In total there are 18 users online :: 0 Registered, 0 Hidden and 18 Guests :: 1 Bot
2007 rhino 660 18.0 af at wot Icon_minitimeWed Aug 16, 2023 1:17 pm by RADICAL RAM
2007 rhino 660 18.0 af at wot Icon_minitimeThu Dec 14, 2017 4:54 pm by WV Hot Rod Rhino
2007 rhino 660 18.0 af at wot Icon_minitimeThu Dec 14, 2017 1:28 am by WV Hot Rod Rhino
2007 rhino 660 18.0 af at wot Icon_minitimeThu Dec 14, 2017 12:35 am by WV Hot Rod Rhino
2007 rhino 660 18.0 af at wot Icon_minitimeFri Dec 13, 2013 11:01 am by WV Hot Rod Rhino
2007 rhino 660 18.0 af at wot Icon_minitimeFri Dec 13, 2013 10:59 am by WV Hot Rod Rhino
2007 rhino 660 18.0 af at wot Icon_minitimeFri Dec 13, 2013 9:33 am by Tacoclaw
2007 rhino 660 18.0 af at wot Icon_minitimeFri Dec 13, 2013 7:50 am by chuddly
2007 rhino 660 18.0 af at wot Icon_minitimeFri Dec 13, 2013 7:47 am by chuddly
2007 rhino 660 18.0 af at wot Vote_lcap2007 rhino 660 18.0 af at wot Voting_bar2007 rhino 660 18.0 af at wot Vote_rcap
Foxman92
6 posters
Foxman92
2007 rhino 660 18.0 af at wot Empty
PostSubject: 2007 rhino 660 18.0 af at wot   2007 rhino 660 18.0 af at wot Icon_minitimeSun Oct 27, 2013 6:21 pm
Ok had some issues a while back, broke 3 motor mounts and because if that the filter on my k&n volecity intake got a big hole in it from rubbing on my shifter linkage, fixed mounts and made this custom intake
.nm will have to post intske image later, though forum could host it****
Foxman92
PostSubject: Re: 2007 rhino 660 18.0 af at wot   2007 rhino 660 18.0 af at wot Icon_minitimeSun Oct 27, 2013 6:25 pm
Now at wide open af goes 18.0 and engine starts sputtering real bad.. I have a wideband and idle its at about 13.0, upped the main jet from 155 to 170, no change, after talking to jbs i checked the woodruff key and tdc on flywheel the piston is on tdc.. Any ideas what would cause this thing to go so lean at wot, still lean with just open carb no filter or intake pipe
PostSubject: Re: 2007 rhino 660 18.0 af at wot   2007 rhino 660 18.0 af at wot Icon_minitimeSun Oct 27, 2013 6:57 pm
with the carb open and no filter you are just making it take in more air and leaning it out even more, what elevation are you at
PostSubject: Re: 2007 rhino 660 18.0 af at wot   2007 rhino 660 18.0 af at wot Icon_minitimeSun Oct 27, 2013 10:14 pm
I agree, taking the air filter off will lean it even more.  are you sure the jet you changed was a 170? we used to drill our jets so the number on them didn't matter...  Might want to see if you can mic them some way or drill them the right size..
Also, check for an air leak on your intake side..
Foxman92
PostSubject: Re: 2007 rhino 660 18.0 af at wot   2007 rhino 660 18.0 af at wot Icon_minitimeMon Oct 28, 2013 12:29 am
Positive the jet is a 170, checked with brake clean no vacuum leaks after carb, its like the main jet isnt working, it doesnt make any sense
PostSubject: Re: 2007 rhino 660 18.0 af at wot   2007 rhino 660 18.0 af at wot Icon_minitimeMon Oct 28, 2013 12:35 am
fuel pump??
Foxman92
PostSubject: Re: 2007 rhino 660 18.0 af at wot   2007 rhino 660 18.0 af at wot Icon_minitimeMon Oct 28, 2013 3:24 am
WV Hot Rod Rhino wrote:
fuel pump??
Tried 2 different pumps same problem
PostSubject: Re: 2007 rhino 660 18.0 af at wot   2007 rhino 660 18.0 af at wot Icon_minitimeMon Oct 28, 2013 8:43 am
fuel pick-up line , filter
PostSubject: Re: 2007 rhino 660 18.0 af at wot   2007 rhino 660 18.0 af at wot Icon_minitimeMon Oct 28, 2013 11:59 am
could be pick up for sure
Foxman92
PostSubject: Re: 2007 rhino 660 18.0 af at wot   2007 rhino 660 18.0 af at wot Icon_minitimeMon Oct 28, 2013 2:48 pm
Pick ups fine along with filter
Pick up tube is fine and so is filter
PostSubject: Re: 2007 rhino 660 18.0 af at wot   2007 rhino 660 18.0 af at wot Icon_minitimeMon Oct 28, 2013 2:59 pm
have you taken the carb apart and cleaned it?
if you had a hole in the filter it may have sucked something into the wot circuit of the carb.
Foxman92
PostSubject: Re: 2007 rhino 660 18.0 af at wot   2007 rhino 660 18.0 af at wot Icon_minitimeMon Oct 28, 2013 4:04 pm
Yea i havent do that yet, thats what im going to do today, its just weird i drove it on the street with no filter open carb snd everything was fine, started it a couple times to move it around, then built custom intake that puts filter under shifter sticking out by my feet and now it wont rev.. Really strange
PostSubject: Re: 2007 rhino 660 18.0 af at wot   2007 rhino 660 18.0 af at wot Icon_minitimeMon Oct 28, 2013 7:34 pm
this filter you put on could it be causing a air restriction, also what size pipe did you run in place of air box
PostSubject: Re: 2007 rhino 660 18.0 af at wot   2007 rhino 660 18.0 af at wot Icon_minitimeMon Oct 28, 2013 8:12 pm
without the air box it might not be creating enough vacuum to open the carb slide , the slide is opend by vacuum not by puching the skinny pedal, just my guess
Foxman92
PostSubject: Re: 2007 rhino 660 18.0 af at wot   2007 rhino 660 18.0 af at wot Icon_minitimeTue Oct 29, 2013 12:35 am
Same size pipe as the k&n volecity, 2", filter is a off the shelf spectre, slide on carb opens with out intake or filter on so dont think that is it, going to clean carb and triple check everything this weekend, got a pretty cool trade offer of a 686 motor for trade for my stock 660, 686 has a broken rocker. Most likely from coil bind going to look in to that, also getting a hsr 45 carb. Just need to get mine running better first
Foxman92
PostSubject: Re: 2007 rhino 660 18.0 af at wot   2007 rhino 660 18.0 af at wot Icon_minitimeSat Nov 02, 2013 12:39 am
Ok figured it out, pulled the slide part of the carb apart, cleaned and reassembled, now with 170 main jet air fuel is 10.5. Time to ho back to 150 and go have some fun!!
PostSubject: Re: 2007 rhino 660 18.0 af at wot   2007 rhino 660 18.0 af at wot Icon_minitimeSat Nov 02, 2013 9:17 am
was the slide not opening? or just sticking
Foxman92
PostSubject: Re: 2007 rhino 660 18.0 af at wot   2007 rhino 660 18.0 af at wot Icon_minitimeSat Nov 02, 2013 1:53 pm
Sticking i think, i know it was opening before, just must not have been opening enough
PostSubject: Re: 2007 rhino 660 18.0 af at wot   2007 rhino 660 18.0 af at wot Icon_minitimeSat Nov 02, 2013 5:27 pm
is she runnin ok now?
» 2007 Rhino 660 Squeak
» 2007 long travel 660 rhino
» 2007 Yamaha Rhino full custom with tracks
» My Little Rhino
» My 07 Rhino
