In total there are 65 users online :: 0 Registered, 0 Hidden and 65 Guests :: 1 Bot
something not good Icon_minitimeWed Aug 16, 2023 1:17 pm by RADICAL RAM
something not good Icon_minitimeThu Dec 14, 2017 4:54 pm by WV Hot Rod Rhino
something not good Icon_minitimeThu Dec 14, 2017 1:28 am by WV Hot Rod Rhino
something not good Icon_minitimeThu Dec 14, 2017 12:35 am by WV Hot Rod Rhino
something not good Icon_minitimeFri Dec 13, 2013 11:01 am by WV Hot Rod Rhino
something not good Icon_minitimeFri Dec 13, 2013 10:59 am by WV Hot Rod Rhino
something not good Icon_minitimeFri Dec 13, 2013 9:33 am by Tacoclaw
something not good Icon_minitimeFri Dec 13, 2013 7:50 am by chuddly
something not good Icon_minitimeFri Dec 13, 2013 7:47 am by chuddly
something not good Vote_lcapsomething not good Voting_barsomething not good Vote_rcap
 something not good
DEZLFREK
6 posters
DEZLFREK
something not good Empty
PostSubject: something not good   something not good Icon_minitimeThu Mar 21, 2013 12:22 am
well i finally got to taking my machine apart thinking that i stripped the sheeve camplate in my ignorance of doing the wieghted wet clutch. With my luck everything to do with that work was lost in the mail last week so i thought it was going to be a fast switch the clutch parts and whatnot but as it turns out its something more.
maybe you guys can help me diagnose what it is. Im thinking maybe the through shaft but i might be worse like the middle drive gears? i could barely give it throttle and it would clunk, not move. In every gear. it happened going up a hill slow in low. Every time i would barely give it throttle it would sound like a stripped gear.
Anyway i had the sheeve off and put it in gear so i could spin the secondary and well with a wrench and the brake on i could get it to slip/clunk also..
so what do you guys think it is, through shaft or middle drive gears? its deffinetly in the trans area..
im at a loss what to do next to fix it. i would rather not pull the motor if its the through shaft but obviously if i have to pull the motor thats the next step to get it going again.. Im going through withdrawl..
DEZLFREK
PostSubject: Re: something not good   something not good Icon_minitimeThu Mar 21, 2013 2:48 am
im thinking i seems like a gear and leaning toward the middle drive gear but hopefully someone can give me a clue so i know to pull the motor and order more parts...
PostSubject: Re: something not good   something not good Icon_minitimeThu Mar 21, 2013 9:08 am
I would take it to a good rhino mechanic and let him diagnos it before you tear it all the way down. getting into the trans is not for the hobbiest.
Last edited by Stuntmanmike on Thu Mar 21, 2013 9:09 am; edited 1 time in total (Reason for editing : cant spell)
Mrs. Hot Rod
Mrs. Hot Rod
PostSubject: Re: something not good   something not good Icon_minitimeThu Mar 21, 2013 9:43 am
that sux...let us know what you find
DEZLFREK
PostSubject: Re: something not good   something not good Icon_minitimeThu Mar 21, 2013 1:30 pm
im pulling the motor so ill let you know asap.
gotta start someplace.. and yes this sux azz..
PostSubject: Re: something not good   something not good Icon_minitimeThu Mar 21, 2013 7:56 pm
buddy of mine stripped his drive shaft where it goes into the back of the motor,his was making a clunking noise,then he put it in 4wd and it would go.
DEZLFREK
PostSubject: Re: something not good   something not good Icon_minitimeFri Mar 22, 2013 2:01 am
found the problem.. not good..
something not good 20130321_192711_zps6cda1e04
something not good 20130321_192752_zpsca5b3723
JOHN DILLARD
JOHN DILLARD
PostSubject: Re: something not good   something not good Icon_minitimeFri Mar 22, 2013 7:51 am
Hey that looks like front output shaft the bolt laying in the bottom holds the bearing retainer in.mine done that.motor has to come completely apart to repair. Lots of little parts in there and it is not a job for a hobbiest.but if you have a manual and some mechanical knowledge you can do it make sure to locktite all bolts.call James he can send parts .
PostSubject: Re: something not good   something not good Icon_minitimeFri Mar 22, 2013 8:53 am
i have posted on this a couple times....bolts back out of the center diff support!!!...........that sux!!
DEZLFREK
PostSubject: Re: something not good   something not good Icon_minitimeFri Mar 22, 2013 10:19 pm
I called you a couple times James. I obviously need to order more parts and my clutch still didnt show up so hopefully it didnt get lost again..
talk to you soon..
something not good
» Well I'm here for good
» where can i get a good sheave
» A good spot to be in
» good seats....
» Site looking good
