| which tires to pick | |
+9Jet watrsmkr jmp30 Snorider rhinosport84 FLOGROWN mike734 123.bert0621 tjt603 13 posters |
tjt603
| Subject: which tires to pick Tue Sep 03, 2013 1:13 pm | |
| Iam looking for some 28" mud tires ? They are going on a 14" rim | |
Posts : 1464 Join date : 2013-03-18 Age : 65 Location : Western Quebec
| Subject: Re: which tires to pick Tue Sep 03, 2013 3:08 pm | |
| Highlifter Outlaws,30" 38.8 pounds, 14 less than Terminators, and 17 lighter than Silverbacks. Easier on you drivetrain and faster accel. | |
tjt603
| Subject: Re: which tires to pick Tue Sep 03, 2013 3:36 pm | |
| Whats better zillas or mud lites | |
Posts : 681 Join date : 2013-04-30 Age : 47 Location : Limerick P.A.
| Subject: Re: which tires to pick Tue Sep 03, 2013 4:47 pm | |
| mudlites are not a mud tire! zillas to answer your question. if you want a true mud tire stick with outlaw or silverback. zillas and mudlites are more of a aggressive all terrain tire. both tires prone to flats due to thin rubber. there light weight for a reason. | |
| Subject: Re: which tires to pick Tue Sep 03, 2013 5:12 pm | |
| Zillas,lighter,great traction real good sidewall protection, and more resistant to punctures, but they are not as smooth as XTR's and wear quicker. The favorite is Zillas. | |
| Subject: Re: which tires to pick Tue Sep 03, 2013 5:32 pm | |
| - 123.bert0621 wrote:
- Zillas,lighter,great traction real good sidewall protection, and more resistant to punctures, but they are not as smooth as XTR's and wear quicker. The favorite is Zillas.
you are the first person I have ever seen use the words good sidewall protection , resistant to punctures and zillas in the same sentence. are you confusing the zilla with the mudzilla?? | |
tjt603
| Subject: Re: which tires to pick Tue Sep 03, 2013 5:38 pm | |
| Ok let me put it this way I do trail and some mud but I want a tire that if I do hit the mud hole im not getting stuck that easy. I do like the outlaws but they seem heavy . | |
FLOGROWN
Posts : 160 Join date : 2013-07-16 Age : 47 Location : Palm Beach County Florida
| Subject: Re: which tires to pick Tue Sep 03, 2013 5:47 pm | |
| I have had nothing but good luck with my XTR's they are light weight and all I ride here in florida is mud and sand bottom water, they pull me threw most everything. I don't care if u have XTR'S, zillas, vampire, outlaws or silverbacks, if it's gonna get stuck it's gonna get stuck, my next tire is going to be the ITP Mayhems. Seen them get thru just about all florida can throw at it and are lightweight as well, I only run a max size of 27" on both rhinos. There is no need for some giant 30" tire at all. HEAVY AND PRONE TO BREAKING AXLES. I've run 30 silverbacks and 29.5 outlaws on 2 of my old grizzlys and I went thru a handful of axles, now add a lift to that scenario and change the angle of the CVs and axles and your just askin to break. But hey it's just my nickles worth of free advice. | |
| then yes mudlites , zillas , xtr`s , 589s and mega mayhem will all be good choices. imo the mega mayhems will be the best choice. | |
FLOGROWN
| Subject: Re: which tires to pick Tue Sep 03, 2013 5:52 pm | |
| X2 ^^^ but IMO I like the mayhem a little better than the mega mayhem, 1.5" lugs on em. A little more meat goes a long way with me. | |
tjt603
| Subject: Re: which tires to pick Tue Sep 03, 2013 5:53 pm | |
| Ive been thinking about going with the mayhems but have never seen them in person. | |
FLOGROWN
| Subject: Re: which tires to pick Tue Sep 03, 2013 5:58 pm | |
| I have a couple buddies running them and have been converted. They love them and I've watched them crawl outta some nasty shit. So I figure when I need new I'm gonna give them a go on my 06 660. From what I've seen and what they are telling me it's a no brainier. Plus there affordable. Only thing I don't care for is they aren't a radial but oh well. | |
| Subject: Re: which tires to pick Tue Sep 03, 2013 6:32 pm | |
you are the first person I have ever seen use the words good sidewall protection , resistant to punctures and zillas in the same sentence. are you confusing the zilla with the mudzilla?? Your right sorry, Zillas still do have pretty good sidewall though. | |
| Subject: Re: which tires to pick Wed Sep 04, 2013 1:32 pm | |
| i just bought a set of 28" zillas ive put about 200 miles on them so far an i like them they are light an handle very well on the trails they also pull good thru the mud the only thing about the zillas is they do not measure true to size my 28s are about 27s with 12 psi air in them other than that i would buy them again no prob. hope this helps ya | |
| Subject: Re: which tires to pick Wed Sep 04, 2013 1:35 pm | |
| forgot to say mine are 28s on 12" wheels so they might be true to size in a 14 but im not sure | |
Snorider
| Subject: Re: which tires to pick Wed Sep 04, 2013 3:23 pm | |
| So when referring to XTR's which ones are you referencing? | |
jmp30
| Subject: Re: which tires to pick Wed Sep 04, 2013 5:20 pm | |
| I ran 27 inch Zillas on 14 inch 212's on my Grizzly and loved them. | |
tjt603
| Subject: Re: which tires to pick Wed Sep 04, 2013 5:39 pm | |
| do the mega mayhem run true to size ? | |
| Subject: Re: which tires to pick Wed Sep 04, 2013 6:41 pm | |
| - Snorider wrote:
- So when referring to XTR's which ones are you referencing?
Mudlite XTR radials | |
| Subject: Re: which tires to pick Wed Sep 04, 2013 6:46 pm | |
| - tjt603 wrote:
- do the mega mayhem run true to size ?
I have read the 3-4 PSI 27" measured at 26.75" | |
watrsmkr
Posts : 24 Join date : 2013-03-10 Age : 66 Location : Ohio
| Subject: Re: which tires to pick Fri Sep 06, 2013 2:05 pm | |
| Running 26 inch Zillas on my 2007 660..........2 inch CFM lift .....no problems in 2 years....no loss of power or any breakage yet. No clutch mods,but hope to get a JBS sheave in the near future!!! | |
| Subject: Re: which tires to pick Fri Oct 11, 2013 8:39 pm | |
| has anyone used the ITP Terracross tires. thinking of getting them. | |
Crusty
Posts : 431 Join date : 2013-08-10 Age : 55 Location : Woods Cross Utah
| Subject: Re: which tires to pick Fri Oct 11, 2013 10:05 pm | |
| I have the 26x14-11 and 26x14-9 terracross on mine and I love them and I'm actually getting close to replacing them soon and will be buying the same tires. They are pretty aggressive and have a good rim guard and good sidewall tread as well. They were on mine when I bought it and I have put them thru Hell and have had no issues what so ever with them. | |
| Subject: Re: which tires to pick Fri Oct 11, 2013 10:25 pm | |
| Cool. I have a set of ITP 216 in 12" that I bought awhile back. Need tires for them. Have Interco Reptiles on ITP beadlocks on the Rhino now. I like the reptiles and the beadlocks but while I was on my 6 month hiatus Jack and I ordered a set. The only thing I don't like about jack is, he and I will get on eBay and the next morning I'm paying for stuff WE bought and that SOB ain't no where around. Goooooo figure. | |
| Subject: Re: which tires to pick Fri Oct 11, 2013 10:31 pm | |
| I have read review after review and the choice is almost always Bighorns over the more expensive Terracross, but more and more people are choosing Grimreapers or Pitbulls over the others.
Last edited by 123.bert0621 on Fri Oct 11, 2013 10:42 pm; edited 1 time in total | |
| Subject: Re: which tires to pick | |
