In total there are 58 users online :: 0 Registered, 0 Hidden and 58 Guests :: 1 Bot
Yamaha Rhino Factory Sport Shock Settings & Hot Rod's Tips. Icon_minitimeWed Aug 16, 2023 1:17 pm by RADICAL RAM
Yamaha Rhino Factory Sport Shock Settings & Hot Rod's Tips. Icon_minitimeThu Dec 14, 2017 4:54 pm by WV Hot Rod Rhino
Yamaha Rhino Factory Sport Shock Settings & Hot Rod's Tips. Icon_minitimeThu Dec 14, 2017 1:28 am by WV Hot Rod Rhino
Yamaha Rhino Factory Sport Shock Settings & Hot Rod's Tips. Icon_minitimeThu Dec 14, 2017 12:35 am by WV Hot Rod Rhino
Yamaha Rhino Factory Sport Shock Settings & Hot Rod's Tips. Icon_minitimeFri Dec 13, 2013 11:01 am by WV Hot Rod Rhino
Yamaha Rhino Factory Sport Shock Settings & Hot Rod's Tips. Icon_minitimeFri Dec 13, 2013 10:59 am by WV Hot Rod Rhino
Yamaha Rhino Factory Sport Shock Settings & Hot Rod's Tips. Icon_minitimeFri Dec 13, 2013 9:33 am by Tacoclaw
Yamaha Rhino Factory Sport Shock Settings & Hot Rod's Tips. Icon_minitimeFri Dec 13, 2013 7:50 am by chuddly
Yamaha Rhino Factory Sport Shock Settings & Hot Rod's Tips. Icon_minitimeFri Dec 13, 2013 7:47 am by chuddly
Yamaha Rhino Factory Sport Shock Settings & Hot Rod's Tips. Vote_lcapYamaha Rhino Factory Sport Shock Settings & Hot Rod's Tips. Voting_barYamaha Rhino Factory Sport Shock Settings & Hot Rod's Tips. Vote_rcap
Mauser69
9 posters
Yamaha Rhino Factory Sport Shock Settings & Hot Rod's Tips. Empty
PostSubject: Yamaha Rhino Factory Sport Shock Settings & Hot Rod's Tips.   Yamaha Rhino Factory Sport Shock Settings & Hot Rod's Tips. Icon_minitimeThu Mar 14, 2013 12:47 am
Wanted to make this info it's own thread & sticky it study
Factory Settings ...
Front Compression - 10 Clicks Out
Front Rebound - 10 Clicks Out
Rear Compression - 7 Clicks Out
Rear Rebound - 12 Clicks Out
I recommend 5 clicks out on Rear Rebound & 9 clicks out on the Front Compression, the other 2 are the same. Then you can give her hell!!! lol
PostSubject: Re: Yamaha Rhino Factory Sport Shock Settings & Hot Rod's Tips.   Yamaha Rhino Factory Sport Shock Settings & Hot Rod's Tips. Icon_minitimeThu Mar 14, 2013 3:07 am
Is that clicks out from the stiffest setting or softest?
PostSubject: Re: Yamaha Rhino Factory Sport Shock Settings & Hot Rod's Tips.   Yamaha Rhino Factory Sport Shock Settings & Hot Rod's Tips. Icon_minitimeMon Mar 18, 2013 7:26 pm
probably turn them clockwise all the way in...then count the clicks counter clockwise out,not sure but james will chime in and let us know.
Mauser69
Mauser69
PostSubject: Re: Yamaha Rhino Factory Sport Shock Settings & Hot Rod's Tips.   Yamaha Rhino Factory Sport Shock Settings & Hot Rod's Tips. Icon_minitimeSat Mar 30, 2013 12:02 pm
Hope this is not out of place in this thread. I have 07 660 Sport Edition- the title sounds like it applies to me. I have not been able to find info on how the Sport differs from base Rhino;can anyone help me with that?
I have seen a lot of posts about needing to upgrade Rhino suspension, but this makes me wonder if the Sport suspension is considered better than normal Rhinos (maybe even good)?
Are there any quick clues to tell if my shocks are stock? I know the PO modded my ride with K&N intake, horribly loud exhaust and a really stupid but very expensive sat radio w monster amp, so I suspect there are plenty of other mods as well.
PostSubject: Re: Yamaha Rhino Factory Sport Shock Settings & Hot Rod's Tips.   Yamaha Rhino Factory Sport Shock Settings & Hot Rod's Tips. Icon_minitimeSat Mar 30, 2013 12:14 pm
The sport edition shocks will have external resivoirs at the top of the shocks,and screws at the top and bottom to adjust compression and rebound.alot better shocks than regular rhino shocks!!
PostSubject: Re: Yamaha Rhino Factory Sport Shock Settings & Hot Rod's Tips.   Yamaha Rhino Factory Sport Shock Settings & Hot Rod's Tips. Icon_minitimeMon Apr 01, 2013 6:27 pm
Is this the same setup for my 2013 Special Edition.
PostSubject: Re: Yamaha Rhino Factory Sport Shock Settings & Hot Rod's Tips.   Yamaha Rhino Factory Sport Shock Settings & Hot Rod's Tips. Icon_minitimeMon Apr 01, 2013 7:05 pm
ok which is the Compression and which is the Rebound ?
http://www.trailbrightled.com
PostSubject: Re: Yamaha Rhino Factory Sport Shock Settings & Hot Rod's Tips.   Yamaha Rhino Factory Sport Shock Settings & Hot Rod's Tips. Icon_minitimeMon Apr 01, 2013 7:47 pm
top is compression,,bottom is rebound
PostSubject: Re: Yamaha Rhino Factory Sport Shock Settings & Hot Rod's Tips.   Yamaha Rhino Factory Sport Shock Settings & Hot Rod's Tips. Icon_minitimeMon Apr 01, 2013 8:48 pm
Factory my fronts were 10 and my rears were 13.
PostSubject: Re: Yamaha Rhino Factory Sport Shock Settings & Hot Rod's Tips.   Yamaha Rhino Factory Sport Shock Settings & Hot Rod's Tips. Icon_minitimeMon Apr 01, 2013 9:37 pm
RedRhino64 thanks
PostSubject: Re: Yamaha Rhino Factory Sport Shock Settings & Hot Rod's Tips.   Yamaha Rhino Factory Sport Shock Settings & Hot Rod's Tips. Icon_minitimeTue Apr 02, 2013 3:31 am
I believe so. Looked to be the same to me. Look it up in your owners manual to see how to adjust, they have marks on them for the factory settings. You can go said number of clicks softer or firmer. I started with the softest settings and I'm working my way up as I ride when I need to firm it up a little. These are nice shocks.
PostSubject: Re: Yamaha Rhino Factory Sport Shock Settings & Hot Rod's Tips.   Yamaha Rhino Factory Sport Shock Settings & Hot Rod's Tips. Icon_minitimeTue Apr 02, 2013 11:04 am
I adjusted them the way the original post shows but I haven't had a chance to ride it yet, probably tomorrow after work. I do bottom out quite a bit with the fronts.
PostSubject: Re: Yamaha Rhino Factory Sport Shock Settings & Hot Rod's Tips.   Yamaha Rhino Factory Sport Shock Settings & Hot Rod's Tips. Icon_minitimeSat Apr 06, 2013 6:37 pm
Great help thanks,working on it now.
PostSubject: Re: Yamaha Rhino Factory Sport Shock Settings & Hot Rod's Tips.   Yamaha Rhino Factory Sport Shock Settings & Hot Rod's Tips. Icon_minitimeSun Apr 07, 2013 12:54 am
Followed the instructions,going on a ride next weekend I found my settings were all over the place somebody must have been trying to tune it by trial and error,(used).
PostSubject: Re: Yamaha Rhino Factory Sport Shock Settings & Hot Rod's Tips.   Yamaha Rhino Factory Sport Shock Settings & Hot Rod's Tips. Icon_minitimeSat May 18, 2013 10:06 pm
I followed James recommendation and the handling was more stable with less rear end kicking up over jumps. Very Happy
PostSubject: Re: Yamaha Rhino Factory Sport Shock Settings & Hot Rod's Tips.   Yamaha Rhino Factory Sport Shock Settings & Hot Rod's Tips. Icon_minitimeSun May 26, 2013 8:35 pm
im looking for them to be a bit more stiff... i have the springs turned all the way up in the rear and half way in the front... where should i set the two other screws so they dont travel as much... i want a stiffer ride....
PostSubject: Re: Yamaha Rhino Factory Sport Shock Settings & Hot Rod's Tips.   Yamaha Rhino Factory Sport Shock Settings & Hot Rod's Tips. Icon_minitimeSun Nov 17, 2013 11:15 pm
Thanks Hot Rod. Dancing Banana
» Factory Yamaha sport roof
» Sport resi shock HELP
» Blown Sport Resi Shocks from 2011 Rhino Sport
» Stock inner rhino tie rods
» Shock suggestions? 700 rhino
