| Pressure behind carb | |
Bradycrouch
Posts : 12 Join date : 2013-07-29
| Subject: Pressure behind carb Mon Jul 29, 2013 7:51 pm | |
| Hey guys i have an 06 660 rhino. I am have problems with the rubber boot connecting the carb to the intake manifold blowing off due to pressure build up. Does anyone have any suggestions. Please help | |
thekrust
| Subject: Re: Pressure behind carb Mon Jul 29, 2013 8:28 pm | |
| I saw that problem on a Raptor 660 when the air box was modded and caused it to run lean. It would backfire and blow the carbs off. Richened up the jetting and all was good. | |
Bradycrouch
| Subject: Re: Pressure behind carb Mon Jul 29, 2013 9:28 pm | |
| Sounds like same problem but my bike is stock.would it help if i rejetted? | |
Bradycrouch
| Subject: Re: Pressure behind carb Mon Jul 29, 2013 9:30 pm | |
| It also just generally runs like crap at idle and out the hole | |
Bradycrouch
| Subject: Re: Pressure behind carb Mon Jul 29, 2013 10:06 pm | |
| Can anyone tell me what jet i should be running on my bike | |
| Subject: Re: Pressure behind carb Mon Jul 29, 2013 10:23 pm | |
| What shape is your exhaust in ? Does it back fire on declaration ? | |
Bradycrouch
| Subject: Re: Pressure behind carb Mon Jul 29, 2013 10:57 pm | |
| Factory exhaust but the baffle is removed. It does not backfire on deceleration. | |
thekrust
| Subject: Re: Pressure behind carb Tue Jul 30, 2013 12:43 pm | |
| I would definitely open up the carb and see if it's dirty, there could be a restriction from that. Have you owned it since new or is it new to you? Possibly someone else changed something before you got it. Check what's in there for jets, should be 150 main and a 40 pilot jet. About 1.5-2 turns out on the mixture screw will be close enough for it to run proper | |
| Subject: Re: Pressure behind carb Tue Jul 30, 2013 2:45 pm | |
| are you sure that "pressure" is blowing the air cleaner off the carb? there should be no reverse pressure from the intake to blow it off. is it fastened securely? | |
Bradycrouch
| Subject: Re: Pressure behind carb Tue Jul 30, 2013 3:16 pm | |
| I have refastened it several times but it always comes off i will have to take carb down and look at it | |
Bradycrouch
| Subject: Re: Pressure behind carb Tue Jul 30, 2013 3:17 pm | |
| How do you know what size jets are in the carb? | |
thekrust
| Subject: Re: Pressure behind carb Tue Jul 30, 2013 3:57 pm | |
| The numbers are stamped right on them, maybe need a magnifier to read them but they will be there | |
| Subject: Re: Pressure behind carb Tue Jul 30, 2013 4:24 pm | |
| check motor mounts and where they mount for cracks...clean both surfaces with alcohol so it wont slip | |
Bradycrouch
| Subject: Re: Pressure behind carb Tue Jul 30, 2013 5:05 pm | |
| I wonder if i should just buy rebuild kit from james | |
Bradycrouch
| Subject: Re: Pressure behind carb Mon Aug 05, 2013 8:27 pm | |
| It looks like i have a 145 and a 40 is this factory? What should i have? | |
| Subject: Re: Pressure behind carb Mon Aug 05, 2013 9:23 pm | |
| Is this completely stock with the 660 air box in place? | |
Bradycrouch
| Subject: Re: Pressure behind carb Mon Aug 05, 2013 10:39 pm | |
| Subject: Re: Pressure behind carb Mon Aug 05, 2013 10:46 pm | |
| Check your valve adjustment,could be that the intake valves are not closing all the way,then when it comes to the compression stroke its blowing compression back to the carb.just tring to figure this out. | |
Bradycrouch
| Subject: Re: Pressure behind carb Mon Aug 05, 2013 11:48 pm | |
| Where can i found the valve specs? | |
| Subject: Re: Pressure behind carb Tue Aug 06, 2013 8:43 am | |
Bradycrouch
| Subject: Re: Pressure behind carb Thu Aug 08, 2013 12:02 am | |
| Ok i tore down the carb and cleaned it and went ahead and ordered new jets. After inspecting everything i noticed that the boot on top of the carb slide has a hole in it. Could this cause my problem? | |
| Subject: Re: Pressure behind carb | |
