| HELP for grinding a weld | |
+6madmax 1 rhino727 onebuilder KJrhino WV Hot Rod Rhino Firefighter 10 posters |
| Subject: Re: HELP for grinding a weld Sat Apr 27, 2013 12:10 am | |
| very nice ride looks good | |
| Subject: Re: HELP for grinding a weld Sat Apr 27, 2013 3:43 pm | |
| took dogs for a ride out to the mudhole back in the woods behind the house solid low end gain but even more impressive mid gain real tight woods so not able to get to top end but very happy for just a little grinding and polishing
| Subject: Re: HELP for grinding a weld Sat Apr 27, 2013 4:08 pm | |
| Awesome Mick ! Hats off to Onebuilder for bringing this mod up ! | |
| Subject: Re: HELP for grinding a weld Sat Apr 27, 2013 4:39 pm | |
| yea man x2, really no money involved maybe 45-60 min well worth your time | |
| Subject: Re: HELP for grinding a weld Sat Apr 27, 2013 5:05 pm | |
| Did ya do a plug check madmax? | |
| Subject: Re: HELP for grinding a weld Sat Apr 27, 2013 6:59 pm | |
| Happy to share anything I have learned.
I know Larry has swapped the washers on the slide, do you other guys know about it? Helps fatten the mid and upper mid range. It's another free mod! | |
| Subject: Re: HELP for grinding a weld Sat Apr 27, 2013 7:06 pm | |
| I heard about it but don't quite understand where you're talking about? | |
| Subject: Re: HELP for grinding a weld Sat Apr 27, 2013 7:23 pm | |
| yea I did seems to be good nice brown color runs great | |
| Subject: Re: HELP for grinding a weld Sat Apr 27, 2013 7:31 pm | |
| Thanks, I might pull it out and try it then! | |
| Subject: Re: HELP for grinding a weld Sat Apr 27, 2013 7:32 pm | |
| let us know what ya think | |
| Subject: Re: HELP for grinding a weld Sat Apr 27, 2013 8:56 pm | |
| Will do, got a bunch of those die grinder bits now! | |
| Subject: Re: HELP for grinding a weld Sun Apr 28, 2013 1:30 am | |
| The manadory safety alert message follows: Safety glasses at a minimum and face shield is even better. Grinding inside of a hole can get out of control quite quickly and the tool can bounce around in there very violently. There, I feel better now. | |
| Subject: Re: HELP for grinding a weld Sun Apr 28, 2013 1:40 am | |
| Is that speaking from experience? It happens when you turn it on after its in the hole, happened to me a couple times today | |
| Subject: Re: HELP for grinding a weld Sun Apr 28, 2013 2:33 am | |
| Yeah its definitely a death wheel! | |
| Subject: Re: HELP for grinding a weld Sun Apr 28, 2013 3:12 am | |
| Subject: Re: HELP for grinding a weld Sun Apr 28, 2013 10:32 am | |
| they can be very dangerous, saw a big 14" base grinder wheel explode was like a grenade chunks of stone everywhere, steves right faceshield saved my modeling career hahaha, be safe , I also did the washer mod on the needle when I did the rais tube | |
| Subject: Re: HELP for grinding a weld | |
