In total there are 90 users online :: 0 Registered, 0 Hidden and 90 Guests :: 1 Bot
CAM Icon_minitimeWed Aug 16, 2023 1:17 pm by RADICAL RAM
CAM Icon_minitimeThu Dec 14, 2017 4:54 pm by WV Hot Rod Rhino
CAM Icon_minitimeThu Dec 14, 2017 1:28 am by WV Hot Rod Rhino
CAM Icon_minitimeThu Dec 14, 2017 12:35 am by WV Hot Rod Rhino
CAM Icon_minitimeFri Dec 13, 2013 11:01 am by WV Hot Rod Rhino
CAM Icon_minitimeFri Dec 13, 2013 10:59 am by WV Hot Rod Rhino
CAM Icon_minitimeFri Dec 13, 2013 9:33 am by Tacoclaw
CAM Icon_minitimeFri Dec 13, 2013 7:50 am by chuddly
CAM Icon_minitimeFri Dec 13, 2013 7:47 am by chuddly
CAM Vote_lcapCAM Voting_barCAM Vote_rcap
 CAM
4 posters
RADICAL RAM
CAM Empty
PostSubject: CAM   CAM Icon_minitimeSun Apr 28, 2013 11:28 pm
going to have to purchase a new cam.
ive researched this before but forget.
as i recall stage 1 is the next step up from stock and stage 2 is bigger.
do i need to replace valve springs with stage 1 cam or is that only for stage 2
thanks
CAM Empty
PostSubject: Re: CAM   CAM Icon_minitimeSun Apr 28, 2013 11:34 pm
Most all high performance Cam's should use heavy duty springs.
RADICAL RAM
CAM Empty
PostSubject: Re: CAM   CAM Icon_minitimeSun Apr 28, 2013 11:41 pm
OK, just trying to decide if i stay stock or bump it up a little while its apart.
thanks
RHINOMOON
RHINOMOON
CAM Empty
PostSubject: Re: CAM   CAM Icon_minitimeSun Apr 28, 2013 11:50 pm
id talk to james.. (JBS).He will set you up right
CAM Empty
PostSubject: Re: CAM   CAM Icon_minitimeMon Apr 29, 2013 12:09 am
you can always do the head work over size valves and the good springs maybe port the head now and be happy, happy , happy
CAM Empty
CAM
