In total there are 62 users online :: 0 Registered, 0 Hidden and 62 Guests :: 1 Bot
What kind of tire pressure are you running, and why? - Page 2 Icon_minitimeWed Aug 16, 2023 1:17 pm by RADICAL RAM
What kind of tire pressure are you running, and why? - Page 2 Icon_minitimeThu Dec 14, 2017 4:54 pm by WV Hot Rod Rhino
What kind of tire pressure are you running, and why? - Page 2 Icon_minitimeThu Dec 14, 2017 1:28 am by WV Hot Rod Rhino
What kind of tire pressure are you running, and why? - Page 2 Icon_minitimeThu Dec 14, 2017 12:35 am by WV Hot Rod Rhino
What kind of tire pressure are you running, and why? - Page 2 Icon_minitimeFri Dec 13, 2013 11:01 am by WV Hot Rod Rhino
What kind of tire pressure are you running, and why? - Page 2 Icon_minitimeFri Dec 13, 2013 10:59 am by WV Hot Rod Rhino
What kind of tire pressure are you running, and why? - Page 2 Icon_minitimeFri Dec 13, 2013 9:33 am by Tacoclaw
What kind of tire pressure are you running, and why? - Page 2 Icon_minitimeFri Dec 13, 2013 7:50 am by chuddly
What kind of tire pressure are you running, and why? - Page 2 Icon_minitimeFri Dec 13, 2013 7:47 am by chuddly
What kind of tire pressure are you running, and why? - Page 2 Vote_lcapWhat kind of tire pressure are you running, and why? - Page 2 Voting_barWhat kind of tire pressure are you running, and why? - Page 2 Vote_rcap
lost|concept
Snorhino
Garnog
varmint10
hymarker
18 posters
Go to page : Previous  1, 2
What kind of tire pressure are you running, and why? - Page 2 Empty
PostSubject: Re: What kind of tire pressure are you running, and why?   What kind of tire pressure are you running, and why? - Page 2 Icon_minitimeMon May 06, 2013 12:29 am
I'm running 26x9-14 and 26x11-14 as well at 12psi and like it. I haven't ran any other pressure yet, I have about 250 miles on these so far. I also runs lots of highway, its about a 4 mile round trip on the pavement every time I ride to get to where I ride.
What kind of tire pressure are you running, and why? - Page 2 IMG_20130504_1005261_zpsa784c381
UnderDawg
UnderDawg
PostSubject: Re: What kind of tire pressure are you running, and why?   What kind of tire pressure are you running, and why? - Page 2 Icon_minitimeMon May 06, 2013 12:41 am
I'm running 6 ta 8 psi in the outlaws and 10 in the X-lites to help smooth them out.
I'm looking at buying a set of bighorns or moto's in 14's is there any advantages over the 12'' rims?
Chief1979
PostSubject: Re: What kind of tire pressure are you running, and why?   What kind of tire pressure are you running, and why? - Page 2 Icon_minitimeMon May 06, 2013 10:00 am
I'm running 25x7x12 and 25x9x12 Dirt Tamers on superatv wheels. I'm running about 7.5 psi's all around. I run them that way because the sidewall says 36psi max for install, and run @ 7-8 psi.
I like the way the tire flexes over obstacles, but its still stiff enough for riding at speed. If the set-up sounds wrong, let me know.
PostSubject: Re: What kind of tire pressure are you running, and why?   What kind of tire pressure are you running, and why? - Page 2 Icon_minitimeMon May 06, 2013 10:14 am
12-14 in the front and 14-16 in the rear or i get sidewall punctures...thats for going 40 in the rocks....lol
PostSubject: Re: What kind of tire pressure are you running, and why?   What kind of tire pressure are you running, and why? - Page 2 Icon_minitimeWed May 08, 2013 12:57 am
I run 26x10x12 mud lite front @ 12 psi , 26x12x12 mudlite rear @ 14psi
PostSubject: Re: What kind of tire pressure are you running, and why?   What kind of tire pressure are you running, and why? - Page 2 Icon_minitimeWed May 08, 2013 3:42 am
It all depends on how hard you drive. If you slow down for the rough stuff to avoid hard hits, low psi is good. I used to drive that way, then I went to the JBS hot rod driving school. LOL If you run hard everywhere and only slow down enough to keep control of your ride, then you better run at least 12 all around. Sliding across a rut in a turn, or hitting a rock will knock a tire down if you are running in the single digits at high speeds. When I ride alone, or lead the pack, I run a little lower psi to get traction. If I'm in a group trying to keep up and it's fast, I run 12-14. Traction suffers, but I come home with my tires still holding air.
» best size and kind of tire on rhino
» Trying New tire
» Tire size?
» Best tire deals
» atv tire weight chart
