In total there are 93 users online :: 0 Registered, 0 Hidden and 93 Guests :: 1 Bot
 Rhino 700 performance Icon_minitimeWed Aug 16, 2023 1:17 pm by RADICAL RAM
 Rhino 700 performance Icon_minitimeThu Dec 14, 2017 4:54 pm by WV Hot Rod Rhino
 Rhino 700 performance Icon_minitimeThu Dec 14, 2017 1:28 am by WV Hot Rod Rhino
 Rhino 700 performance Icon_minitimeThu Dec 14, 2017 12:35 am by WV Hot Rod Rhino
 Rhino 700 performance Icon_minitimeFri Dec 13, 2013 11:01 am by WV Hot Rod Rhino
 Rhino 700 performance Icon_minitimeFri Dec 13, 2013 10:59 am by WV Hot Rod Rhino
 Rhino 700 performance Icon_minitimeFri Dec 13, 2013 9:33 am by Tacoclaw
 Rhino 700 performance Icon_minitimeFri Dec 13, 2013 7:50 am by chuddly
 Rhino 700 performance Icon_minitimeFri Dec 13, 2013 7:47 am by chuddly
 Rhino 700 performance Vote_lcap Rhino 700 performance Voting_bar Rhino 700 performance Vote_rcap
3 posters
Quadog
Quadog
 Rhino 700 performance Empty
PostSubject: Rhino 700 performance    Rhino 700 performance Icon_minitimeMon Sep 23, 2013 3:41 pm
I got an 08 700 sport with James' HR sheave with 16g OD weights, Gold spring, Dyna FS cdi, 27" mudlite XTRs on 14' wheels, & a full windshield. It will take off like a beast & run up to 47 mph on flat roads.   Does this sound about right to you guys?
I didn't clean or grease the secondary pulley when I had it apart to change the spring so I'm wondering if that could affect my top speed some or if it is about right.
chalkminer
chalkminer
PostSubject: Re: Rhino 700 performance    Rhino 700 performance Icon_minitimeMon Sep 23, 2013 3:53 pm
Is 47 mph from the speedometer on the bike?  If it is you might be going a little faster than that due to the tires.  If that is the case you may not be too far off.  Still not a bad idea to service the secondary.  Let us know if you find a little more speed when you do.
Quadog
Quadog
PostSubject: Re: Rhino 700 performance    Rhino 700 performance Icon_minitimeMon Sep 23, 2013 4:12 pm
It hits each mph just a little quicker on my gps but it's always within 1 mph. I will service the sec pulley.  My belt is the original too with 1800 miles. It sits out of the sec pulley just enough to see the ridges in the belt above the pulley. Prolly worn some but doesn't slip or anything. May be a extra mph or 2 there also but don't know if it's worth it. It only matters when I bust out on the county roads with the Rzrs. They make me hold it to the floor just to keep them in sight.  They can't lose me on the trails tho.
PostSubject: Re: Rhino 700 performance    Rhino 700 performance Icon_minitimeMon Sep 23, 2013 4:23 pm
I'd say you are not too far off. You have 27" MudLight XTRs which are on the heavier side as they are radial construction tires. You also have a full windshield which will kill speed. The windshields are nice at times but they kill top speed. My buddy's Rhino has a JBS sheave and 27" XTRs and no other mods. It will do 49-50mph on a flat road. I bet if he put a windshield on he'd lose another mph or so.
» My Little Rhino
» My 07 Rhino
» New Cab for the Rhino
» My Rhino vs RZR
» Cam for rhino
