| radiator relocate | |
+7rhino727 Tech Man WV Hot Rod Rhino banchee6 T.Rhino ChrisH corylmack 11 posters |
corylmack
Posts : 36 Join date : 2013-03-11 Age : 43 Location : Newberry, SC
| Subject: radiator relocate Wed Jun 19, 2013 1:01 am | |
| Subject: Re: radiator relocate Wed Jun 19, 2013 2:14 am | |
| I like it. I'm a fan! So, you left the oil cooler in the stock location, and relocated the radiator to the upper frame rail? And it still cools fine during normal trail riding under the hood without being in the direct flow of the wind? | |
| Subject: Re: radiator relocate Wed Jun 19, 2013 6:54 am | |
| That is a pretty cool idea. | |
| Subject: Re: radiator relocate Wed Jun 19, 2013 10:44 am | |
| How will it do without direct air flow?? | |
corylmack
| Subject: Re: radiator relocate Wed Jun 19, 2013 1:36 pm | |
| thanks guys, it still gets a good bit of airflow from the grill in the hood kind of like a ram air scoop. | |
| Subject: Re: radiator relocate Wed Jun 19, 2013 1:45 pm | |
Tech Man
Posts : 44 Join date : 2013-04-01 Age : 50 Location : Peace River, Alberta
| Subject: Re: radiator relocate Thu Jun 20, 2013 2:06 pm | |
| I love it! Even if you get mud, dirt or sand in the core it's way easier to clean. How did you extend the hoses but still keep them from kinking when it in the down position? It's what I want to do as well. With my rear seat and cage I don't want kids getting anoid from the fan running by their ears. If you could post some close detail pics of the mounts and hoses that would be great. | |
corylmack
| Subject: Re: radiator relocate Thu Jun 20, 2013 8:23 pm | |
| thanks Tech Man. it does make it way easier to clean. as far as the hoses go i just replaced them with longer ones, there is plenty of room for them to tuck down without kinking. i will get some better pics of the mounts and hoses for you tomorrow. | |
Tech Man
| Subject: Re: radiator relocate Thu Jun 20, 2013 9:30 pm | |
| You haven't got an oil temp gauge by chance? I wonder what the diff would be between having a fan there or not to help with the oil cooler. | |
Posts : 1317 Join date : 2013-03-25 Age : 60 Location : musella,Ga.
| Subject: Re: radiator relocate Fri Jun 21, 2013 12:53 am | |
| looks good I like it, we ride a lot of mudd also this looks like it could help with the getting dirty | |
corylmack
| Subject: Re: radiator relocate Fri Jun 21, 2013 12:59 am | |
| i don't have a oil temp gauge. but i do have a second fan on the oil cooler, i will get pics of that also. | |
Tech Man
| Subject: Re: radiator relocate Fri Jun 21, 2013 1:02 am | |
| That would be great! And any info on it to please. | |
corylmack
| Subject: Re: radiator relocate Fri Jun 21, 2013 1:12 am | |
| the second fan i got at work off of a wrecked volkswagen passat. | |
| Subject: Re: radiator relocate Fri Jun 21, 2013 7:24 am | |
| I would also like to see the picks on that and I have a question to add if the radiator was mounted in the fix postion like I have seen some others against the top frame rails how hard would it be to fill or is there something I'm not seeing that's makes it more accessible. | |
Guenther
Posts : 91 Join date : 2013-05-11 Age : 48 Location : Lake Desolation, NY
| Subject: Re: radiator relocate Fri Jun 21, 2013 1:06 pm | |
| This is very similar to a mod that I am aiming to do. I do not like the idea of the radiator behind the headrest. I don't care about me but If a line was to blow and hit my wife in the face, eye, neck whatever with 200 degree fluid I couldn't live with myself. I am debating on whether to move the radiator or the oil cooler to under the hood, add a fan and a hood scoop to help with airflow. I would be interested to see any photos you have etc. | |
corylmack
| Subject: Re: radiator relocate Fri Jun 21, 2013 10:48 pm | |
| Teddy i have wing nuts that i can take loose and tilt it up for cleaning and filling it. here is a pic. | |
corylmack
| Subject: Re: radiator relocate Fri Jun 21, 2013 11:01 pm | |
corylmack
| Subject: Re: radiator relocate Fri Jun 21, 2013 11:08 pm | |
Tech Man
| Subject: Re: radiator relocate Sat Jun 22, 2013 2:30 am | |
| Perfect! Thanks Cory. Is the oil cooler fan on a separate switch or did you wire it to the rad fan relay so they come on at the same time? | |
corylmack
| Subject: Re: radiator relocate Sat Jun 22, 2013 3:22 pm | |
| your welcome. the oil cooler fan is on a separate switch. | |
Posts : 1649 Join date : 2013-03-10 Age : 60 Location : Asheboro N.C./Mountain Top West By God Virginia
| Subject: Re: radiator relocate Sat Jun 22, 2013 10:23 pm | |
| Looks good!! I have a summit oil cooler im thinking about mounting under the drivers seat that has a fan and temp sensor on it,cant do what you did because my heater is in the way,but this oil cooler should lower my temps along with running the heater fan and blowing the heat outside.nice job!!! | |
| Subject: Re: radiator relocate Sun Jun 23, 2013 11:20 am | |
| Very nice rad relocate! I wanted to do the same with my 660. Mount it on a hinge exactly like you. However, I also wanted to relocate the oil cooler as well and found that I didn't have enough room under the hood. I ended up putting it sideways higher up on the rails. I left enough slack in all the hoses to fill rad. Had to use a unisleeve to prevent one hose from kinking. The fan runs a bit more but it's a small price to pay for not having a plugged rad after a ride. I was also thinking about a cowl induction scoop of sorts. Might just to allow more air flow. Hard to find a camo scoop though! LOL! | |
Bender.chris5908
Posts : 33 Join date : 2013-03-11 Location : Central pa
| Subject: Re: radiator relocate Wed Sep 25, 2013 7:50 pm | |
| Subject: Re: radiator relocate Wed Sep 25, 2013 9:41 pm | |
| hope you don't get mad, but I am stealing your design....great job.. I think I am going to mount the oil cooler right below the fan so it kinda blows air on it.... | |
| Subject: Re: radiator relocate | |
