| What secondery spring to use | |
+4WV Hot Rod Rhino Hump REDRHINO64 T.Rhino 8 posters |
| Subject: What secondery spring to use Tue Mar 26, 2013 2:38 pm | |
| Why are some people changing from the gold secondery spring to the purple on the 700 ? | |
| Subject: Re: What secondery spring to use Tue Mar 26, 2013 6:47 pm | |
| Subject: Re: What secondery spring to use Tue Mar 26, 2013 6:55 pm | |
| Less tension lets it spool up faster,too much friction takes away hp. | |
| Subject: Re: What secondery spring to use Tue Mar 26, 2013 7:18 pm | |
| So the purple is better then right ? I guess I'm just confused cause it use to be that the gold was the big rave now people are going with the purple so why isn't the stock spring better then ? Sorry for all the questions. | |
| Subject: Re: What secondery spring to use Tue Mar 26, 2013 7:27 pm | |
| You want to run the lightest spring u can without slipping the belt,then use the weights to get the rpm range that is best for your setup,but i would check with james on that,your motor and his are very close on the setup. | |
| Subject: Re: What secondery spring to use Tue Mar 26, 2013 7:32 pm | |
| I agree he built my motor they are twins mine is just a little faster though. Lol | |
| Subject: Re: What secondery spring to use Tue Mar 26, 2013 7:45 pm | |
| We will have to get together at james place and ride sometime!! and scott wv!! | |
| Subject: Re: What secondery spring to use Tue Mar 26, 2013 8:14 pm | |
| Sure sounds great how far are you from James's place ? | |
| Subject: Re: What secondery spring to use Tue Mar 26, 2013 8:19 pm | |
| around 200 miles,but i am going to try to get up there either in april or may,cant wait to check out the new house,and ride!! | |
| Subject: Re: What secondery spring to use Tue Mar 26, 2013 8:37 pm | |
| House is beautiful and the ride is awsome. I'm about 2 hours away from him and about 4 hours away from you I thank. But it would be cool to get together though. | |
| Subject: Re: What secondery spring to use Tue Mar 26, 2013 8:40 pm | |
| Cool!! Hopefully we will!! | |
| Subject: Re: What secondery spring to use Wed Mar 27, 2013 4:33 am | |
| I wanna ride too!
I still don't understand the whole deal with the springs, but I know I like the feel of what I have now on a hill. It's a real positive hooked up feel when I get to the gas. | |
| Subject: Re: What secondery spring to use Wed Mar 27, 2013 9:40 pm | |
| - RedRhino64 wrote:
- You want to run the lightest spring u can without slipping the belt,then use the weights to get the rpm range that is best for your setup,but i would check with james on that,your motor and his are very close on the setup.
James what is your opinion on this ? | |
| Subject: Re: What secondery spring to use Wed Mar 27, 2013 9:43 pm | |
| And I was also wondering about mixing 14 gram and 16 gram weights to make 15. What is your thoughts ? | |
| Subject: Re: What secondery spring to use Thu Mar 28, 2013 9:33 am | |
| Subject: Re: What secondery spring to use Thu Mar 28, 2013 9:37 am | |
| - T.Rhino wrote:
James what is your opinion on this ? right on the money.this is to find the best overall performance...if you want it more for what the rider wants... hills mud ect then you change it from that base line | |
| Subject: Re: What secondery spring to use Thu Mar 28, 2013 10:26 am | |
| So what would be best for fast trail riding. And would the 15 gram weights help with that ? | |
| Subject: Re: What secondery spring to use Thu Mar 28, 2013 10:41 am | |
| i run 14gr and it turns alot of rpms and its nasty fast but you better be changing the oil more or it wont last!..im in race mode all the time!!...im ordering 15s | |
RiverRat
| Subject: Re: What secondery spring to use Fri Mar 29, 2013 9:31 pm | |
| James what secondary spring are you running? | |
| Subject: Re: What secondery spring to use Sun Mar 31, 2013 3:02 pm | |
| He is running the purple spring that's what got me wondering our motors are pretty close so I was wondering why he went from the gold to the purple and is it better. I guess he likes the purple better for his set up though. | |
| Subject: Re: What secondery spring to use Sun Mar 31, 2013 9:36 pm | |
| How about this set up.... 16g weights, JBS sheave, and gold spring.... 29.5 terminators...... I find it revs up high before it starts to pull, but when it pulls it pulls hard... Next mod soon is Cam and MSD this week.... Clutch set up will still be good????? | |
| Subject: Re: What secondery spring to use Tue Apr 02, 2013 2:51 pm | |
| You probably are faster now that JAmes engine is kaput lol.. | |
| Subject: Re: What secondery spring to use Tue Apr 02, 2013 4:56 pm | |
| Subject: Re: What secondery spring to use | |
