Good Morning Everyone,
I just wanted to post something that may be useful to other members. Last year I was removing my radiator every 3rd or 4th ride. The first few times time it was a quick job, then it progressively got more annoying involving more beer and pissing off my wife.
This is typical of what I used to deal with, believe it or not this was already rinsed out quite a bit. So here is the solution...
I am not a welder by any means. All I did was remove the end piece and fold it over on itself. Then drill some holes in it, the first few I drilled were a little big so I went smalleer. It fits right between the oil cooler and the radiator with quite a bit of pressure, when you turn it on it is similar to the force of a pressure washer. Enough for me to see Mulleyville Mud blowing out all over the place.
and a close up
I did snake this idea from another site. It does work and costs under $10 @ Home depot. Or if you want you can steal the one your wife uses for her flowers.
