| keihin fcr41 | |
| Subject: keihin fcr41 Sun Apr 14, 2013 3:06 pm | |
| heard that this makes a good swap for the rhino , from benchmark, just wanted to see if anyone is running one | |
Posts : 1649 Join date : 2013-03-10 Age : 60 Location : Asheboro N.C./Mountain Top West By God Virginia
| Subject: Re: keihin fcr41 Sun Apr 14, 2013 3:11 pm | |
| Im running one and its the best carb you can get for a rhino,ive had the hsr 45 and it was not consistant,love the keihin!! mine has the r&d power bowl 2 on it. | |
| Subject: Re: keihin fcr41 Sun Apr 14, 2013 3:17 pm | |
| From what ive heard,the honda crf450r keinhin fcr mx carb between 2003-2005 is the one u want. | |
Posts : 1317 Join date : 2013-03-25 Age : 60 Location : musella,Ga.
| Subject: Re: keihin fcr41 Sun Apr 14, 2013 6:49 pm | |
| what all do you have to change to run the keihin fcr,is the throat bigger does it allow more air | |
| Subject: Re: keihin fcr41 Sun Apr 14, 2013 7:09 pm | |
| did yours come from benchmark red, or somewhere else, is it worth the investment | |
| Subject: Re: keihin fcr41 Sun Apr 14, 2013 7:31 pm | |
| - rhino727 wrote:
- what all do you have to change to run the keihin fcr,is the throat bigger does it allow more air
No,i got lucky and bought an fcr 41 bored to 43mm with the power bowl 2 for $400,this carb is the most consistent carb i have ran,better than the stock carb and the hsr 45 even tho it is only 43mm,you have to get a different throtle cable,and the slide does not depend on vacuum,when u nail it your wide open,and it has a jet for off idle boost that sprays gas before wide open throttle!! | |
| Subject: Re: keihin fcr41 Sun Apr 14, 2013 7:33 pm | |
| DEFINETLY THE FCR IS THE BEST CARB I HAVE RAN!! | |
| Subject: Re: keihin fcr41 Sun Apr 14, 2013 9:27 pm | |
| cool man thanks for the info | |
| Subject: Re: keihin fcr41 Sun Apr 14, 2013 9:40 pm | |
| Glad to help!! fcr all the way!! | |
jaydog13
| Subject: Re: keihin fcr41 Tue Apr 16, 2013 10:19 pm | |
| i looked at a fcr 41 what is the wire for ? do u have to hook it up somehow or do away with it | |
| Subject: Re: keihin fcr41 Tue Apr 16, 2013 10:30 pm | |
| Do away with it,cut it off. | |
sugarbear
Posts : 105 Join date : 2013-03-11 Location : slc, utah
| Subject: Re: keihin fcr41 Tue Apr 16, 2013 10:49 pm | |
| Well picked up a used benchmark 41 fcr carb today. I have a stock engine right now with open uni and exhaust tip where would be a good starting point for the jets at 4500-7500 ft elevation? | |
| Subject: Re: keihin fcr41 Tue Apr 16, 2013 11:05 pm | |
| Not sure,i have 35 pilot...165 main at 1750 ft...maybe 35 and 155 main? | |
| Subject: Re: keihin fcr41 Tue Apr 16, 2013 11:12 pm | |
| Also if your too rich drop your needle. | |
| Subject: Re: keihin fcr41 | |
| keihin fcr41 | |
