In total there are 92 users online :: 0 Registered, 0 Hidden and 92 Guests :: 2 Bots
I need a tool bad Icon_minitimeWed Aug 16, 2023 1:17 pm by RADICAL RAM
I need a tool bad Icon_minitimeThu Dec 14, 2017 4:54 pm by WV Hot Rod Rhino
I need a tool bad Icon_minitimeThu Dec 14, 2017 1:28 am by WV Hot Rod Rhino
I need a tool bad Icon_minitimeThu Dec 14, 2017 12:35 am by WV Hot Rod Rhino
I need a tool bad Icon_minitimeFri Dec 13, 2013 11:01 am by WV Hot Rod Rhino
I need a tool bad Icon_minitimeFri Dec 13, 2013 10:59 am by WV Hot Rod Rhino
I need a tool bad Icon_minitimeFri Dec 13, 2013 9:33 am by Tacoclaw
I need a tool bad Icon_minitimeFri Dec 13, 2013 7:50 am by chuddly
I need a tool bad Icon_minitimeFri Dec 13, 2013 7:47 am by chuddly
I need a tool bad Vote_lcapI need a tool bad Voting_barI need a tool bad Vote_rcap
 I need a tool bad
4 posters
I need a tool bad Empty
PostSubject: I need a tool bad   I need a tool bad Icon_minitimeTue Apr 02, 2013 11:06 am
I need the tool to take the bearing out of the pinion housing. Whatever will fit those splines to unscrew that nut. Any help??
PostSubject: Re: I need a tool bad   I need a tool bad Icon_minitimeThu Apr 04, 2013 11:02 pm
Sorry Banchee6, doesn't look like anyone knows or has that tool. Can you post what your lookin for?
southark
southark
PostSubject: Re: I need a tool bad   I need a tool bad Icon_minitimeThu Apr 04, 2013 11:19 pm
I used a hammer and a chisel to back that big splines out of the ones that I have rebuilt.
Yamahammer
PostSubject: Re: I need a tool bad   I need a tool bad Icon_minitimeSat Apr 06, 2013 10:12 am
I welded a 1 1/2 to 1 1/4 pipe reducer to a socket and the out side fit perfect on a 450 foreman. I just to diff case to hardware store tell I found something that fit. Also had to grind inside treads out alittle
PostSubject: Re: I need a tool bad   I need a tool bad Icon_minitimeSat Apr 06, 2013 12:01 pm
Yea. I pulled the seal off and cleaned it and inspected it all good. Looks like my rear diff wasn't my issue. Got it all sealed back up and on the rhino already. Next one we pull down I may get a picture so we can see what I'm talking about.
I need a tool bad
» What's in your tool bag?
» tool....
» How To Change Your Secondary Spring W/Out A Tool
