the muddy crap in there, clean up the brushes, lube it up(bearings and bushings), silicone it back up and you're good to go. Mine stopped working a while back and when I took it apart, turned out to be a severed wire to the brush. Put in a new brush, (had to customize one from a skil saw actually) and all was well. Saved a pile of dough. Redneck ingenuity! | |
| Subject: Re: radiator fan Sun Mar 31, 2013 4:22 pm | |
| I'll pull it off soon. Clean it up and see what happens. Thanks for the help. | |
| Subject: Re: radiator fan Sun Mar 31, 2013 9:23 pm | |
| - Firefighter wrote:
- I put an aftermarket fan on from O'Reilly's .....$50 Been on there for about a year with no issues. cools better than factory !
You wouldnt happen to remember a part number or something for that one you purchashed??? | |
| Subject: Re: radiator fan Sun Mar 31, 2013 9:38 pm | |
| Subject: Re: radiator fan Sun Mar 31, 2013 11:10 pm | |
| I have a brand new Yamaha fan with shroud if interested. | |
| Subject: Re: radiator fan Wed Apr 24, 2013 10:07 pm | |
| well pulled it apart today to clean the radiator and its not rebuildable..... there is a sticker on it with a company called tripac... they make cooling fans but i cant seem to find the one that is in there.... Part number 15-0012.... reason i will have to change it is the vent line piece is broke off and no tellin how long its been like that.... so im sure all the bearings are full of water n mud and its rivited sorta together not bolted together... | |
Posts : 283 Join date : 2013-03-10 Age : 45 Location : Maine
| Subject: Re: radiator fan Fri Apr 26, 2013 9:32 pm | |
Posts : 1649 Join date : 2013-03-10 Age : 60 Location : Asheboro N.C./Mountain Top West By God Virginia
| Subject: Re: radiator fan Fri Apr 26, 2013 9:36 pm | |
| Subject: Re: radiator fan Fri Apr 26, 2013 9:39 pm | |
| The bolt pattern looks close. Did you try installing it in the stock location? | |
| Subject: Re: radiator fan Fri Apr 26, 2013 9:43 pm | |
| - banchee6 wrote:
- The bolt pattern looks close. Did you try installing it in the stock location?
The holes in the shroud in the pic above are where the stock fan would go. These are a bit wider and shorter. | |
| Subject: Re: radiator fan Sat Apr 27, 2013 12:43 am | |
| So you saying that the fan motor in the pic won't fit in the stock location?? | |
| Subject: Re: radiator fan Sat Apr 27, 2013 2:12 am | |
| No it will not fit the stock location. With an aftermarket shroud drilling new mounting holes is super easy. I would suggest purchasing a shroud anyway...they run about $50. So even if you buy a shroud and a fan it will run you about $80...still cheaper than most fans | |
| Subject: Re: radiator fan Sat Apr 27, 2013 7:50 am | |
| Subject: Re: radiator fan Sun Apr 28, 2013 4:20 pm | |
| - Pokahpolice wrote:
- No it will not fit the stock location. With an aftermarket shroud drilling new mounting holes is super easy. I would suggest purchasing a shroud anyway...they run about $50. So even if you buy a shroud and a fan it will run you about $80...still cheaper than most fans
I agree, a shroud is a must! The 660s d | |
txgrown1404
| Subject: Re: radiator fan Thu Jun 27, 2013 11:17 pm | |
| where is a good place to get a fan shroud for a 660?? | |
Posts : 1464 Join date : 2013-03-18 Age : 65 Location : Western Quebec
| Subject: Re: radiator fan Fri Jun 28, 2013 12:02 am | |
| TCP Preformance,(totally cool products). | |
| Subject: Re: radiator fan Fri Jun 28, 2013 10:12 pm | |
| TCP shroud is way over priced...sorry but we're talking about a fan shroud. If it fits than it's a great product...so I don't understand why it cost almost double other places.
Found mine on Ebay for $45 and looks identical to the TCP. | |
| Subject: Re: radiator fan Sat Jun 29, 2013 2:06 pm | |
| Good find. | |
Bender.chris5908
Posts : 33 Join date : 2013-03-11 Location : Central pa
| Subject: Re: radiator fan Wed Sep 25, 2013 7:44 pm | |
| watch buying aftermarket automotive fans.. I installed one on my rhino and with in 5 mins of ripping around in a "play area" out on the trail i lost half the an blades and it started to hack away at the radiator itself..
So i am in the market or a new fan and shroud.. thoughts on the duel an setup? | |
| Subject: Re: radiator fan Wed Sep 25, 2013 9:43 pm | |
| damn that sucks... ebay has a bunch, but I have no clue on how well they work | |
| Subject: Re: radiator fan Thu Sep 26, 2013 12:59 am | |
| im in the same boat my fan quit on a ride last sat. im looking into getin one with a shroud been on ebay an they have some for 119 but i dont want to buy a junk any one ever use the ebay fans? | |
| Subject: Re: radiator fan Thu Sep 26, 2013 8:39 am | |
| I know the OEM fans and shrouds are about $200, but you will know what you getting with that. Just a thought. | |
| Subject: Re: radiator fan | |
| radiator fan | |
