| HELP for grinding a weld | |
+6madmax 1 rhino727 onebuilder KJrhino WV Hot Rod Rhino Firefighter 10 posters |
| Subject: Re: HELP for grinding a weld Thu Apr 18, 2013 9:26 pm | |
| I did not weld around the coupler. I feel confident that I left enough weld on to hold it. May be wrong !
I'm sure I will need to re jet, but I don't have an A/F gauge yet, so it would just be a guess.
My next "thing" will be an A/F gauge. Either buy or borrow. I did go ahead and weld an exhaust bung on while I had it out. | |
| Subject: Re: HELP for grinding a weld Thu Apr 18, 2013 9:29 pm | |
| Yeah I remember it over on the dark side lol | |
| Subject: Re: HELP for grinding a weld Thu Apr 18, 2013 10:03 pm | |
| do you think it will flow that much more to require rejetting | |
| Subject: Re: HELP for grinding a weld Thu Apr 18, 2013 10:05 pm | |
| o yea where did you get the exhaust bung at , auto parts store? | |
| Subject: Re: HELP for grinding a weld Thu Apr 18, 2013 10:07 pm | |
| I don't want to mess with re-jetting. | |
| Subject: Re: HELP for grinding a weld Thu Apr 18, 2013 10:14 pm | |
| - madmax 1 wrote:
- do you think it will flow that much more to require rejetting
Not sure Mick, but those welds were HUGE. | |
| - madmax 1 wrote:
- o yea where did you get the exhaust bung at , auto parts store?
JBS ! | |
| Subject: Re: HELP for grinding a weld Thu Apr 18, 2013 10:18 pm | |
| cool i'll check mine out tommorow | |
| Subject: Re: HELP for grinding a weld Thu Apr 18, 2013 10:19 pm | |
| - CustomizedRhino13 wrote:
- I don't want to mess with re-jetting.
Re jetting isn't bad at all and if You do much performance stuff (exhaust or intake), You REALLY need to. If You don't, it could run lean and burn up a good motor. | |
| Subject: Re: HELP for grinding a weld Thu Apr 18, 2013 10:20 pm | |
| Madmax, I think You could find one local (parts store) | |
| Subject: Re: HELP for grinding a weld Thu Apr 18, 2013 10:22 pm | |
| ill check in am cause i hate to wait | |
| Subject: Re: HELP for grinding a weld Thu Apr 18, 2013 10:25 pm | |
| how far from flange did you place o2 bung | |
| Subject: Re: HELP for grinding a weld Thu Apr 18, 2013 10:29 pm | |
| - madmax 1 wrote:
- how far from flange did you place o2 bung
I put it right in the curve behind the collector . I think that is where James puts them. I would show You a pic, but I welded it and it is FUGLY !! | |
| Subject: Re: HELP for grinding a weld Thu Apr 18, 2013 10:34 pm | |
| Subject: Re: HELP for grinding a weld Mon Apr 22, 2013 12:56 pm | |
| - madmax 1 wrote:
- sounds good let us know when your up and runnin
Got to run it this weekend with the exhaust mod. NICE !!. I thought it would show up best on take off, but I really think it improve between low and mid range the most ! | |
| Subject: Re: HELP for grinding a weld Mon Apr 22, 2013 8:59 pm | |
| thats great orders donuts and bung from james should be her soon, sound like somthing from a porn movie, bung and donuts would make a good title | |
| Subject: Re: HELP for grinding a weld Mon Apr 22, 2013 9:00 pm | |
| hopfully get to mine this weekend other stuff came up thanks for info keep us posted | |
| Subject: Re: HELP for grinding a weld Mon Apr 22, 2013 10:51 pm | |
| - Firefighter wrote:
Got to run it this weekend with the exhaust mod. NICE !!. I thought it would show up best on take off, but I really think it improve between low and mid range the most ! Glad to hear you like it! Have you done the washer swap in the carb yet??? | |
| Subject: Re: HELP for grinding a weld Mon Apr 22, 2013 10:53 pm | |
| Subject: Re: HELP for grinding a weld Mon Apr 22, 2013 10:57 pm | |
| Yep, done that when I rejetted. With the tip and weld grinding, its like a different machine. Oh yea and the UNI filter w adapter. Thanks a bunch Steve ! | |
| Subject: Re: HELP for grinding a weld Tue Apr 23, 2013 6:28 pm | |
| I snuck my header & bung into work an tiged it ,my little mig would have been ok but not set-up for stainless | |
| Subject: Re: HELP for grinding a weld Tue Apr 23, 2013 7:08 pm | |
| tried my mig on the old muffler and pipe and it seams to weld fine | |
| Subject: Re: HELP for grinding a weld | |
