| numb feeling | |
| Subject: numb feeling Mon Apr 29, 2013 7:50 am | |
| I love my Rhino but the thing i dont like about it is how numb the throttle/backend feels. Is there anyway to give a bit more feeling to the back end of this thing? its like you never really know when the rear end is spinning or anything. I dont know if its my tires (about 50% work stockers) or my suspension (all stock with sway bars still attached)? Any help would be great. | |
| Subject: Re: numb feeling Mon Apr 29, 2013 9:11 am | |
| not sure, have you been hiking again??? but maybe you could back off shocks preload maybe feel the weight transfer more? ahhhh.......you must become one with your rhino O grasshopper then you will fill | |
| Subject: Re: numb feeling Mon Apr 29, 2013 9:19 am | |
| mine gets better traction w/o the rear swaybar, just a thought | |
| Subject: Re: numb feeling Mon Apr 29, 2013 10:13 am | |
| its not really a traction issue. I dont mind the back end coming around. I was truckin across the field yesterday at about 45mph and hit some water the the back end came out and that doesnt bother me...stayed in the throttle and counter steer and just keep goin. Its more that you just dont feel ANY THING going on back there. Maybe disconnecting the sway bars would help out and let it flex a bit more. I cant really dial back my shock preload because i have a cage and seat back there all the time...plus kids back there so i need the weight in the springs so i dont bottom out the shocks all the time. | |
| Subject: Re: numb feeling Mon Apr 29, 2013 10:35 am | |
| When I'm going 45 mph the rhino feels like its off the ground floating, the stockers don't have a lot of traction either so there easier to break loose. How much tire pressure are you running that could be a factor. | |
| Subject: Re: numb feeling Mon Apr 29, 2013 11:06 am | |
| its not a traction issue....whether i do or dont have traction isnt the issue. Its when it starts to move or let go or do anything you dont feel it very quickly in the rhino. | |
rockin rhino
Posts : 91 Join date : 2013-04-14
| Subject: Re: numb feeling Mon Apr 29, 2013 1:22 pm | |
| i think i kinda know what your talking about and i notice it more with my stock tires on when i put my diggers on it i can defenatly feel it when the tires break lose with the stockers sometimes i am spinning and dont relize it till i see the rosters or the dug up lawn that mu wife gets a littel mad about | |
| Subject: Re: numb feeling Mon Apr 29, 2013 1:26 pm | |
| imho that's what happens when you have pulleys instead of direct drive. i think a cvt isolates a lot of the feel that you're talking about. i notice the difference if i hop on my wife's rancher. it just hooks up better right off the bat. it's a trade-off... | |
| Subject: Re: numb feeling Mon Apr 29, 2013 1:49 pm | |
| Chuddly I think I know what You are talking about ! I have somewhat gotten use to it. I think that is were the clutch slugs come in. Gives more of a feeling of direct drive ! I have not done this mod yet, but from the way everyone describes it, It will help that feeling. | |
| Subject: Re: numb feeling Mon Apr 29, 2013 2:01 pm | |
| Slugging the clutch couldnt hurt either....I think i will do a combo of all the above. loose the rear sway bar, tires at some point (when my current ones wear out) and slug the clutch. | |
| Subject: Re: numb feeling | |
| numb feeling | |
