In total there are 95 users online :: 0 Registered, 0 Hidden and 95 Guests :: 2 Bots
are they all he same? Icon_minitimeWed Aug 16, 2023 1:17 pm by RADICAL RAM
are they all he same? Icon_minitimeThu Dec 14, 2017 4:54 pm by WV Hot Rod Rhino
are they all he same? Icon_minitimeThu Dec 14, 2017 1:28 am by WV Hot Rod Rhino
are they all he same? Icon_minitimeThu Dec 14, 2017 12:35 am by WV Hot Rod Rhino
are they all he same? Icon_minitimeFri Dec 13, 2013 11:01 am by WV Hot Rod Rhino
are they all he same? Icon_minitimeFri Dec 13, 2013 10:59 am by WV Hot Rod Rhino
are they all he same? Icon_minitimeFri Dec 13, 2013 9:33 am by Tacoclaw
are they all he same? Icon_minitimeFri Dec 13, 2013 7:50 am by chuddly
are they all he same? Icon_minitimeFri Dec 13, 2013 7:47 am by chuddly
are they all he same? Vote_lcapare they all he same? Voting_barare they all he same? Vote_rcap
5 posters
are they all he same? Empty
PostSubject: are they all he same?   are they all he same? Icon_minitimeThu Apr 11, 2013 12:45 pm
Are all the rear bolt paterns the same on the rhinos? I found some rear wheel spacers but in their add it says for 06-07 Rhino but mine is an 05. What is the difference in them if there is any?
PostSubject: Re: are they all he same?   are they all he same? Icon_minitimeThu Apr 11, 2013 12:59 pm
Not that i know of... i put some tires from an 04 on my 09 with no issues......
PostSubject: Re: are they all he same?   are they all he same? Icon_minitimeThu Apr 11, 2013 1:10 pm
I won't be a problem.
4/110 bolt pattern, same as all Rhinos.
PostSubject: Re: are they all he same?   are they all he same? Icon_minitimeThu Apr 11, 2013 1:23 pm
yep..as far as i know
PostSubject: Re: are they all he same?   are they all he same? Icon_minitimeThu Apr 11, 2013 2:03 pm
ok thanks guys. I was just curious because i didnt think there was any differences but i wanted to confirm my thoughts .
PostSubject: Re: are they all he same?   are they all he same? Icon_minitimeThu Apr 11, 2013 2:07 pm
If you do get them make sure to lock tire the nuts that set down inside the housing they look like lock nuts but they will back off on you and will cause the tire to kick out on you. And cause the wheel bearings to go out faster cause of the play in the the spacers.
PostSubject: Re: are they all he same?   are they all he same? Icon_minitimeThu Apr 11, 2013 3:11 pm
thanks for the advice!
