| Putting in gauges | |
+22Pokahpolice REDRHINO64 lost|concept rhino727 RiverRat madmax 1 pageandbeth banchee6 Spanky bubba53 T.Rhino Snorhino WV Hot Rod Rhino CUSTOMIZEDRHINO13 ChrisH foyota86 tjt603 onebuilder Randy3451 KJrhino Firefighter Ss74077 26 posters |
Ss74077
Posts : 12 Join date : 2013-03-21
| Subject: Putting in gauges Sun Apr 07, 2013 7:59 pm | |
| I'm putting in a set of gauges. I was wondering if someone had any pics of there setup | |
| Subject: Re: Putting in gauges Sun Apr 07, 2013 8:25 pm | |
| Mine are poor boy simple, but work great ! | |
Ss74077
| Subject: Re: Putting in gauges Sun Apr 07, 2013 8:44 pm | |
| I't look's good to me if you don't mind me asking how did you do the wiring | |
| Subject: Re: Putting in gauges Sun Apr 07, 2013 8:46 pm | |
| Pretty simple. Lights and power are connected to key switch. Volts is connected to primary battery and temp is connected to sending unit I installed in the radiator hose | |
Ss74077
| Subject: Re: Putting in gauges Sun Apr 07, 2013 9:14 pm | |
| Thanks just trying to get ideas on the best way to do this project | |
| Subject: Re: Putting in gauges Sun Apr 07, 2013 11:02 pm | |
| firefighter what type of gauges are they brand and auto or marine? did you just use some pipe fitting for temp t for water? I have been thinking of a triple set with oil pressure as well i was planning on using the 6mm bolt or t in to the feed pipe. | |
| Subject: Re: Putting in gauges Sun Apr 07, 2013 11:10 pm | |
| Just some cheap auto type from local parts store. And yes, I went to hardware store and put together some fitting.
I did look for gauges I could easily match for future gauges. | |
| Subject: Re: Putting in gauges Sun Apr 07, 2013 11:26 pm | |
| copy. After hearing of james overheating issue gauges got bumped up on the list quickly... any ideas on oil p[ressure | |
| Subject: Re: Putting in gauges Sun Apr 07, 2013 11:29 pm | |
| I dont, but if some one doesnt chime in, start a new thread for oil pressure gauge. I need to do one, but dont really have a place for it.
Temp gauge was a real eye opener ! Glad I got it. Temp light doesnt come on till about 260. | |
| Subject: Re: Putting in gauges Sun Apr 07, 2013 11:31 pm | |
| WOW>> 260 will do new thread coming up | |
Randy3451
| Subject: Re: Putting in gauges Sun Apr 07, 2013 11:56 pm | |
| Love my gauges, water temp, oil pressure and volts. Never have gotten my tach to work right. | |
| Subject: Re: Putting in gauges Mon Apr 08, 2013 12:01 am | |
| Would love to have a tach !!! Just for fun ! | |
| Subject: Re: Putting in gauges Mon Apr 08, 2013 12:10 am | |
| - Firefighter wrote:
- I dont, but if some one doesnt chime in, start a new thread for oil pressure gauge. I need to do one, but dont really have a place for it.
Temp gauge was a real eye opener ! Glad I got it. Temp light doesnt come on till about 260. I agree the water temp was an eye opener. You should check out what oil temps run. I added a oil temp gauge, personally the pressure doesn't concern me as much as the temp does. As far as a sensor location, their are several options. If your basically stock, just drill and tap one of the cooler line Banjo bolts. If you have a remote oil filter adapter it may have a port for a sender, if not drill and tap it. If you have braided hoses with AN fittings you can just add a tee and install the needed fitting. | |
tjt603
| Subject: Re: Putting in gauges Mon Apr 08, 2013 12:12 am | |
| I used a painless wiring harness and a grounding block. nothing is tied into factory wiring.
| Subject: Re: Putting in gauges Tue Apr 09, 2013 12:24 pm | |
| That is bad ass. In my future plans for sure. Man these things are like money pits. Mods are limitless... | |
| Subject: Re: Putting in gauges Tue Apr 09, 2013 12:47 pm | |
| I love the way a Rhino's dash just utterly and completely changes with a set of gauges. It's super easy to do on a Rhino, too. Here's my latest gauge and switch pic that I have. I used the Livorsi gauges from Black Rhino but I don't like them all that much. The water temp gauge has some fogging going on. It drives me nuts! LoL I recently ordered a set of Gaffrig marine gauges that have the 270 degree sweep needles. They also have a glass bezel instead of the plastic bezel like my current gauges. I went a little OCD on my accessory wiring, too. I purchased one of the Painless wiring blocks that has one always hot circuit and two switched hot circuits. I made my own custom harness and nothing is run off the stock wiring at all. It took me like two weeks of wiring and installing for my accessories. I just didn't want to have any electrical problems down the road. So far so good. Here is a shot of behind my switch and gauge panel. Here you can see the fuse block: The water temp sending unit. I put the sender on the driver side hose on my Rhino 700. It is the hot side (water coming out of the motor) Battery box after some tidying up. After this pic was taken I did upgrade the winch wiring to 4AWG cable. My 5000lb Viper Max needs more juice than that wire could deliver. My suggestion is to take your time putting in the electrical accessories and NEVER ground anything to the chassis. The stock wiring is good for the stock Rhino and that's it. Lots of people have messed up and melted wires by grounding to the frame. | |
| Subject: Re: Putting in gauges Tue Apr 09, 2013 1:09 pm | |
| Another great write up Chris very good pics and detailed thanks | |
| Subject: Re: Putting in gauges Tue Apr 09, 2013 5:23 pm | |
| Wow your rhino sure is clean, thanks for the pics! | |
| Subject: Re: Putting in gauges Tue Apr 09, 2013 6:14 pm | |
Snorhino
| Subject: Re: Putting in gauges Tue Apr 09, 2013 9:34 pm | |
| Subject: Re: Putting in gauges Tue Apr 09, 2013 10:10 pm | |
| That thang looks brand knew under the hood. | |
bubba53
Posts : 117 Join date : 2013-04-07 Age : 70 Location : statesville,nc
| Subject: Re: Putting in gauges Wed Apr 10, 2013 8:33 am | |
Spanky
Posts : 18 Join date : 2013-03-10 Age : 57 Location : Raceland Louisiana
| Subject: Re: Putting in gauges Wed Apr 10, 2013 6:28 pm | |
| I used VDO for mine off of ebay no problems so far. Thinking about changing the oil pressure to oil temp before I hook it up. First Version Second Version added a radio Latest version due to previous radio not working. | |
| Subject: Re: Putting in gauges Wed Apr 10, 2013 6:32 pm | |
Spanky
| Subject: Re: Putting in gauges Wed Apr 10, 2013 6:43 pm | |
| Not bad for a street sigh, uh I mean scrap aluminum, lol | |
| Subject: Re: Putting in gauges | |
