| Progressive Problems? | |
UnderDawg
| Subject: Progressive Problems? Fri Nov 01, 2013 9:42 pm | |
| I just installed a set of Progressive 425 HD shocks only to find out they rub the axles. I even took off the lift and they still rub. Has anyone else had this problem? Any ideas for a solution???? The only thing I can come up with is chit-can the rear shocks or move the lower shock mounts. Son of a BITCH!!! | |
| Subject: Re: Progressive Problems? Fri Nov 01, 2013 11:52 pm | |
| yea I think u right move the bottom shock mount over | |
| Subject: Re: Progressive Problems? Sat Nov 02, 2013 12:02 am | |
| Those brown axles are bigger in diameter , than the oe...that's part of the problem...that shock base looks huge !!....dunno...Are you only having a problem on that side ?? | |
| Subject: Re: Progressive Problems? Sat Nov 02, 2013 12:12 am | |
| Your A-arm mount could be bent to. | |
| Subject: Re: Progressive Problems? Sat Nov 02, 2013 12:21 am | |
| it's prob twisted , like you Teddy !!... | |
UnderDawg
| Subject: Re: Progressive Problems? Sat Nov 02, 2013 1:36 am | |
| Thanks for the response guys!
Scott, your right the shock bases are a lot bigger than stock and rubbed a little on both side till I took off the lift. I didn't have time to check diameter of the axle but will get the caliper out in the AM.
After I check a few things in the morning, I think my best option is to cut the bushing down some and shim the shock over...any thoughts on this would be appreciated | |
| Subject: Re: Progressive Problems? Sat Nov 02, 2013 9:14 am | |
| - UnderDawg wrote:
- Thanks for the response guys!
After I check a few things in the morning, I think my best option is to cut the bushing down some and shim the shock over...any thoughts on this would be appreciated that's what I was thinking, grind maybe an 1/8-3/16 and shim the shock over prolly the easyest | |
| Subject: Re: Progressive Problems? Sat Nov 02, 2013 1:32 pm | |
| How much difference did the progressive's make ? Do You like them ? Thinking about a set for mine. | |
| Subject: Re: Progressive Problems? Sat Nov 02, 2013 2:27 pm | |
| looks like the head of the shocks bolt my be rubbing the axle too u might have to change that to a thinner head style or grind alittle on it also | |
UnderDawg
| Subject: Re: Progressive Problems? Sat Nov 02, 2013 3:41 pm | |
| - Firefighter wrote:
- How much difference did the progressive's make ? Do You like them ? Thinking about a set for mine.
Firefighter, I haven't had a chance to run 'em yet, but heading out to the camp shortly. will give them a full workout and report back tomorrow night. | |
UnderDawg
| Subject: Re: Progressive Problems? Sat Nov 02, 2013 4:03 pm | |
| - madmax 1 wrote:
- looks like the head of the shocks bolt my be rubbing the axle too u might have to change that to a thinner head style or grind alittle on it also
I'll keep an eye on that this weekend.. By the way, the new Jensen is working great! | |
| Subject: Re: Progressive Problems? Sat Nov 02, 2013 5:18 pm | |
| great man glade to hear it | |
UnderDawg
| Subject: Re: Progressive Problems? Tue Nov 05, 2013 2:24 am | |
| After cutting down the bushing and shimming over the shock 2mm, I took it out to the camp a ride. They ride ten times GOODER than the stockers and no more rubbing. | |
| Subject: Re: Progressive Problems? Tue Nov 05, 2013 9:18 am | |
| if the knuckle is upside down it will rub too!! | |
| Subject: Re: Progressive Problems? | |
